[AUDI A6 4F0] - Montaż ZEWNĘTRZNYCH lusterek Fotochrom
kuczera15 21 Wrz 2014 20:46 2829 0
  • #1 13979693
    kuczera15
    Zabieram się do montażu lusterek fotochromowych do samochodu.
    Wewnętrzne lusterko dołożone i podłączone na dwa kable.
    Pozostało podłączenie sygnału ściemniania do lusterek zewnętrznych.
    Znalazłem opis na angielskiej stronie A4, jednakże nie mam pojęcia, gdzie szukać wtyczki:
    T27 A-PILLAR.
    Opis angielski:
    Making the electrical connections
    Note that this only applies if you're doing this the OEM aka. The correct way. If you're tapping in to the R/L sensor wires, just make sure you tap the right wires. The connections will slightly depend on the mirror you're installing. The 6-pin connection :
    Pin 1 = +12V, driver's side black fuse carrier, fuse 9, 5A
    Pin 2 = Ground
    Pin 3 = Signal from reverse gear, Central Electric control module in the trunk, Connector T32c - Pin 32
    Pin 4 = T27, Pin 7 in the A-pillar. Left side auto-dimming exterior mirror signal
    Pin 5 = T27, Pin 25 in the A-pillar. Right side auto-dimming exterior mirror signal
    Pin 6 = Signal from the interior light, larger 8-pin connector of the two connectors, Pin 6
    The only required connections are Pins 1 and 2. As of writing this I have only connected Pins 1, 2 and 6 and the mirror works fine. I still need to connect pin 3 once I figure out where it goes for the reverse signal. The exterior mirror connections are only required if you're also fitting auto-dimming exterior mirrors.
