chrysler stratus jak zaprogramowac pilota lub wylaczyc imobilajzer
oldsmobile98 02 Lut 2015 00:39 1278 1
  • #1 14393553
    oldsmobile98
    Chrysler stratus podaje paliwo na gazie chdzi ale nie ma impulsu na wtryskiwaczach i nie zamyka i nie otwiera sie z pilota jak odlaczyc imobilajzer lub zaprogramowac go
  • #2 14393682
    ladamaniac
    Poziom 40  
    Metody dla rocznika 2002. Oczywiście sposób C odpada, z racji użycia testera fabrycznego.
    Program Method A (Customer Program Method)
    Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
    Turn ignition to run position. (Allow ignition chimes[UNLOCK] to stop).
    Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
    Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
    Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
    Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
    NOTE:(FOR DR ONLY) A CHIME WILL NOT SOUND ON STEP # 6 FOR THE FIRST TRANSMITTER PROGRAMMED, BUT WILL SOUND UPON PROGRAMMING THE SECOND TRANSMITTER.
    Repeat steps 5 through 6 to program additional transmitters.
    Turn ignition to OFF position. Transmitter programming mode v/ill discontinue after 60 seconds (30 seconds for AN/DN and RS). (All transmitter programming must be completed within time specified).
    Program Method B (Customer Program Method)
    Press [LOCK] button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming.
    Turn ignition to the run position (Allow ignition chimes to stop).
    Using original transmitter, press and hold the [UNLOCK] button on the transmitter for between 4 and 10 seconds.
    Continue to hold the [UNLOCK] button and press the [PANIC] button. A chime will sound to indicate that the transmitter programming mode has been entered (Allow 3 seconds for chime to sound).
    Press a button on all transmitters to be programmed into the system including any previously programmed transmitters; a chime will sound when each transmitter has been programmed.
    Turn the ignition to OFF position to exit the transmitter programming mode.
    Program Method C (Dealer Program Method) *Can be used for any type transmitter.
    Plug DRBIII to vehicle's 1-way data link connector.
    Follow Service Manual and DRBIII instructions to program transmitters.
    Program Method D (For use with AB vehicles not equipped with VTSS only)
    Locate the dark green program enable wire connected to pin # 1 of the 16-way data link connector under the left side of the instrument panel.
    Connect the program enable wire terminal to a good ground.
    Insert the key into the ignition and turn the ignition switch to the ON position. The power locks will cycle (Lock and Unlock) indicating that program mode has been entered.
    Using the transmitter to be programmed, press either [LOCK] or [UNLOCK]. The power locks will cycle indicating the transmitter has been programmed successfully.
    Repeat step 4 to program additional transmitter.
    Disconnect the program enable wire from ground to exit program mode.
    Turn the ignition to the OFF position and remove the key.
