Tańsze głośniki do auta pasujące do Rockford Fosgate T2652-S?
Urbixx 11 Lut 2013 19:28 933 0
  • #1 11920789
    Urbixx
    Witam !!!
    Szukam do kompletu jeszcze odpowiedników głośników Rockford Fosgate T2652-S
    Głośniki po prostu zwalają z nóg jakością w połączeniu z subem RF P2
    Lecz kosztują 1 000zł tyle co wydałem na skrzynie RF, teraz szukam czegoś tańszego do boków auta.
    Macie jakiś pomysł, żeby jakościowo pasował do RF T2652-S?
    Dane[ang]:
    6-1/2" Power Series Aluminum Component System
    Power Handling:
    Peak: 400 watts per set / 200 watts each side
    RMS: 200 watts per set / 100 watts each side
    Discrete Dual Clamp tweeter provides concentric clamping pressure around the perimeter of the mounting hole for easy installation
    Aluminum dome neo-tweeter with integral suspension
    Tweeter utilizes an integral suspension with a tuned chamber to optimize frequency response
    5% Tolerance high quality poly-capacitors and air-core inductors
    3 levels of tweeter attenuation
    Recessed tweeter mount uses standard 1-3/4" hole saw
    On-axis/off-axis tweeter configuration
    Positive Temperature Coefficient (PTC) allows tweeter protection with a bypass resistor for 100% run-time
    Carbon fiber & polypropylene injection molded cone
    Vertical Attach Surround Technique (VAST) significantly increases the speaker's effective radiating cone area without complicated installation issues resulting in up to 25% more effective radiating cone area
    Flex fit basket allows for variable adjustments to the mounting position
    External audiophile grade component crossover
    Billet machined aluminum Phase plug
    Butyl rubber surround
    Bi-amp on/off capability
    Speaker grilles and hardware included
    OEM Adapter plate included
    Frequency Response: 55 - 22,000 Hz
    Crossover Frequency: 3,000 Hz
    Free Air Resonance: 55 Hz
    Sensitivity: 89 dB
    Voice Coil Diameter: 1-1/5"
