Passat B5 FL 2001 po wymianie skrzyni z automata na biegówke.
iktorn200 27 Cze 2012 17:21 3045 0
  • #1 11048037
    iktorn200
    Witam wszystkich.
    Mam problem z passatem 2001, poświetla się pasek z biegami na fisie, próbowałem zmienić kodowanie w can(19) z 00006 na 00004, ale bez powodzenia.
    Wynik skanowania;
    Wednesday,27,June,2012,16:07:40:10074
    VCDS Version: Beta 11.3.0
    Data version: 20110801
    Chassis Type: 3B - VW Passat B5
    Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
    VIN: WVWZZZ3BZ1P266708 Mileage: 192000km/119303miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 DS
    Component: 1,9l R4 EDC G000AG 1348
    Coding: 00001
    Shop #: WSC 00028
    VCID: 6BD1C39F36A1
    WVWZZZ3BZ1P266708 VWZ7Z0A3542506
    No fault code found.
    Readiness: 0 0 X X X
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 3B0 927 156 S
    Component: AG5 01V 1.9l-PD RdW 1416
    Coding: 00103
    Shop #: WSC 00028
    VCID: 366722EB3D63
    3 Faults Found:
    18171 - Shift Lock Solenoid (N110): Open Circuit
    P1763 - 35-00 - -
    17090 - Transmission Range Sensor (F125): Implausible Signal
    P0706 - 35-00 - -
    17094 - Transmission Fluid Temp Sensor (G93): Malfunction
    P0710 - 35-00 - -
    Address 03: ABS Brakes Labels: 8D0-907-389.lbl
    Part No: 8D0 907 389 D
    Component: ABS/ESP front D56
    Coding: 04257
    Shop #: WSC 00028
    VCID: 346318E32B1F
    1 Fault Found:
    01119 - Gear Recognition Signal
    35-00 - -
    Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
    Part No: 3B1 907 044 H
    Component: CLIMATRONIC B5GP 0003
    Coding: 17000
    Shop #: WSC 00028
    VCID: 2647F2ABEDC3
    3 Faults Found:
    00787 - Temperature Sensor in Fresh Air intake duct (G89)
    30-10 - Open or Short to Plus - Intermittent
    01273 - Fresh Air Blower (V2)
    35-10 - - - Intermittent
    00792 - A/C Pressure Switch (F129)
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 6Q0 909 605 B
    Component: 0A AIRBAG VW5 04 0006
    Coding: 12353
    Shop #: WSC 00028
    VCID: 366722EB3D63
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
    Part No: 1J0 907 487 B
    Component: Lenkradelektronik 0002
    Coding: 00008
    Shop #: WSC 00028
    VCID: 306B14F3DF07
    Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
    Part No: 3B0 920 845 A
    Component: KOMBI+WEGFAHRSP VDO V13
    Coding: 21125
    Shop #: WSC 19411
    VCID: 224FEEBB81EB
    WVWZZZ3BZ1P2660000 VWZ7Z0A3542506
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 00028
    VCID: F0EB54F39F87
    Z góry dziękuję za pomoc.
