Witam z wzmacniaczy które (tak przynajmniej deklaruje producent) 600W RMS oraz w kompaktowych obudowach <200$ znalazłem:
1)
LANZAR MAX PRO MAXP1601D
Cytat: Max Pro Series 1-Channel Amplifier
1 x 750 Watts RMS at 4 Ohms
1 x 1500 Watts Max at 2 Ohms
1 x 3000 Watts Max at 1 Ohms
Anti-Thump Turn-On
Tri-Mode Configurable
Soft Turn On/Off
RCA Line Input and Output
DIN Balance Inputs
Molded Speaker Terminals
Molded Power / Ground Terminals
Remote Connector Included
White Light Illuminated Crossover Control
Power Protection LED Indicators to provide instant information on status on amplifier, including short-circuit and thermal overload alerts
Advanced Protection Circuitry
Bass Boost Remote Control
Bass Boost Circuit : 0 ~ +10dB
Variable Phase Shift Control : 0 to 180 degrees
Variable Subsonic Filter : 15Hz ~ 35Hz
Variable Low Pass Crossover : 35Hz ~ 250Hz
Frequency Response: 15Hz- 150Hz
Dimensions: 10.16"W x 2.56"H x 15.63"L
2)Kenwood XR-1S eXcelon
Cytat: 1500W Class D Mono Digital Power Amplifier
4 ohms: 600 watts x 1 chan
2 ohms: 700 watts x 1 chan
Max power output: 1500 watts x 1 chan
Signal-to-noise Ratio: 83dBA
Low-Pass Filter: 50Hz-200Hz(Variable)
Infrasonic Filter: 15Hz-40Hz(Variable)
Bass Boost Control: 40Hz-100Hz, 0dB
Excellent heat dissipation
Compact Design
CEA-2006 compliant
Wired Remote ready
Performance
Signal to Noise Ratio 105 dB
Crossover / Equalizer
Bass Boost With Bass Boost
POWER ACOUSTIK BAMF2000/1D (BAMF20001D)
Cytat: Amplifier Class : Class D
Number of Channels : 1-Channel
Maximum Power : 2000 Watts
RMS Power Output @ 4 Ohms : 600 Watts x 1-Channel
RMS Power Output @ 2 Ohms : 900 Watts x 1-Channel
RMS Power Output @ 1 Ohms : 1200 Watts x 1 Channel
Bridged Power : N/A
THD : 0.02%
Signal-to-Noise Ratio (dB) : 97db
Frequency Response (Hz) : 20Hz~200hz
Built-in Crossover : N/A
High-Pass Crossover Frequency : N/A
Low-Pass Crossover Frequency : 40Hz~200Hz
Bass Boost : 0dB~18dB
Bass Remote : Yes
Fan Cooled : N/A
Fuse Rating : 40A x 2
Dimensions (Width x Height x Depth) Inches : 11.5" x 2.2" x 9.2"
Czy ktoś mógłby sie wypowiedzieć odnośnie tych modeli?
Całkiem ciekawą propozycją wg mnie jest Kenwood z seri XR-1S eXcelon
