[Sprzedam] Anvyl Spartan-6 FPGA Trainer Board
elcapitano 24 Mar 2016 10:50 1191 0
  • #1 15551249
    elcapitano
    Sprzedam
    Sprzęt używany.
    Stan idealny.
    Data produkcji: grudzień 2014
    Cena: 1600 PLN (do niewielkiej negocjacji)
    Osoby zainteresowane proszę o kontakt pod nr tel. 609 416 020
    The Anvyl™ FPGA development platform is a complete, ready-to-use digital circuit development platform based on a speed grade -3 Xilinx® Spartan®-6 LX45 FPGA. The large FPGA, along with the 100-mbps Ethernet, HDMI Video, 128MB DDR2 memory, 4.3” LED backlit LCD touchscreen, 128x32 pixel OLED display, 630 tie-point breadboard, multiple USB HID controllers, and I2S audio codec makes the Anvyl an ideal platform for an FPGA learning station capable of supporting embedded processor designs based on Xilinx's MicroBlaze™.
    The Anvyl is compatible with all Xilinx CAD tools, including ChipScope™, EDK, and the free ISE® WebPACK™, so designs can be completed at no extra cost. The board dimensions are 27.5cm x 21cm.
    Features
    6,822 slices, each containing four input LUTs and eight flip-flops
    2.1Mbits of fast block RAM
    Four clock tiles (eight DCMs & four PLLs)
    58 DSP slices
    500MHz+ clock speeds
    128MB DDR2 SDRAM
    2MB SRAM
    16MB QSPI FLASH for configuration and data storage
    100 MHz Crystal Oscillator
    Ships with a 20W power supply and USB cable
    10/100 Ethernet PHY
    HDMI Video Output
    12-bit VGA port
    I2S Audio codec with line-in, line-out, mic, and headphone
    Digilent USB-JTAG circuitry with USB-UART function
    4.3" wide-format vivid color LED backlit LCD screen
    128x32 pixel 0.9" OLED graphic display panel
    Three two-digit seven-segment LED displays
    On-board USB2 ports for programming and USB-HID devices (for mouse/keyboard)
    Keypad with 16 labeled keys (0-F)
    GPIO: 14 LEDs (10 red, 2 yellow, 2 green), 8 slide switches, 8 DIP switches in 2 groups, and 4 push buttons
    Breadboard with 10 Digital I/Os
    32 I/Os routed to 40-pin expansion connector (I/Os are shared with Pmod connectors)
    Seven 12-pin Pmod connectors with 56 I/Os total
