Licznik na fisie ;
32-pin, niebieska kostka
1 -Terminal 15
2 -Wear of brake pads
3 -Speedometer output 1
4 -not used
5 -Fuel gauge sender
6 -Fuel gauge warning OBD 2
7 -Terminal 31 (sensor earth)
8 -Coolant temperature
9 -Terminal 31 (load earth)
10 -Oil pressure 2 (high)
11 -Engine-speed signal
12 -Air conditioner shutoff
13 -Electronic throttle/ pre-glow control
14 -Self-levelling suspension
15 -Terminal 58d
16 -Trailer turn signal
17 -Main beam
18 -Left turn signal
19 -not used
20 -Terminal 58s
21 -Door contact, driver's side
22 -Low coolant level
23 -Terminal 30
24 -Terminal 31 (load earth)
25 -Consumption signal
26 -Right parking light
27 -Left parking light
28 -Speedometer input
29 -Brake
30 -S-contact
31 -Speedometer output 2
32 -ESP
32-pin, zielona kostka
1 -Door contact (all doors)
2 -Transponder 1
3 -not used
4 -not used
5 -W wire
6 -Tailgate
7 -Right turn signal
8 -External buzzer
9 -External gong
10 -Airbag
11 -Service life output
12 -Terminal 61
13 -Parking brake
14 -CHECK
15 -Oil level / temperature
16 -not used
17 -Transponder 2
18 -CAN high speed (drive) (high +)
19 -CAN high speed (drive) (low -)
20 -CAN high speed (drive) (screen)
21 -ABS
22 -CAN low speed (Convenience) (high +)
23 -CAN low speed (Convenience) (low -)
24 -CAN low speed (Convenience) (screen)
25 -Bonnet
26 -not used
27 -Belt buckle
28 -K wire
29 -Ambient temperature input
30 -not used
31 -Selection range
32 -not used
32-pin, szara kostka
1 -Switch menu guide (menu)
2 -Switch menu guide (out A)
3 -Switch menu guide (out B)
4 -Switch menu guide (Enter)
5 -CAN high speed Display (high +)
6 -CAN high speed Display (low -)
7 -CAN high speed Display (screen)
8 -Door contact, passenger side
9 -Door contact, rear right
10 -Door contact, rear left
11 -Enable
12 -Clock
13 -Data
14 -Brake light
15 -Washer fluid level
16 -Tail lights/dipped beams
17 -On-board computer, left
18 -On-board computer, right
19 -On-board computer reset
20 -not used
21 -not used
22 -not used
23 -Key branch 1 Navigation system
24 -Key branch 2 Navigation system
25 -Key branch Telematics
26 -not used
27 -not used
28 -not used
29 -not used
30 -not used
31 -not used
32 -not used
Dodano po 5 [minuty]: Jeśli piszesz prawdę i nie grzebałeś nic w liczniku to bardzo dziwi mnie ze tylko poprzez wskazówkę zrobił się taki problem,powiem tak nawet jeśli miałeś podłączony akumulator to niemożliwe żeby uszkodził się licznik podczas wyciagania lub montażu.
rozpiskę pinów masz powyżej.
