http://www.jungheinrich.se/betriebsanleitungen/50425855.pdf
poszukaj
str.27
Charging times
The time required for recharging depends
on the capacity
of the battery.
LED display
Fill-up charge
The fill-up charge begins aut
omatically after the rec
harge procedure has ended.
Partial recharging
The battery charger is designed in such a
way that it automatic
ally adapts to the
charging status of partially
recharged batteries. This permits
to reduce wear and tear
of the battery.
Green LED
(charging
status)
Red LED
(fault)
Indication
is lit --- Recharge procedure is
finished; battery is full.
(charging break,
fill-up charge or equ
alization charge)
flashes slowly --- Charging process
flashes fast --- Indicates the start of
a recharge procedure or that a
new charging curve was adj
usted. The number of
the flashing pulses corresponds to the adjusted
charging curve.
--- is lit Excess temperature. Re
charge process is interrupt-
ed.
--- flashes slowly Safety
charging interval ex
ceeded. Recharge proc-
ess is interrupted. Disconnection from the mains is
required for restarting
the charging process.
--- flashes fast charging curve setting is invalid.
--- --- Power failure and/o
r no battery connected.
