Witam!
ostatnio byłem u elektronika który stwierdził że prawdopodobnie mam coś z komputerem silnika.
poniżej podaję kody błędów:
E R R O R M E M O R Y ---------------------------------------
Date: 09.04.2010 19:57:37
ECU: ME9K42
JobStatus: OKAY
Variant: ME9K42
RESULT: 10 error in error memory !-------------------------------------------------------------
2760 CDKSLS - Secondary air system
Error counter: 1
Logistic counter: 36
Mileage 180320 km
Mittelwert Lambdaregelfaktor (frm) 0.98
Lambda-Sollwert (lamsons) 1.00
Korrekturfaktor Höhe (fho_u) 1.91
Motorstarttemperatur (tmst) 95.25 Grd C
Sekundaerluftdurchsatz zu gering
Test conditions fulfilled
Error present now and already stored
Error would not cause a warning lamp to light up
Error code: 0A 27 60 62 22 01 24 46 70 7E 10 7A BF FF FF FF FF FF FF FF FF FF FF FF-------------------------------------------------------------
2761 CDKSLS2 - Secondary air system bank2
Error counter: 1
Mileage 180320 km
Mittelwert Lambdaregelfaktor B2(frm2) 1.00
Lambda-Sollwert Bank2 (lamsons2) 1.00
Korrekturfaktor Höhe B2(fho_u) 1.91
Test conditions fulfilled Error present now and already stored
Error code: 0A 27 61 62 22 01 24 46 70 80 10 7A BF FF FF FF FF FF FF FF FF FF FF FF-------------------------------------------------------------
27BB CDKANWS - Camshaft control outlet-VANOS
Error counter: 4
Logistic counter: 40
1. Umweltsatz Mileage 180400 km
Engine speed (nmot) 2320.00 /min
Engine temperature (tmot) 94.50 degrees C
rel. air filling (rl) 10.50 %
Supply voltage (ub) 12.25 V
2. Umweltsatz Mileage 180430 km
Engine speed (nmot) 2080.00 /min
Engine temperature (tmot) 95.25 degrees C
3. Umweltsatz Mileage 181060 km
Engine speed (nmot) 1040.00 /min
Engine temperature (tmot) 96.75 degrees C
rel. air filling (rl) 13.50 %
Supply voltage (ub) 13.00 V
Anschlagadaption außerhalb gültigem Bereich
Test conditions fulfilled Error not occurred yet
Error code: 0A 27 BB 02 20 04 28 46 78 3A BE 0E 82 46 7B 34 BF 0E 82 46 BA 1A C1 12-------------------------------------------------------------
272C CDKRKAT - Adaption add. per time
Error counter: 1
Logistic counter: 27
Mileage 180440 km
Engine speed (nmot) 800.00 /min
rel. air filling (rl) 18.75 %
gas level (tfst) 17.00 l
Regulator factor bank1 (fr_u) 1.19 -
System zu mager additiv pro Zeit zu gross
Error would cause a warning lamp to light up
Error code: 0A 27 2C 81 00 01 1B 46 7C 14 19 11 99 FF FF FF FF FF FF FF FF FF FF FF-------------------------------------------------------------
272D CDKRKAT2 - Adaption add. per time (Bank2)
Error counter: 1
Mileage 180440 km
Regulator factor bank2 (fr2_u) 1.12 -
Error code: 0A 27 2D 81 00 01 1B 46 7C 14 19 11 90 FF FF FF FF FF FF FF FF FF FF FF-------------------------------------------------------------
2731 CDKENWS - Camshaft control inlet - VANOS
Error counter: 2 Logistic counter: 35
1. Umweltsatz Mileage 180440 km
Engine speed (nmot) 2040.00 /min
Engine temperature (tmot) 98.25 degrees C
rel. air filling (rl) 24.75 %
wnwi1_u 0.00 Grad KW
2. Umweltsatz Mileage 180790 km
Engine speed (nmot) 2520.00 /min
wnwi1_u 31.00 Grad KW
Anschlagadaption ausserhalb gueltigen Bereich
Error code: 0A 27 31 02 00 02 23 46 7C 33 C3 21 00 46 9F 3F C1 12 1F FF FF FF FF FF-------------------------------------------------------------
272A CDKFRAU - Adaption multipl. area1
Error counter: 1
Mileage 180800 km
Engine speed (nmot) 2800.00 /min
rel. air filling (rl) 21.75 %
Intake air temperature (tans) 13.50 degrees C
gas level (tfst) 12.00 l
Gemisch zu mager Test conditions fulfilled
Error code: 0A 27 2A 81 00 01 23 46 A0 46 1D 52 0C FF FF FF FF FF FF FF FF FF FF FF-------------------------------------------------------------
2780 CDKBM - Ref. marking generator
Error counter: 2
Logistic counter: 38
1. Umweltsatz Mileage 180970 km
Engine speed (nmot) 2200.00 /min
Engine temperature (tmot) 97.50 degrees C
Ambient temperature (tumg) 12.00 Grd C
Supply voltage (ub) 12.43 V
2. Umweltsatz Mileage 180980 km
Engine speed (nmot) 0.00 /min
Ambient temperature (tumg) 10.50 Grd C
Kurbelwellen-Zahnfehler oder Lueckenverlust
Test conditions fulfilled Error not present now, but already stored
Error code: 0A 27 80 28 00 02 26 46 B1 37 C2 50 84 46 B2 00 C2 4E 84 FF FF FF FF FF-------------------------------------------------------------
2782 CDKPH2 - Camshaft sensor outlet
Error counter: 2
Logistic counter: 37
1. Umweltsatz Mileage 180980 km
Supply voltage (ub) 11.12 V
Supply voltage (ub) 10.83 V
Lage der Phasenflanken oder Einbaulage ausserhalb Toleranz
Error code: 0A 27 82 04 20 02 25 46 B2 00 C3 4E 76 46 B2 00 C3 4E 73 FF FF FF FF FF-------------------------------------------------------------
2727 CDKLASH2 - Lambda sensor ageing after cat bank2
Error counter: 1
Logistic counter: 39
Mileage 181000 km
Engine speed (nmot) 2000.00 /min
Cat temp. out of the model bank2(tkatm2) 410.00 Grd C
Inside resistor LS before cat bank2 (rinh2) 128.00 Ohm
Sensor voltage before cat bank2 (ushk2) 0.24 V
Schubspannungsschwelle nicht erreicht
Error code: 0A 27 27 04 21 01 27 46 B4 32 5C 02 55 FF FF FF FF FF FF FF FF FF FF FF ================================================== ===========
objawy są takie że mi od czasu do czasu autem szarpie, często towarzyszy temu zapalenie się na około 2 sek. kontrolki od baterii. nieraz przy szarpnięciu strasznie zafalują obroty- i auto gaśnie...bylem wczoraj u elektronika to mówił mi gosć że to może być prawdopodobnie wina komputera i może być do wymiany.
czy Państwo jesteście w stanie określić czy ten komputer nadaje się do naprawy?
w załączniku foto
pzdr
Łukasz
[img]
[/img]
ECU: ME9K42
JobStatus: OKAY
Variant: ME9K42
Error counter: 1
Mileage 180320 km
Error counter: 1
Mileage 180320 km
Error counter: 4
Error counter: 1
Mileage 180440 km
Error counter: 1
Mileage 180440 km
Error counter: 1
Mileage 180800 km
Error counter: 2
Error counter: 2
Error counter: 1
Mileage 181000 km
w załączniku foto
pzdr
Łukasz
[img]
