[AT91SAM7S256] AT91SAM7S256, OpenOCD, OOCDLink - brak połączenia JTAG na Windows 7 x64
klyman 12 Lis 2010 19:52 3369 10
  • #1 8735747
    klyman
    Próbuję nawiązać kontakt między mikrokontrolerem, a jtgagiem. Mój system: Windows 7 x64. Openocd odpalam z poziomu linii poleceń:
    openocd -f interface/oocdlink.cfg -f target/sam7s256.cfg
    zawartość pliku interface/oocdlink.cfg:
    # Joern Kaipf's OOCDLink
    # http://www.joernonline.de/contrexx2/cms/index.php?page=126
    interface ft2232
    ft2232_device_desc "OOCDLink"
    ft2232_layout oocdlink
    ft2232_vid_pid 0x0403 0xBAF8
    #jtag_khz 5
    zawartość pliku target/sam7s256.cfg:
    # Target section, this example was tested with an
    # Olimex SAM7-P256 board.
    # Start slow, speed up after reset
    jtag_khz 5
    #use combined on interfaces or targets that can't set TRST/SRST separately
    reset_config srst_only srst_pulls_trst
    #reset_config trst_only trst_push_pull
    if { [info exists CHIPNAME] } {
    set _CHIPNAME $CHIPNAME
    } else {
    set _CHIPNAME sam7s256
    if { [info exists ENDIAN] } {
    set _ENDIAN $ENDIAN
    } else {
    set _ENDIAN little
    if { [info exists CPUTAPID ] } {
    set _CPUTAPID $CPUTAPID
    } else {
    set _CPUTAPID 0x3f0f0f0f
    jtag newtap $_CHIPNAME cpu -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_CPUTAPID
    set _TARGETNAME [format "%s.cpu" $_CHIPNAME]
    target create $_TARGETNAME arm7tdmi -endian $_ENDIAN -chain-position $_TARGETNAME -variant arm7tdmi
    $_TARGETNAME configure -event reset-init {
    # disable watchdog
    mww 0xfffffd44 0x00008000
    # enable user reset
    mww 0xfffffd08 0xa5000001
    # CKGR_MOR : enable the main oscillator
    mww 0xfffffc20 0x00000601
    sleep 10
    # CKGR_PLLR: 96.1097 MHz
    mww 0xfffffc2c 0x00481c0e
    sleep 10
    # PMC_MCKR : MCK = PLL / 2 ~= 48 MHz
    mww 0xfffffc30 0x00000007
    sleep 10
    # MC_FMR: flash mode (FWS=1,FMCN=60)
    mww 0xffffff60 0x003c0100
    sleep 100
    $_TARGETNAME configure -work-area-virt 0 -work-area-phys 0x00200000 -work-area-size 0x4000 -work-area-backup 0
    #flash bank <driver> <base> <size> <chip_width> <bus_width>
    #flash bank at91sam7 0 0 0 0 0
    #init
    #reset halt
    # For more information about the configuration files, take a look at:
    # openocd.texi
    komunikat od openocd:
    Open On-Chip Debugger 0.4.0 (2010-02-22-19:05)
    Licensed under GNU GPL v2
    For bug reports, read
    http://openocd.berlios.de/doc/doxygen/bugs.html
    srst_only srst_pulls_trst srst_gates_jtag srst_open_drain
    Warn : use 'at91sam7s.cpu' as target identifier, not '0'
    Info : clock speed 6000 kHz
    Info : JTAG tap: at91sam7s.cpu tap/device found: 0x3f0f0f0f (mfg: 0x787, part: 0
    xf0f0, ver: 0x3)
    Warn : Unexpected idcode after end of chain: 32 0x00000000
    Warn : Unexpected idcode after end of chain: 64 0x00000000
    Warn : Unexpected idcode after end of chain: 96 0x00000000
    Warn : Unexpected idcode after end of chain: 128 0x00000000
    Warn : Unexpected idcode after end of chain: 160 0x00000000
    Warn : Unexpected idcode after end of chain: 192 0x00000000
    Warn : Unexpected idcode after end of chain: 224 0x00000000
    Warn : Unexpected idcode after end of chain: 256 0x00000000
    Warn : Unexpected idcode after end of chain: 288 0x00000000
    Warn : Unexpected idcode after end of chain: 320 0x00000000
    Warn : Unexpected idcode after end of chain: 352 0x00000000
    Warn : Unexpected idcode after end of chain: 384 0x00000000
    Warn : Unexpected idcode after end of chain: 416 0x00000000
    Warn : Unexpected idcode after end of chain: 448 0x00000000
    Warn : Unexpected idcode after end of chain: 480 0x00000000
    Warn : Unexpected idcode after end of chain: 512 0x00000000
    Warn : Unexpected idcode after end of chain: 544 0x00000000
    Warn : Unexpected idcode after end of chain: 576 0x00000000
    Warn : Unexpected idcode after end of chain: 608 0x00000000
    Error: double-check your JTAG setup (interface, speed, missing TAPs, ...)
    xf0f0, ver: 0x3)
    Command handler execution failed
    Warn : jtag initialization failed; try 'jtag init' again.
