Kompilator nie tworzy pliku .hex dla Atmega328p-PU - co robię źle?
fabjan1994 25 Mar 2016 16:47 1704 13
  • #1 15554853
    fabjan1994
    Witam chciałem zacząć przygodę z mikrokontrolerami i znalazłem stronę Link. Robię wszystko krok po kroku jak autor tam opisał niestety w momencie gdy dochodzę do "Kompilacja" Wciśniecie "Make All" faktycznie mi kompiluje bez problemów niestety w katalogu nie pojawiają się żadne pliki dodatkowy typu hex czy eep. Dodam że mój mikrokontroler to Atmega328p-PU
  • #2 15554862
    grko
    Poziom 33  
    Ocena: 141
    Pokaż co masz w Makefile oraz log kompilacji.
  • #3 15554873
  • #4 15554949
    fabjan1994
    Makefile
    Spoiler:
    # Hey Emacs, this is a -*- makefile -*-
    # WinAVR Makefile Template written by Eric B. Weddington, Jörg Wunsch, et al.
    # Released to the Public Domain
    # Additional material for this makefile was written by:
    # Peter Fleury
    # Tim Henigan
    # Colin O'Flynn
    # Reiner Patommel
    # Markus Pfaff
    # Sander Pool
    # Frederik Rouleau
    # Carlos Lamas
    # On command line:
    # make all = Make software.
    # make clean = Clean out built project files.
    # make coff = Convert ELF to AVR COFF.
    # make extcoff = Convert ELF to AVR Extended COFF.
    # make program = Download the hex file to the device, using avrdude.
    # Please customize the avrdude settings below first!
    # make debug = Start either simulavr or avarice as specified for debugging,
    # with avr-gdb or avr-insight as the front end for debugging.
    # make filename.s = Just compile filename.c into the assembler code only.
    # make filename.i = Create a preprocessed source file for use in submitting
    # bug reports to the GCC project.
    # To rebuild project do "make clean" then "make all".
    # MCU name
    MCU = atmega328P
    # Processor frequency.
    # This will define a symbol, F_CPU, in all source code files equal to the
    # processor frequency. You can then use this symbol in your source code to
    # calculate timings. Do NOT tack on a 'UL' at the end, this will be done
    # automatically to create a 32-bit value in your source code.
    # Typical values are:
    # F_CPU = 1000000
    # F_CPU = 1843200
    # F_CPU = 2000000
    # F_CPU = 3686400
    # F_CPU = 4000000
    # F_CPU = 7372800
    # F_CPU = 8000000
    # F_CPU = 11059200
    # F_CPU = 14745600
    # F_CPU = 16000000
    # F_CPU = 18432000
    # F_CPU = 20000000
    F_CPU = 8000000
    # Output format. (can be srec, ihex, binary)
    FORMAT = ihex
    # Target file name (without extension).
    TARGET = main
    # Object files directory
    # To put object files in current directory, use a dot (.), do NOT make
    # this an empty or blank macro!
    OBJDIR = .
    # List C source files here. (C dependencies are automatically generated.)
    SRC = $(TARGET).c
    # List C++ source files here. (C dependencies are automatically generated.)
    CPPSRC =
    # List Assembler source files here.
    # Make them always end in a capital .S. Files ending in a lowercase .s
    # will not be considered source files but generated files (assembler
    # output from the compiler), and will be deleted upon "make clean"!
    # Even though the DOS/Win* filesystem matches both .s and .S the same,
    # it will preserve the spelling of the filenames, and gcc itself does
    # care about how the name is spelled on its command-line.
    ASRC =
    # Optimization level, can be [0, 1, 2, 3, s].
    # 0 = turn off optimization. s = optimize for size.
    # (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
    OPT = s
    # Debugging format.
    # Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs.
