SAMSUNG HD160JJ - ocena stanu dysk twardego - padł
Jankesik 23 Paź 2013 18:37 1218 2
  • #1 23 Paź 2013 18:37
    Jankesik
    Otrzymałem dysk twardy do sprawdzenia i wydaje mi się że nadaje się tylko do wyrzucenie. Zamieszczam test oraz zdjęcia
    smartctl 5.41 2011-06-09 r3365 [i686-linux-3.2.6-pmagic] (local build)
    Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
    === START OF INFORMATION SECTION ===
    Model Family: SAMSUNG SpinPoint P80 SD
    Device Model: SAMSUNG HD160JJ
    Serial Number: 1373J1FL426895
    Firmware Version: ZM100-47
    User Capacity: 160,041,885,696 bytes [160 GB]
    Sector Size: 512 bytes logical/physical
    Device is: In smartctl database [for details use: -P show]
    ATA Version is: 7
    ATA Standard is: ATA/ATAPI-7 T13 1532D revision 4a
    Local Time is: Wed Oct 23 18:12:20 2013 UTC
    SMART support is: Available - device has SMART capability.
    SMART support is: Enabled
    === START OF READ SMART DATA SECTION ===
    SMART overall-health self-assessment test result: PASSED
    General SMART Values:
    Offline data collection status: (0x02) Offline data collection activity
    was completed without error.
    Auto Offline Data Collection: Disabled.
    Self-test execution status: ( 0) The previous self-test routine completed
    without error or no self-test has ever
    been run.
    Total time to complete Offline
    data collection: ( 3632) seconds.
    capabilities: (0x5b) SMART execute Offline immediate.
    Auto Offline data collection on/off support.
    Suspend Offline collection upon new
    command.
    Offline surface scan supported.
    Self-test supported.
    No Conveyance Self-test supported.
    Selective Self-test supported.
    SMART capabilities: (0x0003) Saves SMART data before entering
    power-saving mode.
    Supports SMART auto save timer.
    Error logging capability: (0x01) Error logging supported.
    General Purpose Logging supported.
    Short self-test routine
    recommended polling time: ( 1) minutes.
    Extended self-test routine
    recommended polling time: ( 60) minutes.
    SCT capabilities: (0x003f) SCT Status supported.
    SCT Error Recovery Control supported.
    SCT Feature Control supported.
    SCT Data Table supported.
    SMART Attributes Data Structure revision number: 16
    Vendor Specific SMART Attributes with Thresholds:
    ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
    1 Raw_Read_Error_Rate 0x000f 100 100 051 Pre-fail Always - 0
    3 Spin_Up_Time 0x0007 253 253 025 Pre-fail Always - 3264
    4 Start_Stop_Count 0x0032 087 087 000 Old_age Always - 13778
    5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 2
    7 Seek_Error_Rate 0x000f 253 253 051 Pre-fail Always - 0
    8 Seek_Time_Performance 0x0025 253 253 015 Pre-fail Offline - 0
    9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 19764
    10 Spin_Retry_Count 0x0033 253 253 051 Pre-fail Always - 0
    11 Calibration_Retry_Count 0x0012 253 100 000 Old_age Always - 0
    12 Power_Cycle_Count 0x0032 093 093 000 Old_age Always - 7588
    187 Reported_Uncorrect 0x0032 099 099 000 Old_age Always - 2
    190 Airflow_Temperature_Cel 0x0022 136 067 000 Old_age Always - 34
    194 Temperature_Celsius 0x0022 136 067 000 Old_age Always - 34
    195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 144811
    196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 2
    197 Current_Pending_Sector 0x0012 253 100 000 Old_age Always - 0
    198 Offline_Uncorrectable 0x0030 253 253 000 Old_age Offline - 0
    199 UDMA_CRC_Error_Count 0x003e 198 198 000 Old_age Always - 10627
    200 Multi_Zone_Error_Rate 0x000a 253 100 000 Old_age Always - 0
    201 Soft_Read_Error_Rate 0x000a 253 100 000 Old_age Always - 0
    202 Data_Address_Mark_Errs 0x0032 253 253 000 Old_age Always - 0
    SMART Error Log Version: 1
    No Errors Logged
    SMART Self-test log structure revision number 1
    Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
    # 1 Short offline Completed without error 00% 19764 -
    Note: selective self-test log revision number (0) not 1 implies that no selective self-test has ever been run
    SMART Selective self-test log data structure revision number 0
    Note: revision number not 1 implies that no selective self-test has ever been run
    SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
    1 0 0 Not_testing
    2 0 0 Not_testing
    3 0 0 Not_testing
    4 0 0 Not_testing
    5 0 0 Not_testing
    Selective self-test flags (0x0):
    After scanning selected spans, do NOT read-scan remainder of disk.
    If Selective self-test is pending on power-up, resume after 0 minute delay.
    SAMSUNG HD160JJ - ocena stanu dysk twardego - padł SAMSUNG HD160JJ - ocena stanu dysk twardego - padł
    0 2
  • #2 23 Paź 2013 19:27
    mati211p
    Sprawdź taśmę którą jest podłączony, oczywiście nie nadaje się na systemowy z racji 2 realokowanych sektorów, ale na mało ważne dane może jeszcze być.
    0
  • #3 23 Paź 2013 20:30
    Jankesik
    Dysk całkowicie padł. Nadaje się tylko do przeróbki na szlifierkę :D
    0
