ANSI C m32 problem z kopiowaniem tablic
figa_miga 31 Mar 2011 22:52 1948 9
  • #1 9346917
    figa_miga
    [syntax=c]
    #include <avr/io.h>
    #include <avr/pgmspace.h>
    #include <inttypes.h>
    #define F_OSC 11059200
    #include <util/delay.h>
    #define toggle(PORT, BIT) (_SFR_BYTE(PORT) ^= _BV(BIT))
    #define LCD_DDR DDRA
    #define LCD_PORT PORTA
    #define RS 0
    #define EN 1
    #define D4 2
    #define D5 3
    #define D6 4
    #define D7 5
    char zwloka= 0;
    char BUF_LCD[33];
    char TX1[32];
    volatile uint8_t dsp_1=1;
    volatile uint8_t dsp_2=2;
    volatile uint8_t dsp_3=3;
    volatile uint8_t dsp_4=4;
    volatile uint8_t dsp_5=5;
    unsigned int val=1234;
    unsigned char WSK_LCD=0;
    void LCD_INT(void);
    void LCD_HOME(void);
    void LCD_POZ(unsigned char x,unsigned char y);
    void LCD_1000(unsigned int x);
    void LCD_WRITE_RAM(void);
    void LCD_OUT(char x);
    void CPY_FLASH_RAM(char TAB);
    int main()
    //	_delay_ms  (50);
    	DDRD=255;
    	DDRD=255;
    	LCD_PORT= 255;
    	LCD_DDR=1<<RS|1<<EN|1<<D4|1<<D5|1<<D6|1<<D7; 		//LINIE LCD JAKO WYJSCIA
    	LCD_INT();
    	while(1)
    		_delay_ms (1000);
    		LCD_WRITE_RAM();
    		CPY_FLASH_RAM(TX1);
    return 0;
    		LCD_POZ (1,1);
    		LCD_PORT |=1<<RS;
    		unsigned char i;
    		for (i=0;i<16;i++)
    			LCD_OUT(BUF_LCD[i]);
    			LCD_POZ (1,2);
    			LCD_PORT |=1<<RS;
    		for (i=16;i<32;i++)
    		LCD_PORT &=~(1<<D4|1<<D5|1<<D6|1<<D7);
    		if(x & (1 << 4)) LCD_PORT |=1<<D4;
    		if(x & (1 << 5)) LCD_PORT |=1<<D5;
    		if(x & (1 << 6)) LCD_PORT |=1<<D6;
    		if(x & (1 << 7)) LCD_PORT |=1<<D7;
    		_delay_ms  (1) ;
    		LCD_PORT |=1<<EN;
    		LCD_PORT &=~(1<<EN|1<<D4|1<<D5|1<<D6|1<<D7);
    		if(x & (1 << 0)) LCD_PORT |=1<<D4;
    		if(x & (1 << 1)) LCD_PORT |=1<<D5;
    		if(x & (1 << 2)) LCD_PORT |=1<<D6;
    		if(x & (1 << 3)) LCD_PORT |=1<<D7;
    		LCD_PORT |=1<<EN;
    		LCD_PORT &=~(1<<EN);
    void LCD_INT(void)
    		LCD_PORT =~(1<<RS|1<<EN);	//4x 0011 z pierwsza zwloka
    		LCD_OUT (50);
    		LCD_OUT (50);
    		LCD_OUT (40);		//function set 2 linie 5x7 znakow
    		LCD_OUT (8);		//function set dispaly off
    		LCD_OUT (1);		//function set display on
    		LCD_OUT (6);		//entry mode set inkrementcaja, ram statyczny
    		LCD_OUT (12);		//
    		LCD_PORT |=1<<RS;
    		LCD_PORT |=1<<RS;
    		dsp_1 =x%10+48;
    		x = x/10;
    		dsp_2 =x%10+48;
    		x =x/10;
    		dsp_3 =x%10+48;
    		dsp_4 =x/10+48;
    		LCD_OUT (dsp_4);
    		LCD_OUT (dsp_3);
    		LCD_OUT (dsp_2);
    		LCD_OUT (dsp_1);
    void LCD_HOME(void)
    	LCD_PORT &=~(1<<RS);
    	LCD_OUT (2);
    	_delay_ms  (5) ;
    void LCD_POZ(unsigned char x, unsigned char y)
    	x=x+127;
    	if(y==2) x=x+64;
    	LCD_OUT(x);
    void CPY_FLASH_RAM (char TAB)
    	unsigned char i;
    	for (i=0;i<32;i++)
    		BUF_LCD[i]=pgm_read_byte(TAB[i]);
    char BUF_LCD[33] = "a";
    char TX1[32] PROGMEM = "abcdefghijklmnop1234567890123456";
    [/syntax]
    Przeglądam różne materiały jednak się poddaje, w czym problem?. Przy próbie kompilacji dostaje bład w CPY_FLASH_RAM którego nie mogę rozgryźć. Reszta działa.
  • #4 9346987
    figa_miga
    ../UART_LCD.c:70: warning: passing argument 1 of 'CPY_FLASH_RAM' makes integer from pointer without a cast
    ../UART_LCD.c: In function 'CPY_FLASH_RAM':
    ../UART_LCD.c:166: error: subscripted value is neither array nor pointer
    make: *** [UART_LCD.o] Error 1
    Build failed with 1 errors and 1 warnings...
    bląd jest tu BUF_LCD[i]=pgm_read_byte(TAB[i]);
    war. tu CPY_FLASH_RAM(TX1);
  • #5 9347006
    michalko12
    Specjalista - Mikrokontrolery
    Kod: C / C++
    Zaloguj się, aby zobaczyć kod
  • #6 9347013
    ksz
    Kod: C / C++
    a do
    Kod: C / C++
    się nie czepia?
  • #7 9347085
    figa_miga
    Czepiał się jeśli zdeklaruje BUF_LCD na 32 co też jest klinem, nie mniej jednak w tym dodatkowym bajcie ma siedzieć pozycja dla migającego kursora.
    ksz
    Chodziło mi raczej, że deklarujesz te stringi dwa razy
    michalko12
    Kompilator nie dochodzi do tego miejsca, a jakby doszedł to raczej zgłosiłby ten błąd no i druga sprawa ten string nie zmieści się do tej tablicy.
  • #10 9347843
    figa_miga
    Dzięki michalko i ksz, teraz działa. Nie czepia się też do długości tablic.
