witam,
mialem stluczke w wyniku czego wyrzucilo mi poduszke kierowcy i pasazera, pasy. wymienilem je na nowe i teraz szukam pomocy przy usunieciu bledow. po probie usuniecia pojawiaja sie ponownie.
zalaczam plik ktory teraz zrobilem bo sie jakies nowe bledy pojawily, a niektore niemam pojecia co oznaczaja.
jak rozszyftowac co jest nie tak i to wlasciwie zrobic, lub gdzie moge taka pomoc uzyskac.
Address 01: Engine Labels: 06A-906-019-AEH.LBL
Controller: 06A 906 019 BR
Component: 1.6l 2V/R4 SIMOS HS3319
Coding: 00031
Shop #: WSC 06441
VCID: 749B5FD357A3
1 Fault Found:
18017 - Crash Shut-Down Activated
P1609 - 29-00 - Short to Ground
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.LBL
Controller: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 00000
VCID: 3E0FBDFB296F
No fault code found.
Address 08: Auto HVAC Labels: 1M0-820-043.LBL
Controller: 1M0 820 043 C
Component: 1M-CLIMATRONIC X0604
Coding: 00040
Shop #: WSC 06441
VCID: 2237698BBDD7
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
VCDS-Lite
Self-Diagnosis Log
Saturday, 22 June 2013, 19:41:55:0
Page 2
VIN Number: License Plate:
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 6Q0 909 605 A
Component: 1G AIRBAG VW5 0004
Coding: 12615
Shop #: WSC 06441
VCID: 351DA2D71C59
10 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00595 - Crash Data Stored
35-00 - -
01214 - Crash Data for Belt Tensioner Stored
35-00 - -
00589 - Airbag Igniter 1; Passenger Side (N131)
32-10 - Resistance too High - Intermittent
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
33-10 - Resistance too Low - Intermittent
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00588 - Airbag Igniter; Driver Side (N95)
29-10 - Short to Ground - Intermittent
01217 - Side Airbag Igniter; Driver Side (N199)
Address 17: Instruments Labels: 1M0-920-xx2-17.LBL
Controller: 1M0 920 821 A
Component: S5-KOMBIINSTR. VDO V02
Coding: 04106
Shop #: WSC 00006
VCID: 253D7297ACF9
IMMO-IDENTNR: SEZ7Z0Y0582666
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 06441
VCID: F093D3C3A3BB
VCDS-Lite
Self-Diagnosis Log
Page 3
Address 46: Central Conv. Labels: 1J0-959-799.LBL
Controller: 1J0 959 799 AH
Component: 8N Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 06441
VCID: 847B8F138703
4 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror; Driver Side (Z4)
35-00 - -
00913 - Window Regulator Switch; Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
35-00 - -
End --------------------------------------------------------------------------------------------------
Coding: 00031
Shop #: WSC 06441
VCID: 749B5FD357A3
1 Fault Found:
Readiness: N/A
Coding: 03504
Shop #: WSC 00000
VCID: 3E0FBDFB296F
Coding: 00040
Shop #: WSC 06441
VCID: 2237698BBDD7
No Faults Found
VCDS-Lite
Self-Diagnosis Log
Page 2
Coding: 12615
Shop #: WSC 06441
VCID: 351DA2D71C59
10 Faults Found:
35-00 - -
35-00 - -
Coding: 04106
Shop #: WSC 00006
VCID: 253D7297ACF9
Coding: 00006
Shop #: WSC 06441
VCID: F093D3C3A3BB
VCDS-Lite
Self-Diagnosis Log
Page 3
Coding: 04097
Shop #: WSC 06441
VCID: 847B8F138703
4 Faults Found:
35-00 - -
35-00 - -
