Moim problemem jest ciągły pomiar 85 st. Rezystor podciągający 4,7k jest, szyna zasilana i GND do masy, program z sampli mikroC (!). Fuse bity ustawione na wewnętrzny rezonator 8MHz. Procesor zmieniłem na Atmega8 o czym poinformowałem kompilator. Poniżej zamieszczam kod, może ktoś poprawi Mikronikę
* Project name:
OneWire (Interfacing the DS1820 temperature sensor - all versions)
* Copyright:
(c) Mikroelektronika, 2009.
* Revision History:
20080930:
- initial release;
- 20090818 - Slavisa Zlatanovic;
* Description:
This code demonstrates one-wire communication with temperature sensor
DS18x20 connected to PB2 pin.
MCU reads temperature from the sensor and prints it on the LCD.
The display format of the temperature is 'xxx.xxxx°C'. To obtain correct
results, the 18x20's temperature resolution has to be adjusted (constant
TEMP_RESOLUTION).
* Test configuration:
MCU: ATmega16
http://www.atmel.com/dyn/resources/prod_documents/doc2466.pdf
Dev.Board: EasyAVR6
http://www.mikroe.com/en/tools/easyavr6/
Oscillator: External Clock 8.0000 MHz
Ext. Modules: DS18x20, LCD 2x16
http://www.mikroe.com/en/tools/components/
SW: mikroC PRO for AVR
http://www.mikroe.com/en/compilers/mikroc/avr/
* NOTES:
- Place jumper J9 to the right(PB2).
- Pull-up and turn off the LED on pin used for one wire bus (PB2) may be required.
// LCD module connections
sbit LCD_RS at PORTD2_bit;
sbit LCD_EN at PORTD3_bit;
sbit LCD_D4 at PORTD4_bit;
sbit LCD_D5 at PORTD5_bit;
sbit LCD_D6 at PORTD6_bit;
sbit LCD_D7 at PORTD7_bit;
sbit LCD_RS_Direction at DDD2_bit;
sbit LCD_EN_Direction at DDD3_bit;
sbit LCD_D4_Direction at DDD4_bit;
sbit LCD_D5_Direction at DDD5_bit;
sbit LCD_D6_Direction at DDD6_bit;
sbit LCD_D7_Direction at DDD7_bit;
// End LCD module connections
// Set TEMP_RESOLUTION to the corresponding resolution of used DS18x20 sensor:
// 18S20: 9 (default setting; can be 9,10,11,or 12)
// 18B20: 12
const unsigned short TEMP_RESOLUTION = 9;
char *text = "000.0000";
unsigned temp;
void Display_Temperature(unsigned int temp2write) {
const unsigned short RES_SHIFT = TEMP_RESOLUTION - 8;
char temp_whole;
unsigned int temp_fraction;
// check if temperature is negative
if (temp2write & 0x8000) {
text[0] = '-';
temp2write = ~temp2write + 1;
// extract temp_whole
temp_whole = temp2write >> RES_SHIFT ;
// convert temp_whole to characters
if (temp_whole/100)
text[0] = temp_whole/100 + 48;
else
text[0] = '0';
text[1] = (temp_whole/10)%10 + 48; // Extract tens digit
text[2] = temp_whole%10 + 48; // Extract ones digit
// extract temp_fraction and convert it to unsigned int
temp_fraction = temp2write << (4-RES_SHIFT);
temp_fraction &= 0x000F;
temp_fraction *= 625;
// convert temp_fraction to characters
text[4] = temp_fraction/1000 + 48; // Extract thousands digit
text[5] = (temp_fraction/100)%10 + 48; // Extract hundreds digit
text[6] = (temp_fraction/10)%10 + 48; // Extract tens digit
text[7] = temp_fraction%10 + 48; // Extract ones digit
// print temperature on LCD
Lcd_Out(2, 5, text);
void main() {
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear LCD
Lcd_Cmd(_LCD_CURSOR_OFF); // Turn cursor off
Lcd_Out(1, 1, " Temperature: ");
// Print degree character, 'C' for Centigrades
Lcd_Chr(2,13,223); // Different LCD displays have different char code for degree
// If you see greek alpha letter try typing 178 instead of 223
Lcd_Chr(2,14,'C');
//--- main loop
do {
//--- perform temperature reading
Ow_Reset(&PORTB, 2); // Onewire reset signal
Ow_Write(&PORTB, 2, 0xCC); // Issue command SKIP_ROM
Ow_Write(&PORTB, 2, 0x44); // Issue command CONVERT_T
Delay_us(120);
Ow_Write(&PORTB, 2, 0xBE); // Issue command READ_SCRATCHPAD
Delay_ms(400);
temp = Ow_Read(&PORTB, 2);
temp = (Ow_Read(&PORTB, 2) << 8) + temp;
//--- Format and display result on Lcd
Display_Temperature(temp);
Delay_ms(500);
} while (1);
