[Sprzedam] Mini moduł Bluetooth 4.0 BLE nRF51822 WT51822-S4AT
Szaflik 02 Sie 2017 21:04 2028 0
  • #1 16622145
    Szaflik
    Do sprzedania mam moduł Bluetooth Low Energy (BLE) oparty na RF SoC Nordic Semiconductors nRF51822 - WT51822-S4AT.
    Strona producenta modułu: Link.
    Strona producenta układu nRF51822: Link.
    Datasheet modułu WT51822-S4AT:Link
    Moduł może być wykorzystywany jako mostek Bluetooth LE - UART, lub niezależnie po wgraniu własnego oprogramowania - linie SWD dostępne dla użytkownika.
    Spoiler:
    nRF51822 features:
    > 2.4 GHz multiprotocol RF transceiver
    > ARM® Cortex™-M0 32 bit processor
    > 128 bit AES HW encryption
    > 256kB flash & 32kB RAM
    > Programmable Peripheral Interconnect (PPI)
    > Digital interfaces: SPI, I2C, UART
    > 10 bit ADC
    > Programmable output power: -20 to +4 dBm
    > Independent application development and protocol stack
    > Fully compatible with NRF24L series
    > Pinout compatible with NRF51xxx series
    > Global separate power management
    > Operating voltage: 1.8 V ~ 3.6 V
    WT51822-S4AT module features:
    > Operating temperature: -25℃~75℃, typical 25℃
    > CPU: nRF51822-QFAA (ARM Cortex™-M0 32 bit processor)
    > Memory: 256KB flash + 16KB RAM memory
    > Transparent transmission (Bridged method) easy to use and fast, no Bluetooth protocol stack development experience can use too.
    > The user interface uses a standard UART (TTL) Interface, bidirectional data read, easy to operate
    > Supports serial AT commands, the user can modify the basic parameters like the serial port baud rate, name, MAC address of the module, etc.
    > Serial data packet length, single data packet can support data length up to 200byte;
    > Serial hardware enable control, low-power control applications
    > With the support under the test mode but not connect the serial mode, mutual communication between test module and bluetooth master devices
    > Operating distance: 0~45m,class II level
    > Support System: IOS & Android
    > Supply voltage:2.0-3.3V
    > Module comes with PCB antenna, optional external antenna
    Cena: 18,50PLN/szt [została 1 sztuka]
    Kontakt: PW/e-mail/tel. 693129245
    Możliwość wysyłki InPost/PP. Odbiór osobisty - Gdańsk
    [Sprzedam] Mini moduł Bluetooth 4.0 BLE nRF51822 WT51822-S4AT[Sprzedam] Mini moduł Bluetooth 4.0 BLE nRF51822 WT51822-S4AT[Sprzedam] Mini moduł Bluetooth 4.0 BLE nRF51822 WT51822-S4AT[Sprzedam] Mini moduł Bluetooth 4.0 BLE nRF51822 WT51822-S4AT
