Main data
Parameter Value
VIN VF3GBWJYB96025025
Brand PEUGEOT
Permanent link https://carinfo.kiev.ua/cars/vin/peugeot/vin_check?su=5pi33ardvtpf
Vehicle characteristics
Parameter Value
Vehicle family PARTNER VU (M59)
AS/RP N° 09606 FV 1 0837
Warranty Start Date 20/03/2003
Engine serial number 10 DXEU 6014586
TRIM LEVEL LEVEL 1
PAINT TYPE METALLIC PAINTWORK
BODY COLOUR EZR - PAINT ALUMINIUM GREY
INTERIOR TRIM TYPE ARSINOE "PG" CLOTH
UPHOLSTERY COLOUR "FZ"
GEARBOX (CHARACTERISTICS) BE4-5L MANUAL GEARBOX
SPEEDOMETER DRIVE TACHO TORQUE 19X17
General information
Parameter Value
PRODUCT TYPE UTILITY VEHICLE
COMMERCIAL MARQUE/COMPONENT TYPE PEUGEOT
VEHICLE FAMILY PARTNER VU (M59)
SILHOUETTE SHORT VAN ’600’
TRIM LEVEL LEVEL 1
ENGINE DW8B DIESEL
TRANSMISSION BVM5
ENGINE (TYPE) EW/DW
OTHER BADGE, " MISC. " WITHOUT FULLER BADGE
BADGE PARTNER
Fuel supply-Engine
Parameter Value
INJECTION ASSOCIATED VARIANT MOUNTING DELPHI
HYBRID DRIVE TRAIN WITHOUT HYBRID TRACTION CHAIN
ENGINE DW8B DIESEL
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 2000 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
ENGINE (TYPE) EW/DW
CAPACITY 1900 CM3
COOLING MOTOR RADIATOR THICKNESS: 27 -21 3 DM2 MBA HP
EOBD SELF-DIAGNOSIS SYSTEM WITHOUT "EOBD" AUTO-DIAGNOSTIC
VEHICLE TECHNICAL DEPOLLUTION W4 VEHICLE TECHNICAL DEPOLLUTION
FAN 1 460W 3-SPEED FAN
Gearbox Transmission
Parameter Value
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 17 X 77
WHEEL STYLE 14 INCH STEEL WHEEL
DIFFERENTIAL (GEARBOX) STD IMP GEARBOX DIFF
TYRE (SIZE, TYPE) 175/65 R14 88/90T REINFORCED TYRE
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE GEARBOX BE4R
Suspension-Steering-Brakes
Parameter Value
BRAKE ASSOCIATED VARIANT ABS BOSCH 5 3
ABS WITH ABS BRAKES
REAR ANTI-ROLL BAR REAR ANTI-ROLL BAR DIAM 21
FRONT ANTI-ROLL BAR FRONT ANTI-ROLL BAR DIAM 21
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM WITHOUT ELECTRONIC STABILITY PROGRAM
Body fittings
Parameter Value
SIDE MOULDINGS (TYPE) LATERAL PROTECTOR MASS TINTED
SIDE MOULDINGS (DIMENSION) SIDE PROTECTORS WIDTH = 95
WHEEL EMBELLISHER (STYLE) CABOCHON HUB COVER
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
REAR SCREEN WIPER W/O REAR SCREEN WASH WIPE
HEADLAMP WIPER W/O HEADLAMP WIPER
REAR ROOF FLAP W/O ROOF TRAP
SIDE LOAD DOOR WITHOUT SLIDING SIDE DOOR
BUMPER DYED FRONT/REAR BUMPER
LUGGAGE RACK WITHOUT ROOF BARS
FRONT FOGLAMP NO FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) HT EXT RRVW MIRROR MN INT CTR
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
SPARE WHEEL STEEL WHEEL + STANDARD TYRE
EXTERIOR ACCESSORIES NEUTRAL EXT HANDLE+FLAP TRIM+EXT RR VIEW MIRROR
SPARE WHEEL MOUNTING SECURE SPARE WHEEL CARRIER
SUN ROOF FIXED ROOF
REAR WINDOW (TYPE) REAR GLASS HEATED
GLASS (APPEARANCE) TINTED
WINDOW (TYPE) ATHERMAL WINDSCREEN
SIDE WINDOW (COMM. VEH. ONLY) WITHOUT SIDE WINDOW
Interior fittings
Parameter Value
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
FRONT SEATBELT PYROTECHNIC SEAT BELT WITH ALARM
CLIMATE (AMBIENT TEMP) COLD COUNTRIES
AIR CONDITIONING WITHOUT AIR RECYCLING
SPEED GRADUATIONS GRADUATION KMS/H
DRIVING POSITION LEFT HAND DRIVE
REMOTE CONTROL REMOTE CONTROL ASSEMBLY
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
MISC. INT. LAMPS W/O MAP READING LAMP
WORK TABLE WITHOUT WORK TABLE
LOAD SPACE TRIM W/O MAT
INSTRUMENT PANEL (CHARACTERISTICS) GRADUATION 210 KM/H 135 M/H BLACK LAND
LOUDSPEAKER 4 FRONT SPEAKERS (2 TW + 2 FRONT)
RADIO CONTROLS REMOTE RADIO CONTROL
DRIVER SEAT CONTROL MANUAL DRIVER’S SEAT CONTROL
FRONT PASSENGER SEAT CONTROL MANUAL FRONT PASSENGER SEAT CONTROL
DRIVER’S SEAT FOLDING W/O FOLDING DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDING W/O FOLDING PASS FRONT SEATING
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
DRIVER’S WINDOW LIFT SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT ELEC CNTRL PASS FRONT WINDOW LIFTER
DISPLAY DISPLAY (CLOCK AND OR TEMP)
CLOCK WITHOUT CLOCK
COURTESY MIRROR PASSENGER SIDE WITHOUT LIGHTING
OIL GAUGE STD OIL LEVEL INDICATOR
HEATING ELEMENT NON HEATED SEAT
FRONT LATERAL AIRBAG WITHOUT FRONT SIDE AIRBAG
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
PASSENGER AIRBAG PASSENGER AIRBAG
ON-BOARD COMPUTER NO COMPUTER
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
REAR MOVING PANEL 2 REAR HINGED WINDOW DOORS
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD CAB PROTECTION LADDER
RADIO RECEIVER "RD3" RDS AUDIO SYSTEM
REFRIGERATION AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER AIRBAG DRIVERS AIR BAG
LOAD SPACE STORAGE W/O BOOT TIDY
CARPET DILOURS CARPET F330
FLOOR MAT W/O CARPETMAT
LOCKING CONTROL SIMPLE CENTRAL LOCKING
Electrical
Parameter Value
ALTERNATOR ALTERNATOR 80 AMP
BATTERY BATTERY L2 400
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
CEN. LOCKING REM CONTROL FREQUENCY LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE
ELECTRIC VEHICLE CHARGING PLUG WITHOUT VEHICLE LOAD RECOGNITION
Component manufacturers
Parameter Value
Miscellaneous
Parameter Value
SPECIAL SPECIFICATION STANDARD
RADIO HEADPHONE SOCKET WITHOUT ACCESSORIES SOCKET
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
System information
Parameter Value
Brand PEUGEOT
DB storage version 1.2
Data language en
Record was added in database 2019-01-18 14:36
Last query date 2019-01-18 14:36
Last update date 2019-01-18 14:36
Data display version 2.0
