AVR AT90s4433 - Saa1057 Limit frequency from 87.5 to 108
DJ_DOGGY 05 Wrz 2013 14:27 2499 5
  • #1 12704358
    DJ_DOGGY
    Sorry but i understand only english
    Here is the problem
    I have this Bascom program for control Saa1057 From a PDF
    But it has no frequency limits from 87.5 to 108 Mhz
    How to edit it to have this limits with no change display after push the UP and Down button when limits are reached.
    This code is tested and works 100% on Bascom 1.11.9.8
    Kod: text
    Zaloguj się, aby zobaczyć kod
    Thank to all that can help
    If Flash is full when someone can make it with limits I can easy change the 4433 with Atmega8 . They are pin compatible . Just need to change the .def file. I guess Atmega8 Is no problem to work at 4 Mhz crystal?
    Also i want to know how Setup = 49605 is converted to .... '&B1100000111000101 and how can i convert my own code , because i want to change some bits
  • #2 12705606
    M. S.
    Kod: text
    Setup = 49605 this is the same Setup = &B1100000111000101
    Write Setup = &B1100000111000101 and change bits.
  • #3 12705800
    DJ_DOGGY
    Thank you for the tip. Ill check it.
    But still cannot realize how these two are equal ?
    And &B1100000111000101 ?! Where is B declared? As word or Byte ..?
    P.S: Yes your tips are working good , the only thig is that between Then and Frequency it must have :
  • #5 12706358
    DJ_DOGGY
    I see now.....
    Ok the only thing is that with added tips from you the 4433 cannot fit all this to flash :)
    Shows me 100% but warning to overwrite . So the solve is to use the ATMEGA8
    Thank you and be cool man .
    P.S: Yep , I fit it on 4433 !!!! Just remove the first Welcome and SAA1057 PLL messages from the program !
    Yes!
