Instrukcji wieży SONY RX77
Ash Ketchum 06 Lis 2004 19:45 6494 6
  • #2 1522995
    Kajtek_170
    Nie EX tylko RX77.
  • #4 1523412
    hansu2
    Jeżeli odpowiada Ci w j.angielskim to mogę podać.
  • #5 1525599
    DiZMar
    Dane techniczne tego modelu i mu podobnych poniżej. Cała instrukcja w języku: English, Spanish, French, German, Italian,Dutch lub Portuguese na życzenie
    page 47
    AUDIO POWER SPECIFICATIONS:
    (MHC-RX66 U.S.A. models only)
    POWER OUTPUT AND TOTAL
    HARMONIC DISTORTION:
    with 6 ohm loads both channels driven, from
    70-20,000 Hz; rates 60 watts per channel
    minimum RMS power, with no more than
    0.9% total harmonic distortion from 250
    milliwatts to rated output.
    Amplifier section
    Canadian models:
    MHC-RX77:
    Continuous RMS power output (reference)
    100 + 100 watts
    (8 ohms at 1 kHz,
    10% THD)
    Total harmonic distortion less than 0.07%
    (8 ohms at 1 kHz, 55 W)
    MHC-RX66:
    60 + 60 watts
    (6 ohms at 1 kHz,
    10% THD)
    (6 ohms at 1 kHz, 45 W)
    European and Russian models:
    MHC-RX900:
    DIN power output (rated) 125 + 125 watts
    (8 ohms at 1 kHz, DIN)
    170 + 170 watts
    (8 ohms at 1 kHz,
    10% THD)
    Music power output (reference)
    275 + 275 watts
    (8 ohms at 1 kHz,
    10% THD)
    MHC-RX77S/RX77/R700:
    DIN power output (rated) 60 + 60 watts
    (6 ohms at 1 kHz, DIN)
    80 + 80 watts
    (6 ohms at 1 kHz,
    10% THD)
    135 + 135 watts
    (6 ohms at 1 kHz,
    10% THD)
    Specifications
    continued
    Other models:
    MHC-GRX9000:
    The following measured at AC 230 V 50/60 Hz
    DIN power output (rated) 130 + 130 watts
    160 + 160 watts
    (8 ohms at 1 kHz,
    10% THD)
    The following measured at AC 120, 220, 240 V
    50/60 Hz
    DIN power output (rated) 140 + 140 watts
    170 + 170 watts
    (8 ohms at 1 kHz,
    10% THD)
    Peak music power output (reference)
    3000 watts
    MHC-GRX7/GRX7J:
    The following measured at AC 110, 220 V 50/60 Hz
    DIN power output (rated) 85 + 85 watts
    110 + 110 watts
    (8 ohms at 1 kHz,
    10% THD)
    The following measured at AC 120, 240 V 50/60 Hz
    DIN power output (rated) 105 + 105 watts
    130 + 130 watts
    (8 ohms at 1 kHz,
    10% THD)
    1500 watts
    MHC-GRX5:
    DIN power output (rated) 50 + 50 watts
    65 + 65 watts
    (6 ohms at 1 kHz,
    10% THD)
    75 + 75 watts
    (6 ohms at 1 kHz,
    10% THD)
    1000 watts
    48
    Specifications (continued) Tape player section
    Recording system 4-track 2-channel stereo
    Frequency response 40 – 13,000 Hz (±3 dB),
    (DOLBY NR OFF) using Sony TYPE I
    cassette
    40 – 14,000 Hz (±3 dB),
    using Sony TYPE II
    cassette
    Wow and flutter ±0.15% W.Peak (IEC)
    0.1% W.RMS (NAB)
    ±0.2% W.Peak (DIN)
    Tuner section
    FM stereo, FM/AM superheterodyne tuner
    FM tuner section
    Tuning range
    2 band models: 87.5 – 108.0 MHz
    3 band (FM–MW–SW) models:
    87.5 – 108.0 MHz
    3 band (FM–MW–LW) models:
    87.5 – 108.0 MHz
    4 band models: 87.5 – 108.0 MHz
    Antenna FM lead antenna
    Antenna terminals 75 ohm unbalanced
    Intermediate frequency 10.7 MHz
    UKV tuner section (4 band models only)
    Tuning range 65.0 – 74.0 MHz
    Stereo Plus
    Inputs
    MD/VIDEO IN: voltage 450 mV/250 mV,
    (phono jacks) impedance 47 kilohms
    MIX MIC: (phone jack) sensitivity 1 mV,
    impedance 10 kilohms
    Outputs
    MD/VIDEO OUT: voltage 250 mV
    (phono jacks) impedance 1 kilohms
    PHONES: accepts headphones of 8
    (stereo phone jack) ohms or more
    SPEAKER:
    MHC-RX66/GRX5/RX77(European models)
    /RX77S/R700: accepts impedance of 6 to
    16 ohms
    MHC-RX900/GRX9000/GRX7/GRX7J/
    RX77 (Canadian models): accepts impedance of 8 to
    16 ohms
    SURROUND SPEAKER:
    (MHC-RX77 Canadian models only):
    accepts impedance of 16
    ohms
    SUPER WOOFER:
    (except MHC-R700/RX77S/RX77 European models)
    Voltage 1 V, impedance 1
    kilohm
    CD player section
    System Compact disc and digital
    audio system
    Laser Semiconductor laser
    (l=780nm)
    Emission duration:
    continuous
    Laser output Max. 44.6 mW*
    *This output is the value
    measured at a distance of
    200 mm from the
    objective lens surface on
    the Optical Pick-up Block
    with 7 mm aperture.
