WItam.
Jakis czas temu w A6 C5 przelozylem silnik i skrzyni auto na manual z AKN na AFN ze sterowaniem ECU z AVG i mam pare bledow ktorych nie moge sie pozbyc. Z tego co wywnioskowalem to walniety jest czujnik poziomu oleju w misce i prawy czujnik PDC ale nie wiem co z reszta bledow. Dodam ze ASR ciagle swieci na zegarach. Z gory dzieki i pozdrawiam.
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4B0 919 283 P
Component and/or Version: parkingsystem A6 RDW D18
Software Coding: 01116
Work Shop Code: WSC 02325
1 Fault Found:
01548 - Sensor for Parking Aid: Rear Right (G206)
30-00 - Open or Short to B+
Control Module Part Number: 4B0 920 932 K
Component and/or Version: C5-KOMBIINSTR. VDO D12
Software Coding: 00060
Work Shop Code: WSC 00186
Additional Info: WAUZZZ4BZ1N069838 AUZ7Z0Y1621691
3 Faults Found:
01177 - Engine Control Unit
49-00 - No Communications
01314 - Engine Control Module
49-10 - No Communications - Intermittent
00562 - Sensor for Oil Level/Temperature (G266)
Control Module Part Number: 038 906 012 BT
Component and/or Version: 1,9l R4 EDC 0000SG 2805
Software Coding: 00002
Work Shop Code: WSC 06335
3 Faults Found:
19561 - Valve for Intake Manifold Flap (N239): Open or Short to Ground
P3105 - 35-10 - - - Intermittent
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Control Module Part Number: 3B0 614 111
Component and/or Version: ABS/ASR 5.3 FRONT D00
Software Coding: 00012
1 Fault Found:
18257 - Please check DTC Memory of Transmission Controller
P1849 - 35-00 - -
Control Module Part Number: 4B0 927 156 DK
Component and/or Version: AG5 01V 2.5lTDI RdW 3132
Software Coding: 00003
Work Shop Code: WSC 00000
5 Faults Found:
18249 - Engine Control Module / Transmission Control Module Incompatible
P1841 - 35-00 - -
18155 - Transmission Solenoid Power Relay: Open or Short to Ground
P1747 - 35-00 - -
18258 - Powertrain Data Bus: Missing Message from ECU
P1850 - 35-10 - - - Intermittent
17090 - Transmission Range Sensor (F125): Implausible Signal
P0706 - 35-00 - -
18158 - Supply Voltage too Low
P1750 - 35-00 - -
1 Fault Found:
3 Faults Found:
3 Faults Found:
P0571 - 35-00 - -
1 Fault Found:
P1849 - 35-00 - -
5 Faults Found:
P1841 - 35-00 - -
P1747 - 35-00 - -
P0706 - 35-00 - -
P1750 - 35-00 - -