    # AVR Studio 4.10 requires dwarf-2.
    # AVR [Extended] COFF format requires stabs, plus an avr-objcopy run.
    DEBUG = dwarf-2
    # List any extra directories to look for include files here.
    # Each directory must be seperated by a space.
    # Use forward slashes for directory separators.
    # For a directory that has spaces, enclose it in quotes.
    EXTRAINCDIRS =
    # Compiler flag to set the C Standard level.
    # c89 = "ANSI" C
    # gnu89 = c89 plus GCC extensions
    # c99 = ISO C99 standard (not yet fully implemented)
    # gnu99 = c99 plus GCC extensions
    CSTANDARD = -std=gnu99
    # Place -D or -U options here for C sources
    CDEFS = -DF_CPU=$(F_CPU)UL
    # Place -D or -U options here for ASM sources
    ADEFS = -DF_CPU=$(F_CPU)
    # Place -D or -U options here for C++ sources
    CPPDEFS = -DF_CPU=$(F_CPU)UL
    #CPPDEFS += -D__STDC_LIMIT_MACROS
    #CPPDEFS += -D__STDC_CONSTANT_MACROS
    #---------------- Compiler Options C ----------------
    # -g*: generate debugging information
    # -O*: optimization level
    # -f...: tuning, see GCC manual and avr-libc documentation
    # -Wall...: warning level
    # -Wa,...: tell GCC to pass this to the assembler.
    # -adhlns...: create assembler listing
    CFLAGS = -g$(DEBUG)
    CFLAGS += $(CDEFS)
    CFLAGS += -O$(OPT)
    CFLAGS += -funsigned-char
    CFLAGS += -funsigned-bitfields
    CFLAGS += -fpack-struct
    CFLAGS += -fshort-enums
    CFLAGS += -Wall
    CFLAGS += -Wstrict-prototypes
    #CFLAGS += -mshort-calls
    #CFLAGS += -fno-unit-at-a-time
    #CFLAGS += -Wundef
    #CFLAGS += -Wunreachable-code
    #CFLAGS += -Wsign-compare
    CFLAGS += -Wa,-adhlns=$(<:%.c=$(OBJDIR)/%.lst)
    CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
    CFLAGS += $(CSTANDARD)
    #---------------- Compiler Options C++ ----------------
    CPPFLAGS = -g$(DEBUG)
    CPPFLAGS += $(CPPDEFS)
    CPPFLAGS += -O$(OPT)
    CPPFLAGS += -funsigned-char
    CPPFLAGS += -funsigned-bitfields
    CPPFLAGS += -fpack-struct
    CPPFLAGS += -fshort-enums
    CPPFLAGS += -fno-exceptions
    CPPFLAGS += -Wall
    CPPFLAGS += -Wundef
    #CPPFLAGS += -mshort-calls
    #CPPFLAGS += -fno-unit-at-a-time
    #CPPFLAGS += -Wstrict-prototypes
    #CPPFLAGS += -Wunreachable-code
    #CPPFLAGS += -Wsign-compare
    CPPFLAGS += -Wa,-adhlns=$(<:%.cpp=$(OBJDIR)/%.lst)
    CPPFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
    #CPPFLAGS += $(CSTANDARD)
    #---------------- Assembler Options ----------------
    # -adhlns: create listing
    # -gstabs: have the assembler create line number information; note that
    # for use in COFF files, additional information about filenames
    # and function names needs to be present in the assembler source
    # files -- see avr-libc docs [FIXME: not yet described there]
    # -listing-cont-lines: Sets the maximum number of continuation lines of hex
    # dump that will be displayed for a given single line of source input.
    ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:%.S=$(OBJDIR)/%.lst),-gstabs,--listing-cont-lines=100
    #---------------- Library Options ----------------
    # Minimalistic printf version
    PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
    # Floating point printf version (requires MATH_LIB = -lm below)
    PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
    # If this is left blank, then it will use the Standard printf version.
    PRINTF_LIB =
    #PRINTF_LIB = $(PRINTF_LIB_MIN)
    #PRINTF_LIB = $(PRINTF_LIB_FLOAT)
    # Minimalistic scanf version
    SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
    # Floating point + %[ scanf version (requires MATH_LIB = -lm below)
    SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
    # If this is left blank, then it will use the Standard scanf version.
    SCANF_LIB =
    #SCANF_LIB = $(SCANF_LIB_MIN)
    #SCANF_LIB = $(SCANF_LIB_FLOAT)
