[tyny13][c]AVRDUDE: ERROR: address 0x0410 out of range.
carkar 06 Lip 2010 18:34 3517 6
  • #1 8267006
    carkar
    Napisałem programik pod tiny13 w c daje program a tu niemiła niespodzianka.
    > "make.exe" program
    Compiling C: main.c
    avr-gcc -c -mmcu=attiny13 -I. -gdwarf-2 -DF_CPU=1000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=./main.lst  -std=gnu99 -MMD -MP -MF .dep/main.o.d main.c -o main.o
    main.c: In function 'main':
    main.c:12: warning: implicit declaration of function 'rand'
    Linking: main.elf
    avr-gcc -mmcu=attiny13 -I. -gdwarf-2 -DF_CPU=1000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.o  -std=gnu99 -MMD -MP -MF .dep/main.elf.d main.o --output main.elf -Wl,-Map=main.map,--cref     -lm
    Creating load file for Flash: main.hex
    avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock main.elf main.hex
    Creating load file for EEPROM: main.eep
    avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
    	--change-section-lma .eeprom=0 --no-change-warnings -O ihex main.elf main.eep || exit 0
    avrdude -p attiny13 -P usb -c usbasp    -U flash:w:main.hex
    avrdude: warning: cannot set sck period. please check for usbasp firmware update.
    avrdude: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.03s
    avrdude: Device signature = 0x1e9007
    avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
             To disable this feature, specify the -D option.
    avrdude: erasing chip
    avrdude: reading input file "main.hex"
    avrdude: input file main.hex auto detected as Intel Hex
    [color=red]avrdude: ERROR: address 0x0410 out of range at line 65 of main.hex[/color]
    avrdude: write to file 'main.hex' failed
    avrdude done.  Thank you.
    make.exe: *** [program] Error 1
    > Process Exit Code: 2
    > Time Taken: 00:01
    Jeszcze kod programu:
    #define F_CPU 1000000UL
    #include <avr/io.h>
    #include <util/delay.h>
    int main(void)
      int nadal;
      nadal = 0x01;
      DDRB = 0x07;
      PORTB = 0x18;
      while(1) {
      int zmienna = rand()%5000;
      _delay_ms(zmienna);
      PORTB |= 0x01;
      while(nadal) {
      if (!(PINB & 0x08)) {
      PORTB &= ~0x01;
      PORTB |= 0x02;
      nadal = 0x00;
      break;
      if (!(PINB & 0x10)) {
      PORTB &= ~0x01;
      PORTB |= 0x03;
      nadal = 0x00;
      _delay_ms(3000);
    Co jest nie tak??
    P.s. Co ciekawe gdy zamienię linijkę:
    na:
    int zmienna = 5673;
    Wszystko gra....
    Więc jak inaczej wygenerować liczbę losową??
    gaskoin
    można użyć timera zamiast rand()
  • #4 8267753
    mirekk36
    Co za niespodzianka ???? To tylko i wyłącznie twój błąd. Wiele razy było wałkowane na temat tego, że do funkcji _delay_ms(xxx) nie należy przekazywać zmiennych bo to właśnie skutkuje takim gwałtownym przyrostem kodu. I nie jest to przypadkowy przyrost. Tyle że teraz nie będziemy rozmawiać dlaczego nie jest przypadkowy.
    Na dzisiaj uświadom sobie i zakonotuj, że do funkcji _delay_ms(xxx) w miejsce xxx podstawiasz tylko i WYŁĄCZNIE stałą dosłowną a nie zmienną. Zrób to a zobaczysz w jak cudowny sposób zmniejszy ci się ilość kodu. A kiedyś zrozumiesz dlaczego przyrasta gdy ładujesz tam na siłę zmienną!
    Jeśli już chcesz koniecznie mieć możliwość regulacji czasu pętli opóźniającej w milisekundach to piszesz sobie ew taką funkcyjkę:
    void my_delay(uint16_t ms) {
       while(ms--) _delay_ms(1);
    i wtedy możesz spokojnie podać do takiej funkcji zmienną, która spowoduje odczekanie żądanej przez ciebie ilości ms.
    teraz jaśniej ??? ;)
    Dr.Vee
    mirekk36 ma tu oczywiście rację.
    Dodatkowo użycie rand() bez inicjalizacji przez srand() zawsze po resecie zwróci taką samą "losową" liczbę. Generator liczb pseudolosowych trzeba jakoś zainicjalizować.
  • #7 8270197
    carkar
    Dzięki wszystkim.
    Dostajecie po 3 punkty.
