Search our partners
Canon Pixma IP 70 - Kody Błedów Potrzebne
cywia 11 Sep 2013 21:14 1533 1
  • #1
    cywia
    Level 14  
    Witam koledzy posiadacie moze kody błędów do drukarek przenośnych Pixma IP 70, 80,90 dziękuję za pomoc
    Kamery 3D Time of Flight - zastosowania w przemyśle. Darmowe szkolenie 16.12.2021r. g. 10.00 Zarejestruj się
  • #2
    leeart
    Level 34  
    2. LIST OF ERROR DISPLAY / INDICATION
    Errors are indicated by the LED, and warnings are displayed on the monitor of the computer connected to the printer.
    2.1 Operator Call Errors (by LED Blinking in Orange)
    Error Solution Remarks
    2 times No paper. Set the paper, and press the
    Resume/Cancel button.
    3 times Paper jam. Remove the jammed paper, and press
    the Resume/Cancel button.
    6 times The print head is not installed. Install the print head, and close the print
    head cover.
    7 times The print head is not installed
    properly. (EEPROM data of
    the print head is faulty.)
    Re-install the print head, or with the
    print head installed, turn the printer off
    and on.
    8 times Warning: The waste ink
    absorber becomes almost full
    (to approx. 95% of the
    maximum capacity).
    Pressing the Resume/Cancel button will
    exit the error, and enable printing.
    In repair servicing, replace the 4-item
    set of the drain pack ass’y (QL2-0194)
    and the 3 ink absorbers
    (QC1-1210/1211/1212) at the same
    time.
    The service call
    error, indicating the
    waste ink absorber
    is full, is likely to
    occur soon.
    9 times The black or color ink tank is
    not installed, or not installed
    properly.
    Install both the black and color ink
    tanks. If they are installed, reseat them
    properly.
    If the error persists
    after the ink tanks
    are seated properly,
    the ink tank sensor
    is likely to be
    faulty.
    10 times Low battery Charge the battery, or connect the AC
    adapter to resume printing.
    2.2 Service Call Errors (by LED Blinking in Orange and Green Alternately, or Lit
    in Orange)
    LED
    alternate blinking
    in orange and
    green
    Error Solution
    2 times Carriage error Replace the logic board ass’y*1, or the print unit.
    4 times Purge unit error Replace the print unit, or the door sensor board ass'y. If the
    guard sheet is not attached, attach the guard sheet, while
    referring to Service Information (QK-12E-0175)
    6 times Internal temperature
    error
    Replace the print unit.
    7 times Waste ink absorber full Replace the 4-item set of the drain pack ass’y (QL2-0194) and
    the 3 ink absorbers (QC1-1210/1211/1212) at the same time*2.
    8 times Print head temperature
    rise error
    Replace the print head, or the logic board ass’y*1.
    9 times EEPROM error Replace the logic board ass’y*1.
    Lights in orange RAM error Replace the logic board ass’y*1.
    *1: As the waste ink counter is reset when the logic board ass’y is replaced, also replace the 4-item set of the
    drain pack ass’y (QL2-0194) and the 3 ink absorbers (QC1-1210/1211/1212) at the same time.
    *2: The waste ink absorber full error occurs when either the main waste ink absorber (drain pack ass’y) or the
    borderless printing waste ink absorber (ink absorber) becomes full. For this reason, all the waste ink
    absorbers should be replaced at the same time.