    MATH_LIB = -lm
    # List any extra directories to look for libraries here.
    EXTRALIBDIRS =
    #---------------- External Memory Options ----------------
    # 64 KB of external RAM, starting after internal RAM (ATmega128!),
    # used for variables (.data/.bss) and heap (malloc()).
    #EXTMEMOPTS = -Wl,-Tdata=0x801100,--defsym=__heap_end=0x80ffff
    # only used for heap (malloc()).
    #EXTMEMOPTS = -Wl,--section-start,.data=0x801100,--defsym=__heap_end=0x80ffff
    EXTMEMOPTS =
    #---------------- Linker Options ----------------
    # -Wl,...: tell GCC to pass this to linker.
    # -Map: create map file
    # --cref: add cross reference to map file
    LDFLAGS = -Wl,-Map=$(TARGET).map,--cref
    LDFLAGS += $(EXTMEMOPTS)
    LDFLAGS += $(patsubst %,-L%,$(EXTRALIBDIRS))
    LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
    #LDFLAGS += -T linker_script.x
    #---------------- Programming Options (avrdude) ----------------
    # Programming hardware
    # Type: avrdude -c ?
    # to get a full listing.
    AVRDUDE_PROGRAMMER = usbasp
    # com1 = serial port. Use lpt1 to connect to parallel port.
    AVRDUDE_PORT = usb # programmer connected to serial device
    AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
    #AVRDUDE_WRITE_EEPROM = -U eeprom:w:$(TARGET).eep
    # Uncomment the following if you want avrdude's erase cycle counter.
    # Note that this counter needs to be initialized first using -Yn,
    # see avrdude manual.
    #AVRDUDE_ERASE_COUNTER = -y
    # Uncomment the following if you do /not/ wish a verification to be
    # performed after programming the device.
    #AVRDUDE_NO_VERIFY = -V
    # Increase verbosity level. Please use this when submitting bug
    # reports about avrdude. See <http://savannah.nongnu.org/projects/avrdude>
    # to submit bug reports.
    #AVRDUDE_VERBOSE = -v -v
    AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
    AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
    AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
    AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
    #---------------- Debugging Options ----------------
    # For simulavr only - target MCU frequency.
    DEBUG_MFREQ = $(F_CPU)
    # Set the DEBUG_UI to either gdb or insight.
    # DEBUG_UI = gdb
    DEBUG_UI = insight
    # Set the debugging back-end to either avarice, simulavr.
    DEBUG_BACKEND = avarice
    #DEBUG_BACKEND = simulavr
    # GDB Init Filename.
    GDBINIT_FILE = __avr_gdbinit
    # When using avarice settings for the JTAG
    JTAG_DEV = /dev/usb
    # Debugging port used to communicate between GDB / avarice / simulavr.
    DEBUG_PORT = 4242
    # Debugging host used to communicate between GDB / avarice / simulavr, normally
    # just set to localhost unless doing some sort of crazy debugging when
    # avarice is running on a different computer.
    DEBUG_HOST = localhost
    # Define programs and commands.
    SHELL = sh
    CC = avr-gcc
    OBJCOPY = avr-objcopy
    OBJDUMP = avr-objdump
    SIZE = avr-size
    AR = avr-ar rcs
    NM = avr-nm
    AVRDUDE = avrdude
    REMOVE = rm -f
    REMOVEDIR = rm -rf
    COPY = cp
    WINSHELL = cmd
    # Define Messages
    # English
    MSG_ERRORS_NONE = Errors: none
    MSG_BEGIN = -------- begin --------
    MSG_END = -------- end --------
    MSG_SIZE_BEFORE = Size before:
    MSG_SIZE_AFTER = Size after:
    MSG_COFF = Converting to AVR COFF:
    MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
    MSG_FLASH = Creating load file for Flash:
    MSG_EEPROM = Creating load file for EEPROM:
    MSG_EXTENDED_LISTING = Creating Extended Listing:
    MSG_SYMBOL_TABLE = Creating Symbol Table:
    MSG_LINKING = Linking:
    MSG_COMPILING = Compiling C:
    MSG_COMPILING_CPP = Compiling C++:
    MSG_ASSEMBLING = Assembling:
    MSG_CLEANING = Cleaning project:
    MSG_CREATING_LIBRARY = Creating library:
    # Define all object files.
    OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o)
    # Define all listing files.
    LST = $(SRC:%.c=$(OBJDIR)/%.lst) $(CPPSRC:%.cpp=$(OBJDIR)/%.lst) $(ASRC:%.S=$(OBJDIR)/%.lst)
