zrobiłem tak jak pisałes. wskazówki wczoraj wieczorem dobrze działały. dzisiaj chce odpalić auto i wskazówki zaczeły sie ruszać we wszystkie strony i auto nawet nie chce krecic
co moze byc przyczyna ?
jak podłączyłem komputer do samochodu to jest taki bład:
ECU ISO Code: AB 86 16 19 B5
2013-01-14 10:55:18
CONNECTED TO:
FIAT PUNTO '99 1.2 8V
TRW MY97 Airbag (2F-I)
ECU ISO code: AB 86 16 19 B5
FIAT drawing number: 00 46 76 63 84
Software version: 3.8
Hardware version: 1.4
ECU programming date: 25-09-2054
READING ERROR CODES:
1: 14 - Passenger airbag exclusion switch
The Passenger/rear side Airbag Disable switch or circuit has a defect. Check it for opens, shorts and weak connections. MAKE SURE that the switch is returned to the position the vehicle operator expects it to be
FOLLOW THE AIRBAG DIAGNOSTICS SAFETY PRECAUTIONS!!
WARNING: Improper access to the Airbag circuitry may cause the Airbag(s) to deploy or malfunction later, which may result in serious injury or death.
DO NOT MEASURE OR CONNECT ANYTHING TO THE AIRBAG SIDE OF THE CIRCUITRY without consulting the appropriate service literature first. Do not work or place anything in the Airbag deployment area. Follow the local regulations concerning Airbag system repairs
The reason for this fault is Interference detected / Faulty signal
The current status of the fault is Intermittent
The error counter value is 2
2: 02 - ECU Supply Voltage
The code is set when the ECU Supply Voltage is out of the specified range longer than allowed.
Certain system clear this code at the next start after the voltage is OK.
Check the ECU supply circuit and ECU ground.
Check also:
- Alternator, diode pattern, battery, pole and cable condition, good ground connections between alternator, engine, chassis and battery negative pole.
The reason for this fault is Value too low
The current status of the fault is Present
The error counter value is 106
CLEARING STORED FAULT CODES...
1: 02 - ECU Supply Voltage
Check also:
