Program dxdiag. dużo powie lub
ftp://ftp.microsoft.com/Services/whql/Tools/NSTL/000316/HCT/Device/Monitor/i386/edidw2k.exe
Monitor
Model name............... DELL SE198WFP
Windows description...... Dell SE198WFP DELL SE198WFP
Manufacturer............. Dell
Plug and Play ID......... DELF003
Serial number............ C558H8610C1M
Manufacture date......... 2008, ISO week 23
Filter driver............ None
EDID revision............ 1.3
Input signal type........ Analog 0.700,0.000 (0.7V p-p)
Sync input support....... Separate
Display type............. RGB color
Screen size.............. 410 x 260 mm (19.1 in)
Power management......... Standby, Suspend, Active off/sleep
Extension blocs.......... None
DDC/CI................... n/a
Color characteristics
Default color space...... sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.336
Green chromaticity....... Gx 0.293 - Gy 0.599
Blue chromaticity........ Bx 0.152 - By 0.068
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-83kHz
Vertical scan range...... 56-75Hz
Video bandwidth.......... 140MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1440x900p at 60Hz (16:10)
Modeline............... "1440x900" 106.500 1440 1520 1672 1904 900 903 909 934 -hsync +vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1440 x 900p at 60Hz - VESA STD
1152 x 864p at 75Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 75Hz - VESA STD
Report information
Date generated........... 2/17/2012
Software revision........ 2.60.0.972
Data source.............. Registry
Operating system......... 5.1.2600.2.Service Pack 3
Raw data
00,FF,FF,FF,FF,FF,FF,00,10,AC,03,F0,4D,31,43,30,17,12,01,03,68,29,1A,78,EE,C1,25,A3,56,4B,99,27,
11,50,54,BF,EF,80,95,00,71,4F,81,80,95,0F,01,01,01,01,01,01,01,01,9A,29,A0,D0,51,84,22,30,50,98,
36,00,98,FF,10,00,00,1C,00,00,00,FD,00,38,4B,1E,53,0E,00,0A,20,20,20,20,20,20,00,00,00,FF,00,43,
35,35,38,48,38,36,31,30,43,31,4D,0A,00,00,00,FC,00,44,45,4C,4C,20,53,45,31,39,38,57,46,50,00,2B
za min.