    # Compiler flags to generate dependency files.
    GENDEPFLAGS = -MMD -MP -MF .dep/$(@F).d
    # Combine all necessary flags and optional flags.
    # Add target processor to flags.
    ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
    ALL_CPPFLAGS = -mmcu=$(MCU) -I. -x c++ $(CPPFLAGS) $(GENDEPFLAGS)
    ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
    # Default target.
    all: begin gccversion sizebefore build sizeafter end
    # Change the build target to build a HEX file or a library.
    build: elf hex eep lss sym
    #build: lib
    elf: $(TARGET).elf
    hex: $(TARGET).hex
    eep: $(TARGET).eep
    lss: $(TARGET).lss
    sym: $(TARGET).sym
    LIBNAME=lib$(TARGET).a
    lib: $(LIBNAME)
    # Eye candy.
    # AVR Studio 3.x does not check make's exit code but relies on
    # the following magic strings to be generated by the compile job.
    begin:
    @Echo.
    @Echo. $(MSG_BEGIN)
    end:
    @Echo. $(MSG_END)
    @Echo.
    # Display size of file.
    HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
    ELFSIZE = $(SIZE) --mcu=$(MCU) --format=avr $(TARGET).elf
    sizebefore:
    @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
    2>/dev/null; echo; fi
    sizeafter:
    @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
    # Display compiler version information.
    gccversion :
    @$(CC) --version
    # Program the device.
    program: $(TARGET).hex $(TARGET).eep
    $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
    # Generate avr-gdb config/init file which does the following:
    # define the reset signal, load the target file, connect to target, and set
    # a breakpoint at main().
    gdb-config:
    @$(REMOVE) $(GDBINIT_FILE)
    @Echo. define reset >> $(GDBINIT_FILE)
    @Echo. SIGNAL SIGHUP >> $(GDBINIT_FILE)
    @Echo. end >> $(GDBINIT_FILE)
    @Echo. file $(TARGET).elf >> $(GDBINIT_FILE)
    @Echo. target remote $(DEBUG_HOST):$(DEBUG_PORT) >> $(GDBINIT_FILE)
    ifeq ($(DEBUG_BACKEND),simulavr)
    @Echo. load >> $(GDBINIT_FILE)
    endif
    @Echo. break main >> $(GDBINIT_FILE)
    debug: gdb-config $(TARGET).elf
    ifeq ($(DEBUG_BACKEND), avarice)
    @Echo. Starting AVaRICE - Press enter when "waiting to connect" message displays.
    @$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
    $(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
    @$(WINSHELL) /c pause
    else
    @$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
    $(DEBUG_MFREQ) --port $(DEBUG_PORT)
    endif
    @$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
    # Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
    COFFCONVERT = $(OBJCOPY) --debugging
    COFFCONVERT += --change-section-address .data-0x800000
    COFFCONVERT += --change-section-address .bss-0x800000
    COFFCONVERT += --change-section-address .noinit-0x800000
    COFFCONVERT += --change-section-address .eeprom-0x810000
    coff: $(TARGET).elf
    @Echo.
    @Echo. $(MSG_COFF) $(TARGET).cof
    $(COFFCONVERT) -O coff-avr $< $(TARGET).cof
    extcoff: $(TARGET).elf
    @Echo.
    @Echo. $(MSG_EXTENDED_COFF) $(TARGET).cof
    $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
    # Create final output files (.hex, .eep) from ELF output file.
    %.hex: %.elf
    @Echo.
    @Echo. $(MSG_FLASH) $@
    $(OBJCOPY) -O $(FORMAT) -R .eeprom -R .fuse -R .lock $< $@
    %.eep: %.elf
    @Echo.
    @Echo. $(MSG_EEPROM) $@
    -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
    --change-section-lma .eeprom=0 --no-change-warnings -O $(FORMAT) $< $@ || exit 0
    # Create extended listing file from ELF output file.
    %.lss: %.elf
    @Echo.
    @Echo. $(MSG_EXTENDED_LISTING) $@
    $(OBJDUMP) -h -S -z $< > $@
    # Create a symbol table from ELF output file.
    %.sym: %.elf
    @Echo.
