[C] Atmega16a dekodowanie RC5
politech 02 Sty 2011 15:43 902 0
  • #1 8947359
    politech
    znalazłem na tym forum kod dekodujący sygnał rc5, ale nie do końca go rozumiem i chciałbym prosić o pomoc.
    Kod:
    #include <avr/io.h>
    #include <avr/interrupt.h>
    #include <avr/signal.h>
    #define RC5BitHigh()    (bit_is_set(PIND,PD3))
    #define RC5BitLow()     (bit_is_clear(PIND,PD3))
    #define WAITFORTIMER()  { while ( timerflag == 0); timerflag = 0; }
    // CLK = 4MHz
    #define TIMER_0_CNT 0xC9     //  111us = 1/( (CLK/8)/(0xFF-0xC9) )
    #define RC5BITREF1  6
    #define RC5BITREF2  11
    #define RC5BITREF3  14
    #define IR_int_enable GIFR|=(1<<INT1);GICR|=(1<<INT1)
    #define IR_int_disable GICR&=~(1<<INT1)
    volatile uint8_t timerflag;
    volatile unsigned int    rc5data;
    void rc5_init()
       DDRD  &= ~(1<<PD3);           // konfiguracja PD3 jako wejście
        PORTD |= (1<<PD3);           // enable internal pull-up resistors
          MCUCR|=_BV(ISC11); // ext. int. activated by falling edge
          MCUCR&=~_BV(ISC10);
          GIFR = (1<<INTF1); // clear ext. int. flag
          GICR|=_BV(INT1); // enable ext. int.
    SIGNAL(SIG_OVERFLOW0)
        timerflag = 1;               // set global variable
        TCNT0 = TIMER_0_CNT;         // reset counter to get this interrupt again
    SIGNAL(SIG_INTERRUPT1)
       IR_int_disable;      //wylaczenie przerwan zewnetrznych
       sei();
        unsigned char   timer, i;
        // init timer/Counter2
        TCCR0 = 0x02;                    // use CLK/8 prescale
        TCNT0 = TIMER_0_CNT;             // set timer T/16 = 111us
        TIMSK |= (1<<TOIE0);             // enable TCNT0 overflow interrupt
        TIMSK &=~(1<<TOIE2);             // disable TCNT2 overflow interrupt
        // measure startbit
        timerflag = 0; timer = 0;
        while ( RC5BitLow() && (timer < RC5BITREF2) ) {
            WAITFORTIMER();
            timer++;
        if ( (timer > RC5BITREF1) && (timer < RC5BITREF2) ) {
            // startbit ok, decode
            // wait T/4: synchronize in the middle of first half of second bit
            while ( timer < RC5BITREF3 ) {
                WAITFORTIMER();
                timer++;
            // read the remaining bits
            rc5data = 1;
            for (i=0; i<13; i++) {
                rc5data <<= 1;
                if ( RC5BitHigh() ) {
                    rc5data |= 0x0001;
                    // wait max T/2 for H->L transition (middle of next bit)
                    timer = 0;
                    while ( RC5BitHigh() && (timer < 16) ) {
                        WAITFORTIMER();
                        timer++;
                }else{
                    rc5data &= ~0x00001;
                    // wait max T/2 for L->H transition (middle of next bit)
                    timer = 0;
                    while ( RC5BitLow() && (timer < 16) ) {
                        WAITFORTIMER();
                        timer++;
                if ( timer == 16 ) {
                    rc5data = 0x0000;   // error, next bit not found
                    return;
                // wait 3/4 T: await next bit
                for ( timer=0; timer < 12 ; timer++) WAITFORTIMER();
        }else {
            rc5data = 0x0000;  // error, invalid RC-5 code
        TCCR0=0;
        TIMSK &=~(1<<TOIE0);              // disable TCNT0 overflow interrupt
        TIMSK |= (1<<TOIE2);              // enable TCNT2 overflow interrupt
       IR_int_enable;
    int main()
       DDRD=0;;//Porty D jako wejścia
       rc5_init();
       sei();
       while(1)
             if(rc5data)
                PORTB=0x00;
    W projekcie korzystam z 4Mhz, w kodzie determinuje to wartość makra TIMER_0_CNT, dzięki któremu wypracowany będzie czas 111us, co który przepełniać się będzie 8-bitowy licznik.
    I rozumiem to tak: przychodzi przerwanie z dekodera IR(tsop1736), wywoływana jest procedura obsł. przerwania w której na początku wyłączane są przerwania zewnętrzne, żeby móc dalej zdekodować sygnał. (to jeszcze, jeszcze rozumiem).
    Pierwszy bit jest startowy, ma zawsze wartość "1"(czyli w połowie bitu zmiana 0->1) więc w pętli:
            WAITFORTIMER();
            timer++;
    czekamy dopóki wartość na PD3 to "0" lub do 1221us(czyli mniej niż 0.75 bitu) i za pętlą mamy niby zdekodowany ten pierwszy bit startu.
                WAITFORTIMER();
                timer++;
    a pętla, wdł. mnie czeka do 1554us, co nawet nie jest drugim bitem, natomiast z komentarza wynika, że ma to być środek połowy drugiego bitu:(
    Dalej jest niby odczytywanych 13 bitów(2gi bit startu, toggle bit, adres, komenda), tak że:
    rc5data = 1 jest przesuwane z każdym przebiegiem pętli (1 bo ten drugi bit startu chyba?) w którym sprawdzany jest stan PD3, niby w chwili T/4. Jeśli "1" to jest ustawiana jedynka w rc5data jeśli "0" to 0.
    I nawet tutaj mam wątpliwość, bo jeśli w pierwszej połowie bitu jest "1" to będzie zmiana z 1->0, czyli "0".
    Nie jestem w stanie tego zrozumiec, dlatego zwracam się o pomoc.
