Dziwny log ze smarta - WDC WD6400BEVT-60A0RT0
rob_za 13 Cze 2011 07:50 1556 0
  • #1
    rob_za
    Panowie rzućcie okiem i spróbujcie mi wyjaśnić co mogło być przyczyną dziwnych logów z dysku. Dysk pracuje w seryjnym laptopie, żadnego overclockingu. Log poniżej:
    smartctl 5.40 2010-10-16 r3189 [i486-pc-linux-gnu] (local build)
    Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net
    === START OF INFORMATION SECTION ===
    Model Family: Western Digital Scorpio Blue Serial ATA family
    Device Model: WDC WD6400BEVT-60A0RT0
    Serial Number: WD-WXF1A2039018
    Firmware Version: 01.01A01
    User Capacity: 640,135,028,736 bytes
    Device is: In smartctl database [for details use: -P show]
    ATA Version is: 8
    ATA Standard is: Exact ATA specification draft version not indicated
    Local Time is: Fri Jun 10 11:13:34 2011 UTC
    SMART support is: Available - device has SMART capability.
    SMART support is: Enabled
    === START OF READ SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    General SMART Values:
    Offline data collection status: (0x00) Offline data collection activity
    was never started.
    Auto Offline Data Collection: Disabled.
    Self-test execution status: ( 0) The previous self-test routine completed
    without error or no self-test has ever
    been run.
    Total time to complete Offline
    data collection: (16380) seconds.
    capabilities: (0x51) SMART execute Offline immediate.
    No Auto Offline data collection support.
    Suspend Offline collection upon new
    command.
    No Offline surface scan supported.
    Self-test supported.
    No Conveyance Self-test supported.
    Selective Self-test supported.
    SMART capabilities: (0x0003) Saves SMART data before entering
    power-saving mode.
    Supports SMART auto save timer.
    Error logging capability: (0x01) Error logging supported.
    General Purpose Logging supported.
    Short self-test routine
    recommended polling time: ( 2) minutes.
    Extended self-test routine
    recommended polling time: ( 190) minutes.
    SCT capabilities: (0x703f) SCT Status supported.
    SCT Error Recovery Control supported.
    SCT Feature Control supported.
    SCT Data Table supported.
    SMART Attributes Data Structure revision number: 16
    Vendor Specific SMART Attributes with Thresholds:
    ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
    1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 938
    3 Spin_Up_Time 0x0027 160 153 021 Pre-fail Always - 2958
    4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 318
    5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
    7 Seek_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
    9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 937
    10 Spin_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0
    11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
    12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 282
    183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
    187 Reported_Uncorrect 0x0032 100 001 000 Old_age Always - 743
    188 Command_Timeout 0x0032 100 001 000 Old_age Always - 408
    190 Airflow_Temperature_Cel 0x0022 067 044 040 Old_age Always - 33 (Min/Max 27/44)
    191 G-Sense_Error_Rate 0x0032 036 036 000 Old_age Always - 64
    192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 18
    193 Load_Cycle_Count 0x0032 181 181 000 Old_age Always - 57807
    194 Temperature_Celsius 0x0022 114 091 000 Old_age Always - 33
    196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
    197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
    198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
    199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
    200 Multi_Zone_Error_Rate 0x0009 200 200 051 Pre-fail Offline - 0
    SMART Error Log Version: 1
    No Errors Logged
    SMART Self-test log structure revision number 1
    Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
    # 1 Extended offline Completed without error 00% 936 -
    # 2 Extended offline Completed without error 00% 933 -
    # 3 Extended offline Completed without error 00% 930 -
    # 4 Short offline Completed without error 00% 927 -
    # 5 Short offline Completed without error 00% 927 -
    # 6 Short offline Completed: read failure 90% 881 888936
    # 7 Short offline Completed: read failure 90% 880 888936
    # 8 Extended offline Completed: read failure 90% 880 888936
    SMART Selective self-test log data structure revision number 1
    SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
    Selective self-test flags (0x0):
    After scanning selected spans, do NOT read-scan remainder of disk.
    If Selective self-test is pending on power-up, resume after 0 minute delay.
