A6 C5 2,5TDi zgasło i odpaliło po skasowaniu błędów
figa_miga 29 Kwi 2011 14:26 2712 0
  • #1 9451394
    figa_miga
    Odpaliło po wykasowaniu błędów, lista jest w załączniku.
    Czyżby coś sie działo z 15tką?
    Chassis Type: 4B - Audi A6 C5
    Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56
    Address 01     -------------------------------------------------------
       Controller: 4B2 907 401 F
       Component:  2.5l/4VTEDC G000SG D04
       Coding: 01015
       Shop #: WSC 02325
       00001000001059 130 106LCV77593798185798
    5 Faults Found:
    18043 - Powertrain Data Bus: Missing Message from A/C Controller
                P1635 - 35-10 - - - Intermittent
    01318 - Control Module for Injection Pump (J399)
                49-10 - No Communications - Intermittent
    00546 - Data wiring faulty
    18062 - Please check DTC Memory of Instrument Cluster
                P1654 - 35-00 - -
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
                P1650 - 35-10 - - - Intermittent
    Readiness: N/A
    Address 03     -------------------------------------------------------
       Controller: 4B0 614 517 H
       Component: ABS/ESP allrad      1328
       Coding: 06455
       Shop #: WSC 02325
    1 Fault Found:
    18031 - Powertrain Data Bus: No Communication
                P1623 - 35-10 - - - Intermittent
    Address 08     -------------------------------------------------------
       Controller: 4B0 820 043 AD
       Component: A6-Klimavoll
       Note: Excessive Comm Errors
    Skipping Address 15-Airbags
    Address 17     -------------------------------------------------------
       Controller: 4B0 920 933 G
       Component: KOMBI+WEGFAHRS. VDO D07
       Coding: 00060
       Shop #: WSC 00160
       WAUZZZ4B42N008845     AUZ7Z0A1872260
    1 Fault Found:
    01314 - Engine Control Module
    Address 35     -------------------------------------------------------
       Controller: 4B0 962 258 D
       Component: Zentralverriegelung D34
       Coding: 06721
       Shop #: WSC 02325
    7 Faults Found:
    01366 - Opened Due to Crash Signal
                35-00 - -
    01570 - Turn-Off Delay: Terminal 15
                29-10 - Short to Ground - Intermittent
    01559 - Drivers Door
                58-00 - Can't Lock
    01562 - Right Rear Door
                59-10 - Can't Unlock - Intermittent
    01560 - Passenger Door
                60-00 - Won't Safe
                60-00 - Won't Safe
                61-10 - Won't De-Safe - Intermittent
    Address 37     -------------------------------------------------------
       Controller: 4B0 919 887 D
       Component: BNS 4.1 H05    BNO 0005
    No fault code found.
    Address 56     -------------------------------------------------------
       Controller: 5B0 J35 195 H
       Component: symphony II NP2    0005
       Coding: 00211
       Shop #: WSC 02325
    End   -------------------------------------------------------
