Znalazłem na elektrodzie poniższy kod:
Kod dotyczy wykrywacza metalu wg zestawu AVT-2025, został on przerobiony na ATMega8. Bascom w linijce konfiguracji Timer-ów wyrzuca błędy.
Mam pytanie czy ktoś próbował uruchomić wykrywacz z wykorzystaniem powyższego kodu?
$regfile = "m8def.DAT"
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Portc.0 , Db5 = Portc.1 , Db6 = Portc.2 , Db7 = Portc.3 , E = Portc.4 , Rs = Portc.5
Config Portd.0 = Input
Config Portd.1 = Input
Config Portd.2 = Input
Config Portd.3 = Input
Config Portd.5 = Input
Config Portb.4 = Output
Cursor Off
Config Timer1 = Timer , Gate = External , Mode = 1 'tu mi wywala bład w bascomie
Config Timer0 = Counter , Gate = Internal , Mode = 1 'tu mi wywala bład w bascomie
Dim Temp As Byte
Dim R As Byte
Dim Freq_compare As Word
Dim Metal_type As Bit
Dim Freq As Word
Dim Dif As Word
Dim Temp2 As Byte
Dim Prescale As Byte
Dim Flag1 As Bit
Dim X As Word
Declare Sub Loop1
Dim Display_type_flag As Bit
Dim Counts As Byte
S1 Alias Portd.1
S5 Alias Portd.0
S3 Alias Portd.2
S4 Alias Portd.5
S6 Alias Portd.3
Pipek Alias Portb.4
On Timer1 Frequency
Deflcdchar 0 , 4 , 14 , 31 , 31 , 31 , 31 , 31 , 31 ' replace ? with number (0-7)
Cls
Deflcdchar 1 , 31 , 31 , 31 , 31 , 31 , 31 , 14 , 4 ' replace ? with number (0-7)
Cls
Lcd " AVT - 5025"
Wait 1
Cls
Lcd " METAL DETECTOR"
Wait 1
Enable Interrupts
Enable Timer0
Enable Timer1
Start Timer0
Start Timer1
Prescale = 1
Display_type_flag = 1
Loop1
Counts = 7
Sub Loop1
Freq_compare = Freq
Dif = 0
Do
Loop
End Sub
Frequency:
Flag1 = 1
Counter1 = 4150
Start Timer1
Incr Temp
If Temp = Counts Then
Temp = 0
Stop Timer0
Stop Timer1
Freq = Counter0
Counter0 = 0
Set S1
If S1 = 0 Then
Cls
Lcd "RESET"
Waitms 255
Freq_compare = Freq
Dif = 0
Flag1 = 0
End If
Set S4
If S4 = 0 Then
Prescale = 10
Cls
Lcd "SENSITIVITY LOW"
Counts = 7
Flag1 = 0
Waitms 255
Cls
End If
Set S5
If S5 = 0 Then
Prescale = 5
Cls
Lcd "SENSITIVITY MID"
Counts = 7
Waitms 255
Cls
End If
Set S6
If S6 = 0 Then
Prescale = 1
Cls
Lcd "SENSITIVITY HIGH"
Counts = 7
Waitms 255
Cls
End If
Set S3
If S3 = 0 Then
Display_type_flag = 0
Cls
Lcd " FREQUENCY"
Counts = 15
Waitms 255
End If
If Display_type_flag = 1 Then
If Freq_compare > Freq Then
Dif = Freq_compare - Freq
Metal_type = 1
End If
If Freq_compare < Freq Then
Dif = Freq - Freq_compare
Metal_type = 0
End If
Temp2 = Dif / Prescale
If Temp2 > 16 Then Temp2 = 16
If Dif > 1 And Flag1 = 1 Then
Cls
For R = 1 To Temp2
If Metal_type = 1 Then Lcd Chr(0);
If Metal_type = 0 Then Lcd Chr(1);
Sound P1.0 , 100 , 100
Next Temp2
Else
Cls
Lcd " NO METAL!"
End If
Else
Cls
Locate 1 , 4
Lcd Freq ; " Hz"
End If
Start Timer1
Start Timer0
End If
Return
