VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 038 906 018 FD
Component: 1,9l R4 EDC G000SG 2137
Coding: 00002
Shop #: WSC 06335
2 Faults Found:
17656 - Injection Start Regulation: Control Deviation
P1248 - 35-10 - - - Intermittent
17654 - Shareware Version. To Decode all DTCs
P1246 - 35-10 - Please Register/Activate - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 AB
Component: ABS 5.3 FRONT D00
Coding: 0273004281
Shop #: BB 24548
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D54
Coding: 00043
Shop #: WSC 06335
2 Faults Found:
00779 - Outside Air Temp Sensor (G17)
30-10 - Open or Short to B+ - Intermittent
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 881 H
Component: B5-KOMBIINSTR. VDO D15
Coding: 05140
Shop #: WSC 00027
IMMO-IDENTNR: AUZ7Z0X1049897
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
Address 25 -------------------------------------------------------
Controller: Bitte Adress
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35 -------------------------------------------------------
Controller: 8D0 862 257
Component: ZV-Pumpe, DWA, Funk D12
Coding: 13131
Shop #: WSC 06335
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
00991 - Interior Lights
28-00 - Short to B+
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
End -------------------------------------------------------
witam oto co wskazał wag dodam że po skasowaniu błędów narazie jest OK
