Search our partners
Philips 42PFL6008S/12 - Nie uruchamia się błąd 22
Top Serwis 07 Dec 2016 11:01 7350 8
  • #1
    Top Serwis
    Level 24  
    Telewizor po włączeniu nie reaguje na pilota ani na klawiaturę, nie świeci stby.
    Po ok. minucie dioda stby. sygnalizuje błąd 2 krótkie błyski przerwa i 2 krótkie błyski.
    Chassis tego tv to QFU 1.2E LA , w opisie tego modelu nie ma opisu błędu 22 .
    Napięcia z zasilacza i na płycie prawidłowe . Telewizor nie reaguje na pendrive z softem ratunkowym .
    Prośba o pomoc.
  • #2
    lisek
    Service technician RTV
    W trybie SDM masz ten error22 ?
    - w stby Led miga x2 dwa razy to nic nie znaczy
    * zazwyczaj jak wejdziesz w SDM to error 53 (NAND)
    Przy czym może to być:
    - uszkodzenie CPU, zasilanie np. 1.25V, inne zasilanie 2,5V
    - wsad NAND, ..... ?
    Quote:
    Chassis QFU1.2E LA
    HiDTV FUSION
    The QFU1.2E LA chassis is part of the FUSION platform and
    covers sets in the 6xxx, 7xxx, 8xxx and 9xxx range.
    QFU1.2
    - 40/46/55/60PFL8008s
    - 42/47/55PFL7#08
    - 42/47/55PFL6008
    * all P/nr. : 3104 313 66124 / or 3104 303 54945
    It uses the same chipset as the earlier QFU1.1E LA chassis.
    * MediaTek MT5580 one-core
    * QFU2.1E LA/ QFU1.1E LA (cpu: Trident fusion240) / QFU1.2E LA
    Only circuits that differ from this chassis are described in this
    manual. For all other info, refer to the QFU1.1E LA manual.
    Z SM
    Quote:
    Back-up Software Upgrade Application If the default software upgrade application does not start (could be due to a corrupted boot sector) via the above described method, try activating the “back-up software upgrade application”.
    How to start the “back-up software upgrade application” manually:
    1. Disconnect the TV from the Mains/AC Power.
    2. Press the “CURSOR DOWN”-button on a Philips TV remote control while reconnecting the TV to the Mains/AC Power.
    *(attention : not supported by use of RF4CE remote due to the fact this application is not running yet at the time of the “CURSOR-DOWN” request).
    3. The back-up software upgrade application will start.
  • #4
    Top Serwis
    Level 24  
    Pamięci Ram to Hynix.
  • #6
    Top Serwis
    Level 24  
    W trybie SDM błąd 53.
    W trybie SDM podłączyłem do sieci z wcisniętym przyciskiem strzałka w dół i telewizor ożył.
    Na razie testuję.
  • #8
    Top Serwis
    Level 24  
    Może tak być też w tym przypadku ponieważ tv na chwilę zamroził obraz pojawiła się dziwna pikseloza i restart. Więc pewnie uszkodzenie "dojrzewa" .
  • #9
    Top Serwis
    Level 24  
    Na drugi dzień problem powrócił. Na życzenie klienta wymieniłem płytę główną co przywróciło prawidłową pracę.