    Frequency response 2 Hz – 20 kHz (±0.5 dB)
    Wavelength 780 – 790 nm
    Signal-to-noise ratio More than 90 dB
    Dynamic range More than 90 dB
    CD OPTICAL DIGITAL OUT
    (Square optical connector jack, rear panel)
    Wavelength 600 nm
    Output Level –18 dBm
    49
    Speaker
    SS-RX900 for MHC-RX900
    SS-GRX9000 for MHC-GRX9000
    Speaker system 3-way, 5-unit,
    bass-reflex type
    Speaker units
    Woofer: 15 cm, cone type x2
    Center Tweeter: 5 cm, cone type
    Side Tweeter: 5 cm, cone type x2
    Nominal impedance 8 ohms
    Dimensions (w/h/d) Approx. 250 x 430 x 355
    mm
    Mass Approx. 7.5 kg net per
    speaker
    SS-J75 for MHC-RX77 (Canadian models)/
    MHC-GRX7/GRX7J
    Speaker system 4-way, 5-unit,
    bass-reflex type
    Speaker units
    Woofer: 17 cm, cone type
    Super Tweeter: 2 cm, dome type
    Dimensions (w/h/d) Approx. 230 x 335 x 310
    mm
    Mass Approx. 5 kg net per
    speaker
    SS-J70 for MHC-RX77S
    bass-reflex type
    Speaker units
    Nominal impedance 6 ohms
    mm
    speaker
    SS-J50 for MHC-RX77 (European models)/
    MHC-RX66/MHC-GRX5
    SS-J50B for MHC-R700
    Speaker system 3-way, bass-reflex type
    Speaker units
    Dimensions (w/h/d) Approx. 220 x 335 x 305
    mm
    Mass Approx. 4 kg net per
    speaker
    AM tuner section
    Tuning range
    2 Band type:
    North American models: 530 – 1,710 kHz
    (with the interval set at 10
    kHz)
    531 – 1,710 kHz
    (with the interval set at 9
    kHz)
    Other models: 531 – 1,602 kHz
    kHz)
    530 – 1,710 kHz
    kHz)
    3 Band/4 Band type:
    MW: 531 – 1,602 kHz
    kHz)
    LW: 153 – 279 kHz
    (with the interval set at 3
    kHz)
    Middle Eastern models:
    MW: 531 – 1,602 kHz
    kHz)
    SW: 5.95 – 17.90 MHz
    (with the interval set at 5
    kHz)
    Other models:
    MW: 531 – 1,602 kHz
    kHz)
    530 – 1,710 kHz
    kHz)
    kHz)
    Antenna AM loop antenna
    Antenna terminals External antenna terminal
    Intermediate frequency 450 kHz
    continued
    Supplied accessories: AM loop antenna (1)
    Remote RM-SR5 (1)
    Batteries (2)
    FM lead antenna (1)
    Speaker cords (2)
    Front speaker pads (8)
    Optional accessories:
    (MHC-RX77 Canadian Surround speaker
    models only) SS-SR101
    Speaker system 1-way, 1-unit,
    bass-reflex type
    Speaker units:
    Full range 8 cm dia., cone type
    Nominal impedance 16 ohms
    Dimensions (w/h/d) Approx. 205 x 95 x 240
    mm
    Mass Approx. 1.1 kg net per
    speaker
    For customers in Canada
    Use only the optional SS-SR101 surround speaker
    for connection to the SURROUND SPEAKER
    connector on the MHC-RX77.
    Design and specifications are subject to change
    without notice.
    General
    Power requirements
    North American models: 120 V AC, 60 Hz
    230 V AC, 50/60 Hz
    Mexican models: 120 V AC, 50/60 Hz
    Australian, Israel and South African models:
    220 - 240 V AC, 50/60 Hz
    Thai models:
    MHC-GRX5/GRX7: 220 - 240 V AC, 50/60 Hz
    MHC-GRX9000: 220 V AC, 50/60 Hz
    Other models:
    MHC-GRX5/GRX7/GRX7J:
    110 - 120 V or 220 - 240 V
    AC, 50/60 Hz
    MHC-GRX9000: 120 V, 220 V or 230 - 240
    V AC, 50/60 Hz
    Power consumption
    U.S.A. models:
    MHC-RX66: 140 watts
    Canadian model:
    MHC-RX66: 120 watts
    MHC-RX77: 195 watts
    MHC-RX77/RX77S/R700:140 watts
    MHC-RX900: 300 watts
    Other models:
    MHC-GRX5: 140 watts
    MHC-GRX7/GRX7J: 250 watts
    MHC-GRX9000: 330 watts
    Dimensions (w/h/d) Approx. 280 x 335 x 380
    mm (131/8 x 111/8 x 15
    in.)
    Mass
    U.S.A. models:
    MHC-RX66: Approx. 8.8 kg
    (19 lbs. 6 oz.)
    Canadian models:
    MHC-RX66: Approx. 8.4 kg
    (18 lbs. 8 oz.)
    MHC-RX77: Approx. 9.5 kg
    (20 lbs. 15 oz.)
    MHC-RX77/RX77S/R700:Approx. 9.1 kg
    (20 lbs. 1 oz.)
    MHC-RX900: Approx. 11.7 kg
    (25 lbs. 13 oz.)
    Other models:
    MHC-GRX5: Approx. 9.4 kg
    (20 lbs. 12 oz.)
    MHC-GRX7/GRX7J: Approx. 10.2 kg
    (22 lbs. 8 oz.)
    MHC-GRX9000: Approx. 12.0 kg
    (26 lbs. 7 oz.)
