Proszę, nie wiem czy to twoje ale na autobaza.pl pokazuje że auto miało jakąś szkodę.
Spoiler:
Parameter Value
Brand AUDI
Model AUDI TT COUPE 1.8 QU.
VIN TRUZZZ8NZY1055873
Production date 1999-12-10
Model year 2000
Engine code APX
Engine number 000
Engine volume, L 1.80
Number of cylinders 4
Power, KW 165
Power, PS 225
Colour of body 5B (SILVER: light silver metallic)
Colour of roof 5B (SILVER: light silver metallic)
Trim JP
Gearbox code DQB (6S)
Country of sale 000 ()
Custom options
Parameter Value
E0A Special editions: No special edition
1PC Lockable wheel bolts: Wheel bolts with anti-theft protection (unlockable)
0CV Vehicle class differentiation units/platform components: Vehicle class differentiation 8N0
0GF Emissions standard: Abgaskonzept, D3 (EU3D)
1D0 Trailer hitch: Without trailer hitch
4UF Airbag: Driver's and front passenger air bag with front passenger air bag deactivation
1E1 Activated carbon canister: Activated carbon canister
7CA Label for radio remote control: Without label for radio remote control
0W1 Label for central electric: Label for central electric German-speaking countries
6XD Exterior mirror setting: Exterior mirrors: electrically adjustable/heated
5SL Left exterior mirror: Left exterior mirror: aspherical
5RU Right exterior mirror: Right exterior mirror: convex (large viewing field)
1X1 Drive layout: Four wheel drive
9Y1 Outside temperature display: Outdoor temperature gage
A8S Equipment levels: Standard equipment
1KF Brake type in rear: Disc brakes, rear
J1L Batteries: Battery 280 A (60 Ah)
1LT Brake type, front: Disc brakes, front
4M0 Beverage holders: Without cup holder
B0A Component part sets with country-specific design requirements: Component parts set without country-specific design requirement
1H0 Proportioning valve: Without proportioning valve
0VC Owner's manuals: Information kit in German
9U1 Brake pad wear indicator: Brake pad wear indicator
9T1 Heated washer nozzles: Heated washer nozzles, front
7QA CD ROM/DVD/SD card: Without CD/DVD for navigation
7A0 CD changer/CD player: Without CD changer/CD player
C04 General operating permit, alterations: Operating permit, alteration
2D1 Cd enhancing underbody panel: Complete cd enhancing underbody panel
3FA Roof insert/convertible top: Without roof insert (standard roof)
1JL Suspension system in rear: Rear shock absorption
1GS Suspension system in front: Front shock absorption (AUDI TT)
2G9 Insert for the filling up of unleaded fuel/fuel type: Filler neck module 2 with insert
7AA Theft protection system: Electronic vehicle immobilization device
7X0 Park distance control: Ohne Einparkhilfe (Parkpilot)
0FA Manufacturing sequence differentiation: Standard manufacturing sequence
4R1 Window regulator: Power windows
8K0 Headlight control: Without special headlight activation
2V1 Fresh air intake for passenger compartment (with particulate filter): Dust and pollen filter
1C1 Antifreeze: Antifreeze up to -25 degree celsius tolerance up to -30 degree C
F0A Vehicle specifications: No special purpose vehicle, standard equipment
0L2 Throttle control: Electric throttle actuation
8GL Alternators: Alternator 120 A
0G4 Transmission types/gearshift mechanisms: Cable gearshift
0YP Weight category rear axle: Weight range 14 installation control only, no requirement forecast
U93 Weight category front axle: Suspension range 192
T6B Base engine: 4-cylinder gasoline engine 1.8 L unit 06A.G
8T0 Cruise control system: Without cruise control system (CCS)
2B9 Exterior noise suppression measures: Additional exterior noise suppression
VC0 Garage door opener: W/o remote-controlled garage door opener
G0L Transmission specifications: 6-speed manual transmission for four-wheel drive vehicle
6PA Hand brake lever handle: Plastic hand brake lever handle
6V1 Rear trim panel: Rear trim panel (ECE)
8M0 Rear window wiper and washer system: W/o rear window wiper and washer system
0N5 Rear axle: Standard rear axle
9AK Heating and air conditioning system: Climatronic with impact pressure control free of cfc
8BG Headlamps: Twin-headlight for driving on the right, with integrated high beam
5F0 Hardtop: Without hardtop
FC0 Customized installation: Without customized installation
U2A Instrument clusters: Instrument insert with km/h speedometer, radio-controlled clock, tachometer and trip odometer
K8C Body style: Coupe
2LB Fuel tank treatment: Kraftstoffbehälter mit besonderer Werkstoffbehandlung (Fluorierung)
1Z2 Fuel quantity for initial filling: Increase in initial standard fuel filling
0F2 Fuel systems: Fuel system for carburetor gasoline engine
5C7 Body measures: Additional body measures
6W5 Front license plate carrier: Front license plate bracket
5K5 Paint preservative/transit coating: Transportschutzfolie (anstelle Lackkonservierung)