    @Echo. $(MSG_SYMBOL_TABLE) $@
    $(NM) -n $< > $@
    # Create library from object files.
    .SECONDARY : $(TARGET).a
    .PRECIOUS : $(OBJ)
    %.a: $(OBJ)
    @Echo.
    @Echo. $(MSG_CREATING_LIBRARY) $@
    $(AR) $@ $(OBJ)
    # Link: create ELF output file from object files.
    .SECONDARY : $(TARGET).elf
    .PRECIOUS : $(OBJ)
    %.elf: $(OBJ)
    @Echo.
    @Echo. $(MSG_LINKING) $@
    $(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
    # Compile: create object files from C source files.
    $(OBJDIR)/%.o : %.c
    @Echo.
    @Echo. $(MSG_COMPILING) $<
    $(CC) -c $(ALL_CFLAGS) $< -o $@
    # Compile: create object files from C++ source files.
    $(OBJDIR)/%.o : %.cpp
    @Echo.
    @Echo. $(MSG_COMPILING_CPP) $<
    $(CC) -c $(ALL_CPPFLAGS) $< -o $@
    # Compile: create assembler files from C source files.
    %.s : %.c
    $(CC) -S $(ALL_CFLAGS) $< -o $@
    # Compile: create assembler files from C++ source files.
    %.s : %.cpp
    $(CC) -S $(ALL_CPPFLAGS) $< -o $@
    # Assemble: create object files from assembler source files.
    $(OBJDIR)/%.o : %.S
    @Echo.
    @Echo. $(MSG_ASSEMBLING) $<
    $(CC) -c $(ALL_ASFLAGS) $< -o $@
    # Create preprocessed source for use in sending a bug report.
    %.i : %.c
    $(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
    # Target: clean project.
    clean: begin clean_list end
    clean_list :
    @Echo.
    @Echo. $(MSG_CLEANING)
    $(REMOVE) $(TARGET).hex
    $(REMOVE) $(TARGET).eep
    $(REMOVE) $(TARGET).cof
    $(REMOVE) $(TARGET).elf
    $(REMOVE) $(TARGET).map
    $(REMOVE) $(TARGET).sym
    $(REMOVE) $(TARGET).lss
    $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.o)
    $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.lst)
    $(REMOVE) $(SRC:.c=.s)
    $(REMOVE) $(SRC:.c=.d)
    $(REMOVE) $(SRC:.c=.i)
    $(REMOVEDIR) .dep
    # Create object files directory
    $(shell mkdir $(OBJDIR) 2>/dev/null)
    # Include the dependency files.
    -include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
    # Listing of phony targets.
    .PHONY : all begin finish end sizebefore sizeafter gccversion \
    build elf hex eep lss sym coff extcoff \
    clean clean_list program debug gdb-config
    Log
    Spoiler:
    > "make.exe" all
    0 [main] sh 1704 sync_with_child: child 8076(0x150) died before initialization with status code 0xC0000142
    14672 [main] sh 1704 sync_with_child: *** child state waiting for longjmp
    /usr/bin/sh: fork: Resource temporarily unavailable
    0 [main] sh 5780 sync_with_child: child 6656(0x14C) died before initialization with status code 0xC0000142
    26132 [main] sh 5780 sync_with_child: *** child state waiting for longjmp
    avr-gcc (WinAVR 20100110) 4.3.3
    Copyright (C) 2008 Free Software Foundation, Inc.
    This is free software; see the source for copying conditions. There is NO
    warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
    Compiling C: main.c
    avr-gcc -c -mmcu=atmega328p -I. -gdwarf-2 -DF_CPU=8000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=./main.lst -std=gnu99 -MMD -MP -MF .dep/main.o.d main.c -o main.o
    main.c:25: fatal error: opening dependency file .dep/main.o.d: No such file or directory
    compilation terminated.
    make.exe: *** [main.o] Error 1
    > Process Exit Code: 2
    > Time Taken: 00:01
    1. winavr chyba juz nikt nie uzywa (nie wiem czy ten projekt jeszcze zyje bo wersja na sourceforge ma 6 lat)- sciagnij sobie Atmel Studio.