    Nie jestem pewny, czy mój jtag nie jest uszkodzony - próbowałem wgrać konfiguracje poprzez mprog'a 3.0 - niestety otrzymuje:
    Number Of Blank Devices = 0
    Number Of Programmed Devices = 0
    Nie mniej jednak, jak odłącze procesor to openocd pokazuje:
    5 kHz
    Info : clock speed 5 kHz
    Error: JTAG scan chain interrogation failed: all zeroes
    Error: Check JTAG interface, timings, target power, etc.
    Czy ktoś ma pomysł o co może chodzić ? Czy to wina konfiguracji, czy sprzętu? Schemat mojego jtaga jest taki sam jak na tej stronie: https://www.elektroda.pl/rtvforum/topic1513657.html#7399949
  • #2 8736667
    Freddie Chopin
    Specjalista - Mikrokontrolery
    Ocena: 870
    Jestem na 99% pewny, że w pierwszym (niedziałającym) przypadku odpalasz OpenOCD inaczej niż w tym drugim, bo za pierwszym razem nie ustawia Ci prędkości JTAGa (Info : clock speed 6000 kHz), a za drugim razem już to robi (Info : clock speed 5 kHz). Pozatym w pierwszym przypadku nazwy używane przez OpenOCD (at91sam7s) nie zgadzają się z tymi w pliku który pokazałeś (sam7s256).
    4\/3!!
  • #3 8746932
    klyman
    No tak... to oczywiście moja pomyłka - w między czasie sprawdzałem inne pliki konfiguracyjne i wkleiłem odpowiedź przy innych parametrach.
    C:\Windows\system32>openocd -f interface/oocdlink.cfg -f target/sam7s256.cfg
    5 kHz
    Info : JTAG tap: sam7s256.cpu tap/device found: 0x3f0f0f0f (mfg: 0x787, part: 0xf0f0, ver: 0x3)
    Info : Embedded ICE version 1
    Info : sam7s256.cpu: hardware has 2 breakpoint/watchpoint units
    Info : accepting 'telnet' connection from 0
    Łącze się przez telnet i daje polecenia:
    > init
    > reset halt
    srst pulls trst - can not reset into halted mode. Issuing halt after reset.
    Halt timed out, wake up GDB.
    timed out while waiting for target halted
    TARGET: sam7s256.cpu - Not halted
    in procedure 'reset' called at file "command.c", line 650
    called at file "command.c", line 361
    Kiedy odhashowałem linijkę w sam7s256.cfg:
    otrzymuję błąd:
    5 kHz
    Error: usage: flash bank <name> <driver> <base> <size> <chip_width> <bus_width>
    Przy czym dzieje się tak tylko na wersji windowsowej openocd (u znajomego na linuxie nie pokazywało błędu).
    Dodam jeszcze, że teraz podłączam inną płytkę z procesorem niż wcześniej, (aczkolwiek teoretycznie jest taka sama).
  • #4 8747148
    Freddie Chopin
    Ocena: 870
    Ten plik którego używasz jest "niezbyt" (na niewiele Ci się przyda). Proponuję abyś spróbował odpalić (na razie bez żadnych zmian) OpenOCD na jednym z tych dwóch plików:
    c:\Program Files\OpenOCD\0.4.0\target\at91sam7sx.cfg
    c:\Program Files\OpenOCD\0.4.0\target\sam7x256.cfg
    Do wywołania dodatkowo dostaw:
    openocd -f interface/oocdlink.cfg -f target/....cfg -c "jtag_khz 1000"
    (w razie problemów poexperymentuj z wartością - powinna być 8x mniejsza niż prędkość rdzenia PO RESECIE).
    4\/3!!
  • #5 8781527
    klyman
    Po dość długiej przerwie mam właśnie okazję znowu coś porobić.
