Audi A4 2004 rok Problem z Airbag błąd vag 01794
kobi231 01 Mar 2011 21:28 22372 11
  • #1 9222941
    kobi231
    Witam. Problem z Audi A4 jak w temacie. Po około 10-15 minutach jazdy zapala się kontrolka Airbag. Po podłączeniu VCDS i zeskanowaniu pokazuje co następuje:
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Tuesday,01,March,2011,18:44:09:60804
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    Mileage: 185220km/115090miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 LJ
    Component: 1,9l R4 EDC G000SG 5934
    Coding: 00003
    Shop #: WSC 06325
    VCID: 6AD0475E3C17
    WAUZZZ8E15A085432 AUZ6Z0D0281641
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 4529
    Coding: 04255
    Shop #: WSC 06435
    VCID: 2648736EE88F
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AD
    Component: A4 Klimaautomat 1424
    Coding: 00000
    Shop #: WSC 06325
    VCID: 63CE2A7ADB3D
    1 Fault Found:
    01794 - Control Module - Incorrect Chassis (VIN) Number
    35-00 - -
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 C
    Component: int. Lastmodul RDW 0606
    Coding: 00001
    Shop #: WSC 06325
    VCID: 32609F3ED447
    1 Fault Found:
    35-00 - -
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 06325 000 00000
    VCID: 3E78BB0E101F
    2 Faults Found:
    000 - - - Intermittent
    00474 - Control Module for Immobilizer
    004 - No Signal/Communication - Intermittent
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 P
    Component: Lenksáulenmodul 0611
    Coding: 01022
    Shop #: WSC 06325
    VCID: 4084C5F66AEB
    1 Fault Found:
    35-00 - -
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 900 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 05001
    Shop #: WSC 30011
    VCID: 2E588B4EC07F
    Component: A085432 AUZ6Z0D0281641
    Part No: WAUZZZ8E15A
    §˜§˜§˜§˜§A085432 AUZ6Z0D0281641
    1 Fault Found:
    00771 - Fuel Level Sensor (G)
    30-10 - Open or Short to Plus - Intermittent
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 BA
    Component: Komfortgerát TA7 1512
    Coding: 23360
    Shop #: WSC 51951
    VCID: 71E2503211C1
    Part No: 8E1959801B
    Component: Tőrsteuer.FS BRM 0205
    Part No: 8E1959802B
    Component: Tőrsteuer.BF BRM 0205
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 186 D
    Component: concert II GRO 0004
    Coding: 01001
    Shop #: WSC 06325
    VCID: 28547D56E29B
    End ---------------------------------------------------------------------
    Próbowałem procedury przyuczania na kanale 081 ale nic to nie pomaga (po wpisaniu kodu 02905 przycisk save jest nieaktywny).
    Czy ktoś ma pomysł jak usunąć tą usterkę? Pozdrawiam.
  • #2 9223205
    15darekvw
    a sterownik jest z tego auta? czy był reanimowany?
  • #3 9223209
    macvir
    Warunkowo odblokowany
    nie prawdlowy VIN w modulach, swiezy nabytek czy tak sie po nocy stalo?
  • #4 9225991
    kobi231
    Z tego co wiem to ktoś próbował "grzebać' w liczniku i najprawdopodobniej uszkodził wsad (przed ingerencją wszystko było ok). Próbowałem zrobić adaptację VCDS-em według przewidzianej procedury, ale nic z tego (nieaktywny przycisk "save").
    Czy jest jakiś inny sposób usunięcia usterki?
  • #5 9226167
    palala
    Przecież stoi jak byk tu :
    ____________________________________________
    Coding: 05001
    Shop #: WSC 30011
    VCID: 2E588B4EC07F
    1 Fault Found:
    widać, że zabawiał się ktoś fejsem,ale nie wiedział co robi.
    WYDZIABANY VIN - może ktoś kombinował w ten sposób z crc :idea:
    P.S.
    Było się nie bawić fejsem....
  • #6 9227039
    kobi231
    może ktoś będzie tak dobry i podpowie jak w takim razie dopisać (uzupełnić) pełny VIN
  • #7 9228501
    palala
    Dopisanie VIN można zrobić z palucha - czasami jest łatwo, czasami nie.
  • #8 9332585
    kobi231
    a mógłby ktoś podpowiedzieć jak dopisać VIN (VCDS)
  • #9 9770833
    amaradaar
    widzę że nikt za bardzo się nie pali do pomagania.. a ja sam dość dużo przegrzebałem by ktoś wkońcu powiedział mi jak to robić,
    a tak ogólnie wszystko jest na stronie ross-tech.com
    a więc aby przyuczyć vin nalezy:
    wejść w air bag 15
    tam wejść w adaptacje 10
    następnie wpisać kanał 081
    i wprowadzić wartość 02905
    schematycznie
    wpisujemy 081 i klikamy read wczytuje sie 081
    okienko niżej
    wpisujemy wartość 02905 klikamy test wczytuje sie 2905
    klikamy save
    klikamy done and go
    bara boom bara bach i air bag przyucza się vinu :)
    najlepiej użyć coś koło vcds lite 1.0
    ale słyszałem od mistrza Bartka że vag-com 311.2 też robi tylko trzeba jakby wolniej,
    po każdym kliknięciu test read save done dać odpocząć minutke :)
    najważniejsze by mieć pełną wersje programu do diagnostyki
    niemal identycznie przyucza się na stering wheel i climatronicku
    trzeba tylko inne wartości podać dla stery 00111 dla clima 26467
    Pozdrawiam :)
  • #10 9781220
    serafin02
    Witam. U mnie tez problem ustapil ale dopiero po wgraniu oryginalnego wsadu do zegarow. Usterka nastapila po zabawie fejsem i probą zmiany przebiegu na sile:) Na szczescie mialem oryginalny wsad. Dodam ze to tez audi A4 2004 1.6b z kolorowymi zegarami
  • #11 10400527
    need for speed
    witam tez mam problem z airbagiem włącza się po około 10 minutach i ze vin nieprawidłowy,gdzie mogę to zrobić bo nikt nie wie jak to zrobić
    z mechaników prosze o pomoc
  • #12 10701220
    TOMAS2012
    mam problem posiadam błąd 01794
    Address 08 -------------------------------------------------------
    Controller: 8E0 820 043 BM
    Component: A4 Klimaautomat 3233
    Coding: 00000
    Shop #: WSC 00000
    3 Faults Found:
    01794 - Control Module Incorrect Chassis (VIN) Number
    po sprawdzeniu nr Vin okazało się że w pozycji 01 i 17 jest Vin
    a w pozycji 25 nie ma go w liku scrin VAGa
    http://imageshack.us/photo/my-images/713/wada12.jpg/
    co w tym wypadku musiał bym zrobić aby ten błąd usunąć
    z góry dziękuje za pomoc
