Search our partners
CLEVO P150SE - Wysoka temperatura mostka północnego
megaman11 23 Nov 2014 22:53 2457 10
  • #1
    megaman11
    Level 13  
    Witam zaobserwowałem ostatnio bardzo wysoka temperatura mostka północnego laptop to clevo p150se po konserwacji brak poprawy wyniki z aida 64 temperatury bez obciążenia sprawdzane kilkoma programami
    Sensor Type CPU, HDD, ACPI, PCH, SNB
    Temperatures
    CPU 41 °C (106 °F)
    CPU Package 43 °C (109 °F)
    CPU IA Cores 43 °C (109 °F)
    CPU GT Cores 39 °C (102 °F)
    CPU #1 / Core #1 41 °C (106 °F)
    CPU #1 / Core #2 43 °C (109 °F)
    CPU #1 / Core #3 40 °C (104 °F)
    CPU #1 / Core #4 43 °C (109 °F)
    PCH Diode 67 °C (153 °F)
    SAMSUNG SSD 830 Series [ TRIAL VERSION ]
    Voltage Values
    CPU Core 1.017 V
    Battery 16.590 V
    Power Values
    CPU Package 4.90 W
    CPU IA Cores 1.22 W
    CPU GT Cores 0.23 W
    CPU Uncore 2.54 W
    DIMM 0.91 W
    temperatury w stresie 30 min gry w far cry 3 ultra
    Field Value
    Sensor Properties
    Temperatures
    CPU 62 °C (144 °F)
    CPU Package 63 °C (145 °F)
    CPU IA Cores 63 °C (145 °F)
    CPU GT Cores 56 °C (133 °F)
    CPU #1 / Core #1 59 °C (138 °F)
    CPU #1 / Core #2 63 °C (145 °F)
    CPU #1 / Core #3 60 °C (140 °F)
    CPU #1 / Core #4 62 °C (144 °F)
    PCH Diode 96 °C (205 °F)
    Voltage Values
    CPU Core 1.010 V
    Battery 16.588 V
    GPU Core 1.000 V
    Power Values
    CPU Package 28.55 W
    CPU IA Cores 16.33 W
    CPU GT Cores 3.75 W
    CPU Uncore 6.02 W
    DIMM 2.46 W
    Battery Charge Rate A
    Pozostale podzespoly
    Computer Type ACPI x64-based PC (Mobile)
    Operating System Microsoft Windows 7 Professional
    OS Service Pack [ TRIAL VERSION ]
    Internet Explorer 11.0.9600.16428 (IE 11.0)
    DirectX DirectX 11.1
    Computer Name USER-PC
    User Name User
    Logon Domain [ TRIAL VERSION ]
    Date / Time 2014-11-23 / 21:51
    Motherboard
    CPU Type Mobile QuadCore Intel Core i7-4700MQ, 3200 MHz (32 x 100)
    Motherboard Name Clevo P15SM
    Motherboard Chipset Intel Lynx Point HM87, Intel Haswell
    System Memory [ TRIAL VERSION ]
    DIMM1: Samsung M471B5173CB0-YK0 4 GB DDR3-1600 DDR3 SDRAM (11-11-11-28 @ 800 MHz) (10-10-10-27 @ 761 MHz) (9-9-9-24 @ 685 MHz) (8-8-8-22 @ 609 MHz) (7-7-7-19 @ 533 MHz) (6-6-6-16 @ 457 MHz) (5-5-5-14 @ 380 MHz)
    DIMM3: Samsung M471B5173CB0-YK0 [ TRIAL VERSION ]
    BIOS Type AMI (01/04/2014)
    Display
    Video Adapter Intel(R) HD Graphics 4600 (2112 MB)
    Video Adapter NVIDIA GeForce GTX 780M (4 GB)
    3D Accelerator Intel HD Graphics 4600
    Monitor LG Philips LP156WF1-TLF3 [15.6" LCD]
    Multimedia
    Audio Adapter Realtek ALC892 @ Intel Lynx Point PCH - High Definition Audio Controller [C-1]
    Storage
    IDE Controller Standard AHCI 1.0 Serial ATA Controller
    Disk Drive SAMSUNG SSD 830 Series ATA Device (SATA-III)
    SMART Hard Disks Status OK
    Partitions
    C: (NTFS) [ TRIAL VERSION ]
    Total Size [ TRIAL VERSION ]
    Input
    Keyboard HID Keyboard Device
    Keyboard Standard PS/2 Keyboard
    Mouse HID-compliant mouse
    Mouse PS/2 Compatible Mouse
    Network
    Primary IP Address [ TRIAL VERSION ]
    Primary MAC Address B8-76-3F-9E-9D-85
    Network Adapter Bluetooth Device (Personal Area Network)
    Network Adapter Killer Wireless-N 1202 (2.4GHz and 5GHz) (192. [ TRIAL VERSION ])
    Network Adapter Realtek PCIe GBE Family Controller
    Peripherals
    Printer Fax
    Printer Microsoft XPS Document Writer
    FireWire Controller Texas Instruments XIO2213A 1394b OHCI with 3-Port PHY (PHY: TI TSB81BA3)
    USB2 Controller Intel Lynx Point PCH - USB 2.0 EHCI Host Controller 1 [C-1]
    USB2 Controller Intel Lynx Point PCH - USB 2.0 EHCI Host Controller 2 [C-1]
