Udało mi się kupić: MONOBLOCK JL AUDIO 500/1
Ciekawy klocek, klasa D, 500W w szerokim zakresie impedancji (od 1,5 do 4).
DF>500/4R. Po Crunch'u to przynajmniej o klasę wyżej
Parametry poniżej:
Features:
* Differential-Balanced Input Topology: (1 pair of Inputs)
* On-board Crossover: fully variable (40Hz - 200Hz), selectable-slope LP (12 or 24 dB per octave)
* Preamp Output: 2-channel (independent active filter, parallel with amp filter or full-range)
* Bass EQ: parametric with variable boost up to 15dB and Remote Bass Control (optional)
* Infrasonic Filter: fully-variable 24dB/octave from 15-60Hz
* Signal-Sensing Turn-On: permits operation without remote lead
* Dual Mono Speaker output connections: accepts up to 8ga. wire
* +12V and Ground connections: accepts up to 4ga. wire
Specifications:
* Rated Power: 500W RMS @ 1.5 ohm-4 ohm
(11V-14.5V)
* THD at Rated Power: <0.05% @ 4 ohm
* S/N Ratio: >95dB below rated power
* Frequency Response: 5 Hz-500Hz (+0, -1dB)
* Damping Factor: >500 @ 4 ohm per channel/50 Hz
* Input Range: switchable from 200mV-2V RMS
to 800mV-8V RMS
* Dimensions: 13.4"L x 9.25"W x 2.36"H
