A tego próbowaleś
Selecting the Panel Display Language (for D158/D159)
To change the panel display language, it is necessary to register available languages in the User Tools.
Specify the settings according to the following procedure.
2. Installation
36
• You can select one of these languages (the default is English): Japanese, English, German, French,
Italian, Dutch, Swedish, Norwegian, Danish, Spanish, Finnish, Portuguese, Czech, Polish,
Hungarian, Simplified Chinese, Russian, Greek, Catalan, Turkish, or Brazilian Portuguese.
• You do not have to do this procedure if you use English. Do this procedure if you want to use a
different language.
1. Turn on the power switch of the machine.
2. Press the "User Tools/Counter" key.
3. Press "Administrator Tools" in "System Settings".
4. Press "Select Switchable Languages".
5. Using the language button displayed on the User Tools screen, select the required
language (this will then be selectable at any time with a toggle setting), and then press
"OK".
• Only languages available for the machine are displayed.
• At least one language must be selected.
6. Return to the User Tools menu, and then keep pressing the language button until the
language you want to select appears.
• The language selected in "Select Switchable Languages" becomes available for selection by
a toggle setting.