    USB3 Controller Intel Lynx Point PCH - USB 3.0 xHCI Host Controller [C-1]
    USB Device Atheros AR3012 Bluetooth 4.0 + HS
    USB Device BisonCam, NB Pro
    USB Device Generic USB Hub
    USB Device TouchStrip Fingerprint Sensor (WBF advanced mode)
    USB Device USB Composite Device
    USB Device USB Input Device
    Battery Microsoft AC Adapter
    Battery Microsoft ACPI-Compliant Control Method Battery
    Battery Microsoft Composite Battery
    DMI
    DMI BIOS Vendor Prema Mod
    DMI BIOS Version 1.03.03PM v1.1
    DMI System Manufacturer Notebook
    DMI System Product P15SM
    DMI System Version Not Applicable
    DMI System Serial Number [ TRIAL VERSION ]
    DMI System UUID [ TRIAL VERSION ]
    DMI Motherboard Manufacturer Notebook
    DMI Motherboard Product P15SM
    DMI Motherboard Version Not Applicable
    DMI Motherboard Serial Number [ TRIAL VERSION ]
    DMI Chassis Manufacturer Notebook
    DMI Chassis Version N/A
    DMI Chassis Serial Number [ TRIAL VERSION ]
    DMI Chassis Asset Tag [ TRIAL VERSION ]
    DMI Chassis Type LapTop
  • Helpful post
    #2
    sk1977
    IT specialist
    Sprawdź czy rzeczywiście tyle jest (chociażby palcem :)) czy może tylko to błąd odczytu.
  • Helpful post
    #3
    Argennto_1
    Level 33  
    Mostek północny prawdopodobnie jest po 2 stronie płyty głównej i tam trzeba też przeprowadzić konserwację układu chłodzenia.
  • #4
    sk1977
    IT specialist
    Nawet jeśli nie jest chłodzony to i tak ok. 100*C to zdecydowanie za dużo.
    Ale to może być błąd odczytu przez program - sprawdź czy taka temperatura rzeczywiście występuje.
  • #5
    megaman11
    Level 13  
    Mostek jest z drugiej strony płyty pod klawiaturą podczas obciążenia mostek robi się naprawdę gorący więc ewidentnie coś jest nie tak jakieś pomysły
  • Helpful post
    #6
    sk1977
    IT specialist
    Nie zgubiłeś przypadkiem termopada?
  • #7
    megaman11
    Level 13  
    Witam założyłem nowy brak poprawy po rozkreceniu laptopa mostek był odsłonięty bez termopada
  • #8
    sk1977
    IT specialist
    Założyłeś dobry termopad?
    Chodzi o jakość i parametry (6W/mK lub więcej) oraz grubość - jak nie było termopada to trzeba eksperymentalnie dobrać.
    Przy 4 rdzeniach i SSD południe ma co robić - nie odpoczywa, wiec dobre chłodzenie jest jak najbardziej wskazane.
    Niewykluczone, że już zostało nadwyrężone i stąd dodatkowe (ponadnormatywne) grzanie się.
  • #9
    megaman11
    Level 13  
    Dziękuję za zaangażowanie kolego, ogólnie termopada ani jakiego kolwiek chłodzenie nie było fabrycznie
    Jakieś pomysły testy?
  • Helpful post
    #10
    lisek
    Service technician RTV
    Ta seria modeli Clevo , grzanie procesora tak ma > popatrz Link oraz Link
    Co do grzania HM77 niestety wskazane pomiary zasilania mostka. ( +3VS )
    - popatrz na SM laptopów z takim Norh
    - o ile pamiętam w org. jest tylko chłodzony procesor i grafika.
    - czy kwarc, chyba 25MHz pracuje na swojej częstotliwości
    - nie ma na ten czas SM ogólnie dostepnego (jak na Elvikom) > ale popatrz na ten chiński poniżej (tylko podgląd , nie mozna zassać)
    - Link
    Można posłużyc się "zbliżonym" np. Link
    (':!:') Popatrz na ten (tylko podgląd) Clevo P150EM , HM77 , i7 Link
    Firma Clevo to "druga półka laptopów" , ale ma ponad 35% udziału w spzredazy laptopów, robi własne płyty MB
    * CLEVO P150HM/P151HM (Sager NP8150) Motherboard, chipset HM65
    ______________
    Clevo P150HM GeForce GTX 580M
  • #11
    megaman11
    Level 13  
    Witam ponownie i dziękuję wszystkim za zainteresowanie cóż temperatura pch jest spowodowana brakiem dobrego chłodzenia po rozebraniu laptopa i zainstalowaniu radiatora temperatura spadła o 20 stopni niestety brak możliwości zainstalowania na stale z powodu ograniczonego miejsca.