    C:\Windows\system32>openocd -f interface/oocdlink.cfg -f target/at91sam7sx.cfg -c "jtag_khz 1000"
    1000 kHz
    Info : clock speed 1000 kHz
    Info : TAP at91sam7s.cpu does not have IDCODE
    Warn : JTAG tap: at91sam7s.cpu UNEXPECTED: 0x00000000 (mfg: 0x000, part: 0x0000, ver: 0x0)
    Error: JTAG tap: at91sam7s.cpu expected 1 of 1: 0x3f0f0f0f (mfg: 0x787, part: 0xf0f0, ver: 0x3)
    Warn : Unexpected idcode after end of chain: 1 0x07fd047d
    Warn : Unexpected idcode after end of chain: 33 0x00000000
    Warn : Unexpected idcode after end of chain: 65 0x00000000
    Warn : Unexpected idcode after end of chain: 97 0x00000000
    Warn : Unexpected idcode after end of chain: 129 0x00000000
    Warn : Unexpected idcode after end of chain: 161 0x00000000
    Warn : Unexpected idcode after end of chain: 193 0x00000000
    Warn : Unexpected idcode after end of chain: 225 0x00000000
    Warn : Unexpected idcode after end of chain: 257 0x00000000
    Warn : Unexpected idcode after end of chain: 289 0x00000000
    Warn : Unexpected idcode after end of chain: 321 0x00000000
    Warn : Unexpected idcode after end of chain: 353 0x00000000
    Warn : Unexpected idcode after end of chain: 385 0x00000000
    Warn : Unexpected idcode after end of chain: 417 0x00000000
    Warn : Unexpected idcode after end of chain: 449 0x00000000
    Warn : Unexpected idcode after end of chain: 481 0x00000000
    Warn : Unexpected idcode after end of chain: 513 0x00000000
    Warn : Unexpected idcode after end of chain: 545 0x00000000
    Warn : Unexpected idcode after end of chain: 577 0x00000000
    Taki wynik dla at91sam7sx.cfg, natomiast dla sam7x256.cfg:
    C:\Windows\system32>openocd -f interface/oocdlink.cfg -f target/sam7x256.cfg -c"jtag_khz 1000"
    1000 kHz
    Info : JTAG tap: sam7x256.cpu tap/device found: 0x3f0f0f0f (mfg: 0x787, part: 0xf0f0, ver: 0x3)
    Info : sam7x256.cpu: hardware has 2 breakpoint/watchpoint units
    Warn : srst pulls trst - can not reset into halted mode. Issuing halt after reset.
    Info : Halt timed out, wake up GDB.
    Error: timed out while waiting for target halted
    TARGET: sam7x256.cpu - Not halted
    a to zwrócił telnet:
    > init
    > reset halt
    I teraz rzecz, która zauważyłem - jeżeli zrobię reset halt, to dostaje takie właśnie komunikaty.
    Jeżeli po podłączeniu procesora dam samo halt, to otrzymuje:
    > halt
    target state: halted
    target halted in ARM state due to debug-request, current mode: Supervisor
    cpsr: 0x80000013 pc: 0x00100148
    czyli w sumie dobrze. Jeżeli teraz dam resume, to powraca do pracy, natomiast jeżeli teraz dam reset i poźniej halt to otrzymuje:
    > reset
    NOTE! DCC downloads have not been enabled, defaulting to slow memory writes. Type 'help dcc'.
    NOTE! Severe performance degradation without fast memory access enabled. Type 'help fast'.
    > halt
    in procedure 'halt' called at file "command.c", line 650
    Wgrałem na uC program migający diodami i widzę, że po komendzie reset nie zaczyna migać na nowo - przycisk reset na płytce też nie działa. W takiej sytuacji jak odłączę uC i podłączę na nowo, wszystko wraca do normy. Jednak po każdej próbie wykonania komendy reset, na nowo muszę odłączać i podłączać uC.
  • #6 8781726
    Freddie Chopin
    Ocena: 870
    Ok, coś się dzieje [;
    1. W skrypcie targeta dodaj/zmień:
    reset_config trst_and_srst
    Możesz poexperymentować z tą opcją i różnymi ustawieniami:
    reset_config trst_and_srst srst_pulls_trst
    2. W skrypcie zedytuj to:
    	# disable watchdog
    	# enable user reset
    	sleep 10
    	sleep 10
    	sleep 10
    	sleep 100
    Wywal wszystko co dotyczy przestawiania częstotliwości - zakomentuj / wykasuj wszystko poniżej "# CKGR_MOR : enable the main oscillator". Jeśli czujesz się na siłach, to możesz oczywiście wprowadzić tam wartości które będą odpowiadały Twojej płytce.
