Ford Galaxy mk2 2000 1.9 tdi - Wykaz logów z VAG-COM 409.1
Flinek_X 20 Sie 2014 21:12 2463 1
  • #1 13893919
    Flinek_X
    Witam!
    Mam problem z moim Fordem Galaxy , podłączyłem pod Vaga i wyskoczyły mi następujące błędy. Pomoglibyście w ich rozszyfrowaniu? Dodam ,że auto gaśnie w czasie jazdy.
    Dziękuje z góry :)
    VAG-COM Version: Release 409.1-S
    Chassis Type: XX - All Long
    Scan: 01,11,21,31,41,51,61,71,02,12,22,32,42,52,62,72,03,13,23,43,53,63,73,14,24,34,44,54,64,05,15,25,35,45,55,65,75,06,16,26,36,46,56,66,76,07,17,27,37,47,57,67,77,08,18,28,38,48,58,68,78,09,19,29,39,49,59,69,0D,0E,1C,1D,1E,2D,2E,3E,4E,4F,5E,6E,7D,7E
    Address 01: Engine
    Controller: 038 906 019 BF
    Component: 1,9l R4 EDC G000SG 1088
    Coding: 00002
    Shop #: WSC 00021
    1 Fault Found:
    19463 - Camshaft Position Sensor (G40): No Signal
    P3007 - 35-00 - -
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 1J0 907 379 P
    Component: ABS 20 IE CAN 0001
    Coding: 12702
    Shop #: WSC 00788
    No fault code found.
    Skipping Address 15-Airbags
    Address 17: Instruments
    Controller: 7M5 920 800 E
    Component: KOMBIINSTRUMENT VDO V03
    Coding: 00111
    Shop #: WSC 44450
    1 Fault Found:
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    Address 08: Auto HVAC
    Controller: 7M5 907 049
    Component: Klimabetaetigung 0303
    Coding: 0000000
    Shop #: WSC 00000
    3 Faults Found:
    00631 - Communications/Connection AC <-> Motronic
    007 - Short to Ground
    01189 - Front Air Distribution Flap Motor (V145)
    009 - Open or Short to Ground
    01271 - Positioning Motor for Temperature Flap (V68)
    Address 09: Cent. Elect.
    Controller: 7M3 962 258 E
    Component: Multifunkt.Einheit 0001
    Coding: 00005
    Shop #: WSC 00022
    1 Fault Found:
    01379 - Interior Monitor Switch (E183)
    28-00 - Short to B+
    Address 19: CAN Gateway
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 00020
    1 Fault Found:
    End --------------------------------------------------------------------------------------------------
  • #2 13893995
    FORMAT4G
    Z numeru sterownika który był w pierwszym logu z danymi z silnika wynika błąd czujnika położenia wałka rozrządu . Pozostałe logi w temacie gaśnięcia silnika bez znaczenia . Możliwe uszkodzenia to : nieprawidłowe ustawienie rozrządu lub instalacja elektryczna .Sam czujnik za rzadko się uszkadza . I lepiej zamiast "logów" podawać numer silnika , rok produkcji , moc i numer błędu .
