DIY drukarka 3d - THE Printrbot
Vantage87 17 Lut 2012 23:02 21675 12
  • DIY drukarka 3d - THE Printrbot
    Więcej zdjęć pod tym linkiem:
    Link
    Tym razem dodaję projekt wykonania własnej drukarki 3d THE Printrbot
    Pliki z częściami do wydrukowania (drukarka_3d.zip)
    Strona z projektem : Link
    Bezpośredni link do autora (pytania można zadawać po zarejestrowaniu): Link
    Info (english version)
    This is the real deal, no derivatives here. These are the real Printrbot in it's current version. I have a bunch of these printing all day, every day.... it works. It is expandable to larger widths and heights easier than any other reprap out there. Period. Its the most inexpensive bot out there being mass produced. And, its now yours to print, build, improve, change.... whatever you like. I can't wait to see what you do with it. I will post pics of all the various forms it takes, news, etc at printrbot.com
    Instructions
    Here is a very basic part list:
    PRINTED PARTS
    2 Bases
    1 X Motor
    1 X Idler
    1 X Carriage
    1 Xtruder Mount
    4 Y BarEnds
    2 Belt Clips
    1 Y Bearing Guide
    OTHER PRINTED PARTS
    2 Z Couplers
    2 Belt Pulleys
    1 Extruder/hot end assembly
    OTHER PARTS / HARDWARE
    4 heat bed clips
    6 smooth rods
    6 threaded rod
    10 bearings LM8UU’s
    1 power supply
    1 lasercut print bed
    1 heatbed with cable
    1 thermistor
    1 extruder power cable
    1 extruder thermistor cable
    1 micro SD CARD
    1 electronics package
    3.5 ft. of belt
    5 Nema 17 Motors
    8 zip ties
    2 1.25” springs
    2 fender washers
    1 5/16-18 1“ bolt
    6 608ZZ bearings
    4 1/4” washers
    4 6-32 1.25” bolts
    8 6-32 1” bolts
    4 6-32 .5” bolts
    4 6-32 .75” bolts
    16 6-32 nuts
    22 5/16” nuts
    2 M3 16mm bolts
    13 M3 8mm bolt
    DIY drukarka 3d - THE Printrbot DIY drukarka 3d - THE Printrbot
    • drukarka_3d.zip (1.07 MB) Musisz być zalogowany, aby pobrać ten załącznik.
    Vantage87
    Vantage87 napisał 10 postów o ocenie 3. Jest z nami od 2012 roku.
  • #2 10564333
    szymon122
    Ocena: 755
    Z góry przepraszam ta takie pytanie ale czym i jak to "klei" ?
  • #3 10564523
    slavo666
    Ocena: 387
    Głównie ABS w postaci zwojów 3mm, warstwa po warstwie. Włókno przechodzi przez dyszę i jest stapiane jak w pistoletach do klejenia na gorąco. Wpisz sobie na YouTube RepRap, to zobaczysz dokładnie, o co chodzi.
    W ogóle idea takich samoreplikujących się drukarek jest bardzo ciekawa. Sam od dłuższego czasu zabieram się za budowę RepRapa. Problem jest w tym, że na pierwszą sztukę najlepiej jest kupić zestaw części plastikowych, płytę grzejną i dyszę, co stanowi już spory koszt. A efekty są bardzo różne, trzeba poświęcić sporo wolnego czasu i z tego, co widziałem już w internecie, możliwości tego typu drukarek są adekwatne do ich ceny. To samo z zastosowaniem komercyjnym - głównie małe elementy, gdzie wysoka dokładność nie jest krytyczna czyli prototypy, elementy modelarskie, jakieś figurki. Większość po prostu składa RepRapa i sprzedaje części do następnych RepRap'ów, które sami wytworzyli. Dla mnie to trochę mało.
  • #5 10571357
    myrcioch
    Ocena: 5
    zackass1 napisał:
    Czy możliwe by było zastosowanie granulatu z tworzywa zamiast żyłki/drutu? Myślę, że granulat jest o wiele łatwiej kupić a co za tym idzie taniej.
    Wątpliwe, musiałby zostać w jakiś sposób rozwiązany problem dozowania.
    Drut jest podawany silnikiem krokowym, dzięki czemu dokładnie wiadomo jaka objętość przetopionego materiału trafi na stół.
  • #6 10588684
  • #7 10588891
    myrcioch
    Ocena: 5
    mil30pal napisał:
    Może ktoś ma foto takiej dyszy i grzałki która topi materiał.
    Poszukaj hasła "reprap extruder", np:
    Wade's extruder
  • #9 10758517
    kamilekaaaaa
    Ocena: 56
    Nie wiem czy da się odświeżyć ten temat, ale mam pytanie odnośnie dyszy. Skoro dysza ma średnicę 0,5mm i nakładanie warstwa po warstwie czy powierzchnia nie wygląda chropowato? Jaki program obsługuje taka drukarkę?
  • #10 10758634
    Freddy
    Ocena: 2809
    Kolego pokaż mi z łaski swojej Twoja pracę. Co tutaj przetłumaczyłeś ?
    Jak zauważyłeś, to dział DIY Zagranica i samo podanie linków, to nie jest nic !
    W takim stanie temat nadaje się jedynie do usunięcia.
  • #11 12355492
    powder-phun
    Ocena: 5
    mam pytanko: czy tym można drukować projekty wykonane w google sketch-up?
  • #12 12444091
    gregoorr
    Ocena: 34
    Polacy nie gęsi i swoją drukarkę też mają.
    Promujmy swoje pomysły.
    Link
    Mam nadzieję, że nie długo stanie taka u mnie w domu i nie będzie kosztowała tyle co mały samochód.
  • #13 13209556
    pawlik722
    Ocena: 356
    Po pierwsze to gdzie tu jest cos tłumaczu przetłumaczone.
    Po drugie mam pytanie do wszystkich innych userów czy znacie jakieś forum tematyczne lub bloga poświęconego właśnie drukarką 3d? Nurtuje mnie kilka zagadnień i muszę rozwiać wątpliwości. A najlepiej czerpać informację od ludzi którzy składają takie maszyny.
    I mam takie pytanie ogólne, jaką temperaturę trzeba osiągnąć aby spoiwo się topiło ale i nie rozlewało i dało dokładnie taką ilość po wyjściu z dyszy jak była zamierzona?
    Czy nie występują problemy z "ciągnięciem" się materiału przy zmianie miejsca druku? Na filmikach w sieci tego w większości nie widać ale tam sa dopracowane maszyny, na pewno ma to związek z temperaturą grzałki, i kolenja jak na razie chyba dla mnie najważniejsza sprawa, czy grzałka 20W będzie wystarczająca i czy nie będzie zbytnio stygnąć podczas ciągłej pracy? Dyszę i grzałkę chce zrobić Sam.
✨ Dyskusja dotyczy budowy drukarki 3D THE Printrbot, która jest opisana jako łatwa do samodzielnego wydruku i rozbudowy. Uczestnicy poruszają kwestie dotyczące materiałów do druku, głównie ABS w postaci zwojów 3mm, oraz sposobu ich topnienia w dyszy. Pojawiają się pytania o możliwość użycia granulatu zamiast drutu, co wiąże się z problemem dozowania materiału. Użytkownicy dzielą się informacjami na temat komponentów, takich jak grzałki i dysze, oraz ich konstrukcji. Wspomniane są również wyzwania związane z jakością wydruków oraz temperaturą topnienia materiałów. Pojawiają się pytania o programy do obsługi drukarki oraz o dostępność zasobów edukacyjnych w tematyce druku 3D.
