Search our partners
Lenovo X1 Carbon potrzebny wsad BIOS
gold-game 21 Aug 2016 13:05 5562 5
Computer Controls
  • #1
    gold-game
    Level 21  
    Witam. Mam na serwisie laptop lenovo X1 carbon, p³yta: LMQ-1 MB 12298-2 48.4LY06.021. Jest w nim raczej problem z biosBIOS. Po pod³±czeniu do zasilania p³yta uruchamia siê, pr±d do 0,5 0,6 A brak obrazu, po czym reset i ponownie. Poszukujê w³a¶ciwego wsadu dla tej p³yty. Wsady jakie znalaz³em w internecie mia³y 16mbMB, podczas gdy orygina³ ma standardowo 8mbMB. Wsady ze strony badcaps nie dzia³aj±.
    Obsada p³yty: MX25L6475E, MEC1632L-AUE, i5-4210U. Dorzucam mój oryginalny zrzut. Proszê o pomoc.
    [28-30.06.2022, targi] PowerUP EXPO 2022 - zasilanie w elektronice. Zarejestruj siê za darmo
  • Computer Controls
  • #2
    lisek
    Service technician RTV
    Gdzie¶ na forum (nie tym ) czyta³em ,¿e problem jest w MB.
    -wymieniano Bios, te¿ uk³ad 16MB > wsad 8MB > nie pomog³o
    Laptop dawa³ napiêcia stby i resztê .. nie dzia³±l.
    Start i reset po czasie.
    Brak SM niestety utrudnia naprawê.
    Po podobnych rozwi±zaniach laptopów Lenovo na tych samych uk³adach .
    Tam KBC to MEC1633 (MEC1633L-AUE , BGA) Link_ z Elceny
    Linkkrótki datasheet
    Quote:
    The MEC1633 incorporates a high-performance 32-bit ARC 625D embedded microcontroller with a 192 Kilobyte Embedded Flash Subsystem, 16 Kilobytes of SRAM, 1 Kilobyte EEPROM emulation, and a 2 Kilobyte EEPROM.
    The MEC1633 communicates with the system host using the Intel® Low Pin Count bus.
    The MEC1633 is the EC Base Component of a split-architecture Advanced I/O Controller system which uses BC-Link communication protocol to access up to three companion components. The BC-Link protocol is peer-to-peer providing
    communication between the MEC1633 embedded controller and registers located in a companion.
    The MEC1633 is directly powered by two separate suspend supply planes (VBAT and VTR) and senses a third runtime power plane (VCC) to provide “instant on” and system power management functions.
    The MEC1633 also contains an integrated VTR Reset Interface and a system Power Management Interface that supports low-power states and can
    drive state changes as a result of hardware wake events as defined by the MEC1633 Wake Interface.
    The MEC1633 defines a software development system interface that includes an MCU Serial Debug Port, a two pin serial debug port with a 16C550A register interface that is accessible to the EC or to the LPC host and can operate up
    to 2 MB/s, a flexible Flash programming interface, a Port 80 BIOS Debug Port, Gang Programmer Interface, and a JTAG interface.
    The EC can also drive the JTAG interface as a master.
  • Computer Controls
  • #3
    gold-game
    Level 21  
    Czyli problem mo¿e le¿eæ w KBC? Mogê spróbowaæ wymieniæ, je¿eli tak jest. Wracaj±c do tych wsadów, to jak próbowa³em z tym 16mbMB to orygina³ 8mbMB i ten 16mbMB w edytorze hex zaczyna³y siê identycznie. Nawet ko¶æ da³a siê zaprogramowaæ tym 16mbMB ale przy próbie uruchamiania z tym wsadem p³yta zaczyna pobieraæ 120mA i tak wisi wiêc jest du¿o gorzej ni¿ na org.
  • #4
    lisek
    To z Link_ elvikom
    Popatrz w SM od Lenovo X240 ( nm-a091), tam jest tak¿e MEC1633.
    - i5-4300U (SR1ED)
    Wszystko zapisane w niej
    Podobnie Lenowo W540
    Podobno b.podobne do
    ____________
    Podaj jaki uk³ad w stby napiêc ( 3,3V i 5V) i charger (BQ24xxx czy ISL )
  • #5
    sk1977
    IT specialist
    - Tak.
    - Jest programowalny, a wsadów do niego brak...
    Ogólnie jest problem z tym modelem - wsad dla KBC i PCH powinny byæ w kompatybilnych wersjach - warto wiêc jeszcze popróbowaæ z innymi wsadami - mo¿e trafisz.
    Sprawd¼ jeszcze ten.
  • #6
    gold-game
    Level 21  
    Wrzuci³em wsad kolegi sk1977 i po uruchomieniu sta³e 230mA, wentylator siê krêci, wszystkie napiêcia obecne i prawid³owe. Próbowa³em teraz wróciæ do mojego orygina³u ale co ciekawe na oryginale efekt jest teraz identyczny jak na obcym wsadzie. Byæ mo¿e problem wcale nie le¿y w bios, tylko w zimnych lutach pod mostkiem. Nie mam ochoty na reballing przez obecny czarny klej pod uk³adami. Co do obsady zasilania o które pyta³ kolega lisek, to jest tu klasycznie- BQ24760 i TPS511220A. PS zrobi³em jeszcze przelut wszystkich cewek i przetwornic napiêæ zasilania mostka i ram. W paru przypadkach pomaga³o na takie dolegliwo¶ci ale nie tutaj.
