motronic me 7.1 - czy warto wymieniac wsad ecu, silnik o innym stopniu sprężania
03 Gru 2016 22:12 1479 3
  • #1 16103020
  • #2 16123582
    pako150
    Czujesz w ogólę jakąś różnice ? Czy chcesz kopać tak od zasady ?
  • #3 16131796
    arnoldgouws
    Hi,
    No you don't have to replace the ECU at all, The software on that ECU was tuned for the old engine, you will have to change the software map on the ecu to adapt to the new compression ratio of the cylinders, because the airflow passing through the Mass Air Flow Sensor is no longer in spec with the tuned APR software.
  • #4 16459650
