witam jestem nowy na forum mam pytanie kupilem te glosniki
Specifications
150W RMS / 300W MAX Per Driver (50Hz – 5Khz Crossover Baffled Installation)
Frequency Response 40Hz – 5Khz
Sensitivity 92db @ 1w/m
Impedance – 4 Ohm
Tech-Two Poly Composite Cone
1″ Heavy Duty Aluminium Voice Coil
Heavy Gauge Steel Basket
Super High Density Oversize Ceramic Magnet
Aerospace Grade Rubber Surround Suspension
Optimised for High Performance Mid Bass
Can Function as Compact Enclosure Subwoofer*
UPC: 617529407311
*for advanced installers only
Whats in the box?…
1 x High Power 6.5″ Mid Bass Driver
Dimensions
Overall Pack Weight: 1290g
Product Weight: 1080g
Overall Diameter with Grilles: 165mm
Overall Diameter: 165mm
Mounting Hole Circle Diameter: 155mm
Front Protrusion From Mounting Plane: 8mm
Magnet Diameter: 105mm
Mounting Depth: 73mm
Installation Cutout Diameter: 148mm
i szukam zwrotnicy do nich czy moze byc taka
Zwrotnica głośnikowa trójdrożna 4 Ohm
Moc max.: 200 W
Punkt podziału częstotliwości: Fp 800/4,1 KHz
Nachylenie zbocza: 12 Db
z gory dziekuje
Specifications
Impedance – 4 Ohm
UPC: 617529407311
Whats in the box?…
Dimensions
Moc max.: 200 W
z gory dziekuje
