Witam jak w temacie poszukuje skrzyni br do hifonics brutus bx 15 d2 może ktoś ma bądź jest w stanie obliczyć i zrobić, poniżej podaje parametry t/s
Średnica głosnika: 380 mm
Moc Max: 1400W
Dual 2-Ohm Illuminated DVC Subwooferr
Moc RMS: 700-Watts
Impedancja: 2 x 2 Ohm
Fs: 27,57 Hz
Qts: 0.48
Vas: 122,6 Liters
Xmax: 15mm
SPL: 97,84 dB @ 2.83v
Illuminated Brutus Speaker Cone
Huge 100z. Double-Stack Magnet Assembly
2.5-inch 4-Layer Hi-Temp Aluminum Voice-Coils
Woven Glass-Fiber Layered Composite Cone
Integrated One-Piece Spider- Tinsel Lead Design
White Chrome Steel Speaker Frame with Rubber Front Gasket
1" Tall NBR Reinforced Rubber Surround
Rubber Magnet Boot
Ported Nickel Plated Back-Plate for Heat Dispersion
Nickel Plated Push & Insert Terminals
Nomex Spider-Assembly
For Vented And Sealed Enclosure Designs
Moc Max: 1400W
Moc RMS: 700-Watts
Fs: 27,57 Hz
Qts: 0.48
Vas: 122,6 Liters
Xmax: 15mm
Rubber Magnet Boot
