To co wypluł:
# oct/04/2012 09:55:09 by RouterOS 5.11# software id = 1WAK-H2CW
/interface bridge
add admin-mac=00:0D:41:FA:99:F7 ageing-time=5m arp=enabled auto-mac=no \ disabled=no forward-delay=15s l2mtu=1520 max-message-age=20s mtu=1500 name=\ Lan priority=0x8000 protocol-mode=none transmit-hold-count=6
/interface ethernet
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\ no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:FA:99:F5 master-port=\ none mtu=1500 name=ether1-Wan speed=1Gbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\ no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:FA:99:F6 master-port=\ none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\ no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:FA:99:F7 master-port=\ none mtu=1500 name=ether3 speed=1Gbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\ no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:FA:99:F8 master-port=\ none mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited disabled=\ no full-duplex=yes l2mtu=1520 mac-address=00:0C:42:FA:99:F9 master-port=\ none mtu=1500 name=ether5 speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1 \ switch-all-ports=yes
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot \ http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap \ name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \ use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 \ status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m \ name=default pfs-group=modp1024
/ip pool
add name=dhcp_pool1 ranges=192.168.88.2-192.168.88.254
/ip dhcp-server
add address-pool=dhcp_pool1 authoritative=after-2sec-delay bootp-support=static \ disabled=no interface=Lan lease-time=3d name=dhcp1
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none \ stop-bits=1
/ppp profile
set default change-tcp-mss=yes name=default only-one=default use-compression=\ default use-encryption=default use-mpls=default use-vj-compression=default
set default-encryption change-tcp-mss=yes name=default-encryption only-one=\ default use-compression=default use-encryption=yes use-mpls=default \ use-vj-compression=default
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=\ 5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 \ red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set only-hardware-queue kind=none name=only-hardware-queue
set multi-queue-ethernet-default kind=mq-pfifo mq-pfifo-limit=50 name=\ multi-queue-ethernet-default
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no \ ignore-as-path-len=no name=default out-filter="" redistribute-connected=no \ redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no \ redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default disabled=no distribute-default=never in-filter=ospf-in metric-bgp=\ auto metric-connected=20 metric-default=1 metric-other-ospf=auto \ metric-rip=20 metric-static=20 name=default out-filter=ospf-out \ redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \ redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 disabled=no instance=default name=backbone type=\ default
/snmp
set contact="" enabled=no engine-id="" location="" trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" \ authentication-protocol=MD5 encryption-password="" encryption-protocol=DES \ name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 \ disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0 \ syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet \ boot-protocol=bootp cpu-frequency=680MHz enable-jumper-reset=yes \ enter-setup-on=any-key force-backup-booter=no silent-boot=no
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,web\
,sniff,sensitive,api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pass\
word,web,sniff,sensitive,api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,wi\
nbox,password,web,sniff,sensitive,api" skin=default
/interface bridge port
add bridge=Lan disabled=no edge=auto external-fdb=auto horizon=none interface=\ ether2 path-cost=10 point-to-point=auto priority=0x80
add bridge=Lan disabled=no edge=auto external-fdb=auto horizon=none interface=\ ether3 path-cost=10 point-to-point=auto priority=0x80
add bridge=Lan disabled=no edge=auto external-fdb=auto horizon=none interface=\ ether4 path-cost=10 point-to-point=auto priority=0x80
add bridge=Lan disabled=no edge=auto external-fdb=auto horizon=none interface=\ ether5 path-cost=10 point-to-point=auto priority=0x80
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
/interface ethernet switch port
set ether1-Wan vlan-header=leave-as-is vlan-mode=fallback
set ether2 vlan-header=leave-as-is vlan-mode=fallback
set ether3 vlan-header=leave-as-is vlan-mode=fallback
set ether4 vlan-header=leave-as-is vlan-mode=fallback
set ether5 vlan-header=leave-as-is vlan-mode=fallback
set switch1_cpu vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption \ enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=\ default enabled=no keepalive-timeout=60 mac-address=FE:A7:E9:93:5A:A8 \ max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=\ no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=\ default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=\ disabled port=443 verify-client-certificate=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
/ip address
add address=192.168.88.1/24 disabled=no interface=Lan network=192.168.88.0
/ip dhcp-client
add default-route-distance=0 disabled=no interface=ether1-Wan/ip dhcp-server config
set store-leases-disk=5m
/ip dhcp-server lease
add address=192.168.88.200 client-id=1:5c:26:a:43:73:2e comment=\ "Daniel D Laptop" disabled=no mac-address=5C:26:0A:43:73:2E server=dhcp1
/ip dhcp-server network
add address=192.168.88.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.88.1
/ip dns
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB \ max-udp-packet-size=512 servers=62.179.1.63,62.179.1.62
/ip firewall connection tracking
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s \ tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=\ 10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \ tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s \ udp-stream-timeout=3m udp-timeout=10s
/ip firewall nat
add action=masquerade chain=srcnat disabled=no out-interface=ether1-Wan \ src-address=192.168.88.0/24
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1-Wan disabled=no
set ether2 disabled=no
set ether3 disabled=no
set ether4 disabled=no
set ether5 disabled=no
set Lan disabled=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 \ cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600 \ max-fresh-time=3d max-server-connections=600 parent-proxy=0.0.0.0 \ parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
/ip service
set telnet disabled=yes port=23
set ftp disabled=yes port=21
set www address=192.168.88.0/24 disabled=no port=80
set ssh disabled=yes port=22
set
www-ssl certificate=none disabled=yes port=443
set api disabled=yes port=8728
set winbox disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip ssh
set forwarding-enabled=no
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=\ 15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no \ lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 \ use-explicit-null=no
/port firmware
set directory=firmware
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1-Wan queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
/radius incoming
set accept=no port=3799
/routing bfd interface
set all disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m \ gateway-selection=no-gateway origination-interval=5s preferred-gateway=\ 0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 \ metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no \ redistribute-connected=no redistribute-ospf=no redistribute-static=no \ routing-table=main timeout-timer=3m update-timer=30s
/store
add disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
set time-zone-name=Europe/Warsaw
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start=\ "jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system health
set
/system identity
set name=MikroTik
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\ 0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=\ none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set address=0.0.0.0 from=<> password="" port=25 user=""
/tool graphing
set page-refresh=300 store-every=5min
/tool graphing interface
add allow-address=0.0.0.0/0 disabled=no interface=all store-on-disk=yes
/tool mac-server
set (unknown) disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=1000KiB file-name="" filter-stream=yes interface=all \ memory-limit=100KiB memory-scroll=yes only-headers=no streaming-enabled=no \ streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
I jeszcze jedno pytanie:
Czy podawanie MAC'ów jest niebezpiecze?
Często inni forumowicze je zamazują (Why?).
