ATX zasilacz 2011 - Czy mogę ustawić niższe napięcia dla oszczędności energii?
Fosucki_Czek 10 Mar 2015 04:51 1200 2
  • #1 14516197
    Fosucki_Czek
    I have a question about my 2011 ATX computer. Can I set lower voltages for the devices inside to save energy, having almost the same functionality? I am thinking about straight 3 volts, 4 volts and 11 volts. Will these makes it work for my devices? I have a typical HDD and Optical Drive.
    Are there a great risk to destroy any mechanisms inside? Does the devices have up step stabilisation easily to their nominal voltages?
    What do you think?
  • #2 14516282
    gregorianin
    For drives basically you can try lower voltages by 1-2V, some of them still work correctly but you won't get much energy save from this. Drives like HDD/SSD, optical drain small a part wattage of whole system. The main energy eater are CPU + GPU and that voltages you can't lower by changing main external power supply level since they have own regulators and core voltages in most cases won't reach even 1.5V
  • #3 14556212
    Sobota
    Probably better idea than lover voltage PSU is down-clocking CPU and down-clocking or modding bios of graphic card. You should remember that majority of power is emitted as a heat.