    Zamiast "reset halt" spróbuj używać "reset init".
    3. Na samym końcu skryptu w linijce:
    flash bank $_FLASHNAME at91sam7 0 0 0 0 $_TARGETNAME 0 0 0 0 0 0 0 18432
    ostatnia cyfra to częstotliwość zewnętrznego kwarcu (w kHz) - ustaw odpowiednią dla Twojej płytki.
    4. Możesz też poexperymentować z prędkością JTAGa jtag_khz (szczególnie z baaardzo niskimi wartościami (1 - 10)
    P.S. łącząc się przez telnet nie musisz wydawać ręcznie komendy "init" - jest ona wykonywana automatycznie gdy OpenOCD skończy mielić pliki konfiguracyjne podane w wywołaniu. Używa się jej tylko wtedy, gdy chcesz w wywołaniu zawrzeć jakieś komendy "akcji", np.:
    openocd -f ... -f ... -c "init; reset halt; flash write_image erase c:/firmware.hex"
    4\/3!!
  • #7 8782031
    klyman
    Dziwna sprawa...
    Zrobiłem jak kazałeś - niestety nie pomogło na problem z resetem. W między czasie spod eclipse odpaliłem gdb (wg opisu z Twojej strony, z tą różnicą, że napisałem:
    monitor halt
    monitor mww 0xE01FC040 0x0002
    load
    ) i teraz to w ogóle się nie mogę połapać... Zasadniczo pokazało jakiś błąd (a później zawiesił się eclipse). Później odpaliłem plik bez komendy load. W tym momencie, robię wszystko tak jak wcześniej. Włączam openocd i na razie wszystko jest tak jak było.Łącze się przez telnet i nie jestem w stanie nic zrobić, ponieważ jestem "zasypywany" powtarzającymi się linijkami:
    Error: ftdi_write_data: usb bulk write failed
    Error: couldn't write MPSSE commands to FT2232
    EDIT: pospieszyłem się z tym postem - zrestartowałem system i teraz wróciłem do punktu wyjścia:) niestety problem z komendą reset w dalszym ciągu nie rozwiązany...
    Freddie Chopin
    Ocena: 870
    W sprawie Eclipse'a możesz zerknąć też tutaj https://www.elektroda.pl/rtvforum/topic1313509-60.html#8653959
    4\/3!!
  • #9 8782594
    flapo213
    Ocena: 10
    Witaj,
    Jeśli chcesz aby działał Ci reset hardwarowy na płytyce to niestety musisz go włączyć programowo najpierw inaczej nie będzie śmigało. Spójrz w dokumentację układu odnośnie sekcji hardware reset. Po wykonaniu tych operacji wszystko powinno Ci śmigać jak trzeba
  • #10 8782897
    klyman
    flapo213 napisał:
    Witaj,
    Zdaje sobie z tego sprawę. Chodziło mi o coś innego - miałem załadowany program, w którym reset był włączony i wszystko śmigało, tylko po wykonaniu resetu spod openocd, ten hardwarowy przestawał działać.
  • #11 8799473
    klyman
    Jeżeli chodzi o sprawę resetu. Częściowo chyba się wyjaśniło. uC, z którym miałem problem AT91SAM7S256. Ostatnio podłączyłem jakąś płytkę testową z uC AT91SAM7S64 i na tych samych plikach konfiguracyjnych (sam7x256.cfg) wydanie komendy reset halt wykonywane było poprawnie. Wnioskuję, że jest jakiś problem z tym uC (S256) - może uszkodzony, albo coś źle podlutowane ?
✨ Użytkownik ma problemy z nawiązaniem połączenia JTAG między mikrokontrolerem AT91SAM7S256 a interfejsem OOCDLink na systemie Windows 7 x64. Po uruchomieniu OpenOCD z odpowiednimi plikami konfiguracyjnymi, użytkownik zauważa różnice w prędkości JTAG oraz błędy związane z identyfikacją urządzenia. W odpowiedziach sugerowane są zmiany w plikach konfiguracyjnych, takie jak użycie innych plików targetowych (at91sam7sx.cfg, sam7x256.cfg) oraz modyfikacje ustawień resetu. Użytkownik odkrywa, że problem z resetem może być związany z uszkodzeniem mikrokontrolera, ponieważ na innej płytce testowej z AT91SAM7S64 reset działa poprawnie.