    Atmel Studio posiadam niestety ni mam atmelowskiego programatora tylk usbasp próbowałem wgrać tam nowe narzędzie tak jak pokazano to tu:
    http://mikrokontrolery.blogspot.com/2011/03/Atmel-Studio-Programator-USBasp-USBTiny.html
    Ale w sumie nie wiem czy mi to wgl zadziałało.
    grko
    Poziom 33  
    Ocena: 141
    @fabjan1994
    Na moje oko to proces budowania nie działa popawnie (compilation termiated). Problem tkwi w powłoce sh. Tu masz rozwiązanie problemu:
    http://www.avrfreaks.net/forum/windows-81-compilation-error
    A tutaj Twój makefile po lekkim formatowaniu. Działa bez problemów:
    Kod: Bash
    Zaloguj się, aby zobaczyć kod
    BTW: Możesz wymienic to WinAVR na coś nowszego:
    http://www.atmel.com/tools/ATMELAVRTOOLCHAINFORWINDOWS.aspx
  • #7 15555037
    fabjan1994
    jednak proponuje AS-a. A dziala Ci jak podłaczysz do procka USBASP (z command line)?
    Masz na myśli wpisując komendę typu: 'avrdude -p atmega328p -c usbasp -P usb -t'
  • #8 15555088
  • #9 15555090
    fabjan1994
    GrzegorzKostka napisał:
    @fabjan1994
    miałeś co do tego rację :) dzięki -^
    To może jeszcze ktoś pomoże odnośnie konfiguracji usbasp pod AtmelStudio. Po zrobieniu wszystkiego jak na http://mikrokontrolery.blogspot.com/2011/03/Atmel-Studio-Programator-USBasp-USBTiny.html wyskakuje mi w cmd komunikat. Z czym on jest związany?
    avrdude.exe: AVR device initialized and ready to accept instructions
    Spoiler:
    Reading | ################################################## | 100% 0.03s
    avrdude.exe: Device signature = 0x1e950f
    avrdude.exe: erasing chip
    avrdude.exe: reading input file "C:\Users\Mariusz\Desktop\AVR\projekty C\GccAppl
    ication1\GccApplication1\Relase\main.hex"
    avrdude.exe: error opening C:\Users\Mariusz\Desktop\AVR\projekty C\GccApplicatio
    n1\GccApplication1\Relase\main.hex: No such file or directory
    avrdude.exe: input file C:\Users\Mariusz\Desktop\AVR\projekty C\GccApplication1\
    GccApplication1\Relase\main.hex auto detected as invalid format
    avrdude.exe: can't open input file C:\Users\Mariusz\Desktop\AVR\projekty C\GccAp
    plication1\GccApplication1\Relase\main.hex: No such file or directory
    avrdude.exe: write to file 'C:\Users\Mariusz\Desktop\AVR\projekty C\GccApplicati
    on1\GccApplication1\Relase\main.hex' failed
    avrdude.exe: safemode: Fuses OK
    avrdude.exe done. Thank you.
    Press any key to continue . . .
  • #10 15557677
  • #12 15558393
    el2010tmp
    Ocena: 44
    fabjan1994 napisał:
    projekty C
    Ta spacja w nazwie może sprawiać kłopot.
  • #13 15558651
    fabjan1994
    Problem rozwiązany chociaż podejrzewam że zakup lepszego programatora i tak będzie najrozsądniejszym wyjściem. A słyszałem że nowe wersje AVRdude mogą obsługiwać pliki elf? Może wie ktoś czy dałoby się jakoś zmienić tą funkcję żeby takie pliki były przesyłane?
  • #14 15559001
Użytkownik napotkał problem z kompilacją projektu dla mikrokontrolera Atmega328p-PU, ponieważ po wykonaniu polecenia "Make All" nie pojawiały się pliki .hex ani .eep. W odpowiedziach zasugerowano sprawdzenie Makefile oraz logów kompilacji, a także przesiadkę na Atmel Studio, ponieważ WinAVR jest przestarzały. Użytkownik próbował użyć programatora USBasp, a także zaktualizować narzędzia w Atmel Studio. Ostatecznie rozwiązano problem, zmieniając ustawienia na "release" w Atmel Studio, co pozwoliło na wygenerowanie pliku .hex. W dyskusji poruszono również kwestie związane z przyszłym zakupem lepszego programatora oraz możliwości przesyłania plików ELF przez AVRdude.
