Opel Astra 1,7 DTH 2005 - Jak naprawić błąd P0621 (obwód L lampy alternatora)?
Stanisław Chwalisz 16 Lip 2015 18:52 4443 7
  • #1 14853458
    Stanisław Chwalisz
    W/g opisu usterki to obwód sterujący L lampą alternatora, może ktoś wie jak z tym walczyć to znaczy jak to usunąć.Rok tego 2005.
    grala1
    Specjalista grupy V.A.G.
    Generic OBD Error Code Details for P0621
    Generator Lamp/L Terminal Circuit
    What does this mean?
    OBD Code P0621refers to
    The Engine Control Module (ECM) or Powertrain Control Module (PCM) uses the generator turn on signal circuit to control the load of the generator on the engine. A high side driver in the ECM/PCM applies a voltage to the voltage regulator. This signals the voltage regulator to turn the field circuit ON and OFF. The ECM/PCM monitors the state of the generator turn on signal circuit. The ECM/PCM should detect low voltage on generator turn on signal circuit when the ignition is ON and the engine is OFF, or when the charging system malfunctions. With the engine running, the ECM/PCM should detect high voltage on the generator turn on signal circuit. The ECM/PCM performs Ignition ON and RUN tests to determine the status of the generator turn on signal circuit.
    Symptoms
    Possible sumptoms of OBD code P0621
    - Engine Light ON (or Service Engine Soon Warning Light)
    Causes
    Possible causes of OBD code P0621
    - Generator circuit - Generator circuit short to fround - Generator circuit open/high Resistance - Generator circuit short to voltage - Bad generator/alternator - Faulty ECM/PCM The Error code is generally activated on detection of the following conditions: - During the Ignition ON test, the ECM/PCM detects high voltage on the generator turn on signal circuit for 5 seconds. - During the RUN test, the ECM/PCM detects low voltage on the generator turn on signal circuit for 15 seconds.
    Possible Solutions
    - Replaced alternator/generator
  • #3 14853928
    Oprysk Stonki
    Poziom 29  
    Regulator oryginał?
  • #4 14853954
    Stanisław Chwalisz
    Do dzisiaj napraw nie było,tylko olej i filtry. O wynikach mojej naprawy dam info.
  • #5 14853973
    Oprysk Stonki
    Poziom 29  
    Ale co się dzieje, świeci się helikopter bądź kontrolka ładowania? Bo jak nie, i poza tym nie ma problemu z ładowaniem to bym to olał ciepłym moczem. Połowa Vectr C 1,9 cdti wali ten błąd i nikt nie robi dymu.
  • #6 14854054
    Stanisław Chwalisz
    Efekt jest taki ; na potencjometrach pedału gazu napięcie za wysokie , dwa błędy
    trzeci błąd wyżej przytoczony. Silnik się uruchamia jednak po naciśnięciu na pedał gazu, zapala się, check,serwis i nie mamy pod nogą gazu silnik przechodzi w tryb awaryjny obroty silnika 1400/min na dojazd do serwisu.
  • #7 14854102
    Oprysk Stonki
    Poziom 29  
    Zostaw ten błąd terminala L, nie tam problem. Masz problem w układzie pedału przyspieszenia.
  • #8 14854185
    Stanisław Chwalisz
    Pedał przyśpieszenia wymieniony na nowy i dalej to samo. Dlatego drążę dalej
    temat.Pozostaje altek w najgorszym przypadku ECM.