L0L Steering system arrangement: Left-hand drive vehicle
1N4 Steering: Servolenkung (andere Гњbersetzung)
3H5 Backrest release: Backrest release for front seats with additional backrest release on the inner side
7P0 Lumbar support: Without lumbar support in seat backrests
2ZN Steering wheels: Leather trimmed sports steering wheel with aluminum appearance
9VD Speaker installation: Speaker (active)
2C5 Steering column systems: Axial and vertical adjustable steering column
8Q1 Headlight range control: Headlight-range adjustment
6E0 Center armrest: Without center armrest front
9Q0 Multi-function display/trip computer: Without multi-function display/ on-board computer
8Z5 Engine cooling system: MotorkГјhlung AusfГјhrung 1
M4S Engine specifications: 4-cyl. turbo gasol. eng. 1.8 L/165kW 20V EU 3D base engine is T6B
4SD Left vanity mirror: Left vanity mirror, illuminated
4TD Right vanity mirror: Right vanity mirror illuminated
7Q0 Navigation device: Without navigation device
8TC Rear fog lamp: Rear fog light for driving on the right
4P0 Platform module, luggage compartment floor: Rear floor panel module, type 1
C4N Wheels: Alloy wheels 7.5J x 17
8UC Radios: Radio "chorus"
9JD Smoker's/non-smoker's package: Smoking package, ashtray front
H6G Tires: Tires 225/45 ZR17 91Y
V0A Tire suppliers: Tires w/o specification of tire brand
1G9 Spare wheel/breakdown kit: Space-saving spare wheel for temporary use, radial tire (5-hole)
PLT leather upholstery and trimleather upholstery and trim
RBL "chorus" radio"chorus" radio
4X1 Side airbag: Side air bag front
6Q7 Gearshift knob/handle: Leather gearshift knob with aluminum appearance
A00 Self-collection / special control: No self-collection
0ST Special labels/plates: Labels/plates in German and French
4E6 Lock operation for tailgate/trunk lid: Entriegelung Heckklappe/Deckel nur von innen
2K1 Bumper systems: Reinforced bumpers
9P0 Seat belt check: Without seat belt reminder
6R3 Gearshift boot/cover: Rubber gearshift boot
N5D Seat trim covers: Valcona leather seat covering
3L3 Seat adjustment: Manual height adjustment for front seats
4A3 Seat heater: Seat heater for front seats separately controlled
0LW Safety certificate: Special plates/stickers/ safety certificates for Germany
7L0 Start-stop system/regenerative braking: Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
8Y1 Horns: Two-tone horn
S39 Control number (no PR family): Control number
SA6 Control number (no PR family): Inventory control model 1
0BJ Rear stabilizer bar: Rear stabilizer
0AN Front stabilizer: Stabilizer, front
FA0 Handling production and pre-production: Control of standard production
8X0 Headlamp washer system: Without headlight washer system
8N4 Windshield wiper intermittent control/ light/rain sensor: Windshield wiper intermittent control with potentiometer (four speeds)
6N0 Mud flap: Without mud flaps
2W0 Fuel filler cap/door, locking option: Fuel filler cap
4K4 Door and lid locking system: Zentralverriegelung m. Funkfernbedienung Innenbetätigung und separater Kofferraumentriegelung
B99 Type approval countries/countries with special requirements: Type approval EC
5D1 Carrier frequency for radio remote control: Trägerfrequenz 433,92 MHz
0A1 Doors: 2 doors
QV0 TV reception/digital radio reception: W/o TV reception/digital radio reception
8CC Speedometer cable and seal: Speedometer sensor without seal (electronic speedometer sensor)
1SA Front underbody guard: Without additional front underbody guard
1EX Identification plates: Spezielles Typschild fГјr EG
2Z1 Type sign: Type sign at rear and "Quattro" nameplates respectively
2A4 Delivery equipment: Delivery equipment for shipment (transit coating) with thick seat cover
1T3 First aid kit / warning triangle: First aid kit with warning triangle
9D0 Preparation for two-way radio installation: Without preparation for two-way radio installation
Q1D Front seats: Sports front seats
9W0 Telephone / telematics: W/o car phone preparation/installation
7S0 Wind deflector: Without wind blocker
QG1 Service interval prolongation: Service interval prolongation
7E0 Heat accumulator system/auxiliary heater: W/o heat accumulator/auxiliary heating
4GH Windshield glass type: Windshield in heat-insulating glass with sunshield
8W0 Washer fluid level indicator: Without washer fluid level indicator
2WA Additional tires (snow tires): Without additional tires
3B0 Additional child seat anchors: Without additional child seat anchor
0RA Ignition/starter switch locking system: Without ignition/starter switch locking system
9M0 Auxiliary heater: Without auxiliary/parking heater
Kup raport https://www.autodna.pl/vin/TRUZZZ8NZY1055873, pracowałem w tej firmie jakiś czas temu, wydasz parę złotych ale możesz dowiedzieć się czegoś ciekawego o samochodzie, autobaza również jest dobra, jak wolisz
