Volvo V70 kody błędów. Interpretacja opisu kodu błędu P 0245.
dariusz b 02 Gru 2011 14:20 5632 2
  • #1 10209212
    dariusz b
    Witam posiadam Volvo V 70 i mam problem z błędem P 0245, a konkretnie z opisem błędu nie mogę go zinterpretowac,proszę w miarę możliwości o wyczerpujące informacje z góry dziękuję i pozdrawiam.
  • #2 10209521
    autoas
    Google wie i na forum jest troszeczkę
  • #3 10209572
    czaderx
    wystarczy poszukac dobrze by bylo gdybys napisal cos wiecej co to za v70:
    Turbo/Super Charger Wastegate Solenoid "A" Low
    What does this mean?
    OBD Code P0245refers to
    The PCM monitors the supercharger (boost) bypass (SCB) solenoid circuit for an electrical failure. The test fails when the signal moves outside the minimum or maximum allowable calibrated parameters for a specified SCB solenoid duty cycle (100% or 0%) by PCM command.
    Symptoms
    Possible sumptoms of OBD code P0245
    - Engine Light ON (or Service Engine Soon Warning Light)
    Causes
    Possible causes of OBD code P0245
    - VPWR circuit open to SCB solenoid. - SCB solenoid circuit shorted to PWR GND or CHASSIS GND. - Damaged SCB solenoid. - SCB solenoid circuit open. - SCB solenoid circuit shorted to VPWR. - Damaged
    Possible Solutions
    Disconnect SCB solenoid. Connect test lamp to SCB solenoid harness connector. Cycle SCB driver in PCM by Output Test Mode. Test lamp cycle on and off - SCB solenoid is suspect. Test lamp always on - SCB signal short in harness or PCM. Test always off - SCB signal or VPWR open in harness or PCM.
