VAG-COM Version: Release 311.2-N
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,15,16,17,26,36,37,45,46,55,56,63,76
Address 01 -------------------------------------------------------
Controller: 8E0 907 401 D
Component: 2.5L V6 TDI G000AG 0004
Coding: 02016
Shop #: WSC 63351
00003059 130 106LC150_1.V77587755188
No fault code found.
Address 02 -------------------------------------------------------
Controller: 8E0 927 156 L
Component: AG5 01V 2.5lTDI RdW 1819
Coding: 00001
Shop #: WSC 65535
Address 03 -------------------------------------------------------
Controller: 8E0 614 517 A
Component: ABS/ESP allrad 1726
Coding: 04457
Shop #: WSC 00650
1 Fault Found:
01826 - Sensor for Steering Angle (G85): Supply Voltage Terminal 30
35-00 - -
Address 08 -------------------------------------------------------
Controller: 8E0 820 043 C
Component: A4 Klimaautomat 0712
Coding: 00000
Shop #: WSC 65535
3 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-00 - Blocked or No Voltage
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
01794 - Control Module Incorrect Chassis (VIN) Number
35-00 - -
Address 09 -------------------------------------------------------
Controller: 8E0 907 279 B
Component: int. Lastmodul NDL 1512
Coding: 00012
Shop #: WSC 63351
1 Fault Found:
35-00 - -
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02141
Shop #: WSC 00650
11 Faults Found:
01748 - Switch for Tiptronic in Steering Wheel (E438): Up
29-00 - Short to Ground
01749 - Switch for Tiptronic in Steering Wheel (E439): Down
30-00 - Open or Short to B+
01317 - Control Module in Instrument Cluster (J285)
49-10 - No Communications - Intermittent
01304 - Radio
35-00 - -
27-00 - Implausible Signal
01332 - Door Control Module: Passenger Side (J387)
01331 - Door Control Module: Driver Side (J386)
01330 - Central Control Module for Central Convenience (J393)
Address 17 -------------------------------------------------------
Controller: 8E0 920 930 JX
Component: KOMBI+WEGFAHRS. RB4 D28
Coding: 01100
Shop #: WSC 19411
05567 AUZ6Z0A0215645
1 Fault Found:
Address 37 -------------------------------------------------------
Controller: 8E0 035 192
Component: RNS 4.1 H06 BNO 0017
Address 46 -------------------------------------------------------
Controller: 8E0 959 433 AE
Component: Komfortgerát T01 0315
Coding: 00576
Shop #: WSC 65535
16 Faults Found:
01333 - Door Control Module: Rear Left (J388)
01334 - Door Control Module: Rear Right (J398)
01320 - Control Module for Climatronic (J255)
37-10 - Faulty - Intermittent
00466 - Control Module for Steering Column Electronics (J527)
00457 - Control Module for Network (J519)
01561 - Left Rear Door
61-00 - Won't De-Safe
01562 - Right Rear Door
61-10 - Won't De-Safe - Intermittent
Address 56 -------------------------------------------------------
Component: Radio BNO 0001
Coding: 00207
Shop #: WSC 63351
2 Faults Found:
00856 - Radio Antenna
36-00 - Open Circuit
00855 - Connection to CD changer
End -------------------------------------------------------
Źle zrozumiałeś, albo ja źle przekazałem. Ktoś kiedyś gdzieś zakodował takie coś, że światła mijania same się włączają z zapłonem. Teraz coś dziwnego się dzieje i światła postojowe i mijania co chwile się włączają i gasną same nawet bez zapłonu i przy zamkniętym samochodzie.
