AMPLIFIER:
Output power: 2X32W RMS/6 Ohm/THD 10%
Power bandwidth: 40 - 20000 Hz
Ferqency response: 40 - 20000Hz
Signal-to-noise ratio: >67 dBA (IEC)
Stereo separation: >35 dB (IHF)
AUX:
Outputs: 400 mV
Loudspeakers: > 6 Ohm
Headphones: 32 - 1000 Ohm (5 Vemk - 120 Ohm)
TUNER:
FM wave range: 87 - 108 MHz
MW wave range: 522 - 1611 kHz
LW wave range: (not on all version) 153 - 279 kHz
Sensitivity at 75 Ohm
mono: 26 dB signal-to-noise ratio 4,3 uV
stereo: 46 dB signal-to-noise ratio 138 uV
Selectivity: > 24 dB
Total harmonic distortion: < 5%
Frequency response: 63 - 12,5 kHz (+/- 3 dB)
Signal-to-noise ratio: >50 dBA
CD PLAYER:
Frequency range: 40 - 20000 Hz
Signal-to-noise: >67 dBA
Channel separation: >35 dB
Total harmonic distortion: < 1%
Conversion: Bitstream
CASSETTE DECK:
Frequency range:
CrO2 tape (tape 2): 80 - 12500 Hz (+/- 5 dB)
Normal tape (tape 1): 80 - 12500 Hz (+/- 5 dB)
Signal-to-noise ratio (whitout Dolby NR):
CrO2 tape (tape 2): > 52 dBA
Normal tape (tape 1): > 52 dBA
Wow and flutter: < 0,4% DIN
WYMIARY: (W x H x D)
600 x 309,5 x 290,5 mm
