Viewsonic VA2226W - zbita matryca MT220WW01 V.2 - jaki zamiennik
piezzzzz 13 Sie 2012 12:46 2232 3
  • #1 11203786
    piezzzzz
    Monitor Viewsonic VA2226W , model matrycy InnoLux MT220WW01 V.2
    AM2200001 201
    jakie ewentualnie zamienniki do tego monitora?
    znalazłem taką na allegro ale nie wiem czy będzie pasować:
    model matrycy z allegro :LTM220M1-L01 22''
    Z góry dziękuje za odpowiedź.
  • #3 11204265
    piezzzzz
    Mam tylko schemat do MT220WW01 V.0 , u mnie matryca V.2 będzie jakaś różnica w podstawowych parametrach?
    MT220WW01 V.0
    General Specyfication
    Display Resolution (pixel) : 1,680(H) X R.G.B X 1050(V), WSXGA+
    Active area (mm) : 473.76(H) X 296.1(V)
    Pixel pitch (mm): 0.282(H) x 0.282(V)
    Color Configuration: R,G,B, vertical stripe
    Overall dimension (mm) 493.7(W) x 320.1(H) x 16.5 (D) typ
    Surface treatment Anti-glare, Haze = 25%, Hard coating (3H)
    Input color signal 8-bit LVDS
    Display colors 16,7M (6 bit with Hi-FRC)
    Power voltage: -0.3V Min, 6V Max
    Input signal voltage: -0.3V Min, 4.3V Max
    Electrical characteristics:
    Input Voltage: 4.5V- Min, 5V Typ, 5.5V Max
    Input Current Black: 1000mA Typ
    Input Current White 800mA Typ
    Input Current Mosaic 900mA Typ
    Treshold Voltage Low -High -100mV (L) +100mV (H)
    Differential Input Voltage 100-600mV (Min-Max)
    Common Mode Voltage 1.2V
    LTM220M1-L01
    Number of Pixels: 1680x1050
    Active Display Area : 473.76(H) X 296.1(V)
    Pixel pitch : 0.282(H) x 0.282(V)
    Pixel Arrngement RGB vertical stripe
    Module size: 493.7 (W) x 320.1 (H) x 17(D) - max
    Surface Treatment Haze 25%, Hard-coating (3H)
    Input color signal: b/d
    Display Colors : 16,7M
    Power Supply Voltage GND-0.5V Min, 6.5V Max
    Data signal - Min, 5V - Max
    Voltage od Power Supply: 4.5V Min, 5V- Typ, 5.5V Max
    Current of Power Supply Black 1000mA Typ
    Current of Power Supply White 800mA Typ
    Current of Power Supply Dot 1100mA Typ, 1500mA Max
    Differential Input Voltage 200-600mV (Min-Max)
    Vsync 56 -60 -76 Hz (Min-Typ-Max)
    Hsync 59.3-64.8-75 kHz (Min-Typ-Max)
    Main Frequency 56-59.6-72 MHz (Min-Typ-Max)
    W obu takie same
    Złącza Pin:
    MT220WW01 V.0
    PIN 24: GND
    PIN 25: GND
    PIN 26: NC - No Connection
    PIN 27: GND
    PINY28-30 Vcc - 5V
    LTM220M1-L01
    PIN 24: GND
    PIN 25: NC *CE (Fr LCD internal use only. Do not connect)
    PIN 26: NC *CTL (Fr LCD internal use only. Do not connect)
    PIN 27: NC - No Cnnection
    PINY28-30 Vcc - 5V
    Objaśnienie * If the system already uses the 25, 26 pins , it should keep under GND level The voltage applied to those pins should not excee -200mV
    Czy będzie LTM220M1-L01 kompatybilna z MT220WW01 V.2
    Czy na coś jeszcze zwrócić uwagę ?
  • #4 11233281
    piezzzzz
    Matryce są kompatybilne. Po włożeniu zamówionej z allegro wszystko ładnie chodzi.
    Może się komuś taka informacja przyda.
    Zamykam temat
