[PHP] ZendStudio 7.2 - Wywala błąd po uruchomieniu.
toma5z 07 Lut 2011 15:46 785 0
  • #1 07 Lut 2011 15:46
    toma5z
    Witajcie,
    mam pewien problem, z którym nie umie sobie poradzić.
    Gdy odpalam zend studio wywala mi takie coś:
    Could not create the view: org/eclipse/wst/jsdt/core/JavaScriptModelException
    java.lang.NoClassDefFoundError: org/eclipse/wst/jsdt/core/JavaScriptModelException
    at org.eclipse.php.internal.ui.explorer.PHPExplorerPart.createContentProvider(PHPExplorerPart.java:121)
    at org.eclipse.dltk.internal.ui.scriptview.ScriptExplorerPart.setProviders(ScriptExplorerPart.java:723)
    at org.eclipse.dltk.internal.ui.scriptview.ScriptExplorerPart.createPartControl(ScriptExplorerPart.java:631)
    at org.eclipse.php.internal.ui.explorer.PHPExplorerPart.createPartControl(PHPExplorerPart.java:178)
    at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:367)
    at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:226)
    at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
    at org.eclipse.ui.internal.Perspective.showView(Perspective.java:2229)
    at org.eclipse.ui.internal.WorkbenchPage.busyShowView(WorkbenchPage.java:1067)
    at org.eclipse.ui.internal.WorkbenchPage$20.run(WorkbenchPage.java:3816)
    at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
    at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3813)
    at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage.java:3789)
    at org.eclipse.ui.handlers.ShowViewHandler.openView(ShowViewHandler.java:165)
    at org.eclipse.ui.handlers.ShowViewHandler.execute(ShowViewHandler.java:80)
    at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:294)
    at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
    at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
    at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
    at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
    at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:770)
    at org.eclipse.ui.menus.CommandContributionItem.access$10(CommandContributionItem.java:756)
    at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:746)
    at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
    at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
    at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
    at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
    at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
    at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
    at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
    at java.lang.reflect.Method.invoke(Unknown Source)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:726)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:542)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1478)
    Uniemożliwia mi to prace nad kodem. Cały czas wyskakuje ww. popup.
    Dzieje się tak od momentu gdy uruchomiłem pierwszy raz na tym samym pc eclipse. Zend i eclipse są na tym samym dysku.
    0 0
