powerbass s-12 + signat rom 4 ?
hrynio400 23 Kwi 2011 16:14 2109 1
  • #1 9431855
    hrynio400
    Pytanie do ludzi siedzacych w CA
    Posiadam PB s-12
    Power Handling
    (RMS/Peak): 300/600 watts
    Nominal Impedance:
    Single 4-ohm
    Voice Coil Size: 2 in
    Frequency Response:
    31Hz - 450Hz
    Sensitivity: 91dB
    Motor Structure: 142 oz
    Mounting Depth: 5.5 in
    Oraz moge miec po taniosci wzmacniacz Signat ROM 4
    Ciezko o nim znalezc informacje ale udalo mi sie wygrzebac takie cos
    Amplificateur 4 canaux
    Puissance : 4x90 (4 ohm, THD = 0.05%)
    Puissance : 2x240 (4 ohm, ponté, THD = 0.1%)
    Bande passante : 10Hz - 60KHz
    Filtre passe-bas : 50-250Hz, 12dB/octave
    Filtre passe-haut : 50-250Hz, 12dB/octave
    Dimensions : 230 x 60 x 390
    Specification data:
    Amp type: 4 channel
    Pc board: double sided
    Power terminal: gold plated screw type
    Speaker terminals: gold plated screw type
    Signal input terminals: 4 x RCA jacks gold plated
    BIC balanced input circuity
    ENS Electronic Noise Suppression
    Bridged mode: yes (min. 4 Ohm)
    Trimode operation: built in
    Protection and control circuites: Temperature, overload, short circuit,
    DC offset
    Output load impendance (stereo mode): 2 - 8 Ohm
    Active low pass filter: 50-250Hz, 12dB (ch 1/2 & 3/4)
    Active high pass filter: 50-250Hz,12dB (ch 1/2 & 3/4)
    Technical data:
    Max. peak music power: 600W
    RMS power at 4 Ohm (0,05% THD): 4x90W
    RMS power at 4 Ohm (0,1% THD): 2x240W
    RMS power at 2 Ohm (0,2% THD): 4x125W
    S/N ratio (A-weighted): 105 dB
    Freq. response (-3dB): 10-60 kHz
    Stereo separation: 70 dB
    Input sensitivity: 150mV - 5V
    Input impendance: 25 kOhm
    Fuse rate: 2 x 30A
    Supply voltage: 12 V DC
    Dimensions: 242 x 60 x 390 mm
    Czy bedzie to dobre polaczenie, czy moze PB wogole na tym nie zagra?
    Czy dalo by rade np zmostkowac dwa kanaly i dac pod suba a kolejne dwa by zasiliy przod?
  • #2 9432213
    Stochus
    Może maxa z pb nie wyciśniesz, ale zagrać, zagra na pewno poprawnie.
    Dobrze kombinujesz :) Sprawdź, i się przekonasz czy Ci pasuje.
